04-17-2017, 12:47 PM | #1 |
What year Steering Columns Fit 86 C10?
My brother is looking to replace the steering column in his 86' C10. He found a 91' for $40 but isn't sure it fits. Anyone know what years beyond 86' that fit?
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb |
04-17-2017, 01:02 PM | #2 |
Re: What year Steering Columns Fit 86 C10?
More info, the 91' is from a suburban. It's the round column. I'm thinking it fits but don't want to give him bad info.
04-18-2017, 01:36 AM | #3 |
Should fit as a drict fit as long as it's got the same option on the Column, As your's.
84-91
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
04-18-2017, 12:30 PM | #4 |
85-94 would work best. You can use 73-84 as well, but you would have to relocate your wiper, and bright switch.
04-18-2017, 01:57 PM | #5 |
