Old 04-04-2017, 04:13 PM   #476
71cheynne402
Re: What did you do to your Blazer/Jimmy today?
Bought a jimmy to go along with my blazer. The orange blazer is mine the white one was my cousins but he sold it recently.
71 Cheyenne 72 k5 71 jimmy 72 k10
71cheynne402 is offline   Reply With Quote
Old 04-04-2017, 10:11 PM   #477
Chulisohombre
Chulisohombre's Avatar
AWesome jimmy. Looks to be in great shape.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 04-05-2017, 07:40 PM   #478
OldBalls
OldBalls's Avatar
So this happened today...
OldBalls is offline   Reply With Quote
Old 04-05-2017, 08:26 PM   #479
dirish
dirish's Avatar
Very nice, what size are the wheels?
dirish is offline   Reply With Quote
Old 04-05-2017, 08:28 PM   #480
OldBalls
OldBalls's Avatar
35" tires 18x9 wheels.
Old 04-05-2017, 11:56 PM   #481
stangtjk
Finished blasting and shot a coat of primer on the floor.... Was in the zone and didn't think to snap a shot in bare metal... Also received a set of 4" skyjacker lift springs to eliminate the lift blocks.
stangtjk is offline   Reply With Quote
Old 04-06-2017, 05:41 PM   #482
Bill21
I wash it and polised it
Bill21 is offline   Reply With Quote
Old 04-08-2017, 11:08 PM   #483
raggedjim
raggedjim's Avatar
Trimmed and fit a windshield frame. Hopefully get it welded in tomorrow. I had been dreading this, but it wasn't as bad as I thought it would be.
Roger
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 04-09-2017, 08:51 AM   #484
lks dcvn
lks dcvn's Avatar
Wow -good work RG! Coming together nicely.
lks dcvn is offline   Reply With Quote
Old 04-09-2017, 11:10 PM   #485
raggedjim
raggedjim's Avatar
Thanks, I have a long way to go... hows your's going?
The bad news is I didn't have time to weld it in today, the good news is I was able to use the shorter frame I had so I still have another windshield frame I can sell to help someone else get theirs done! Silver linings all around.
Rg
Roger
'70 GMC Jimmy 2wd
Old 04-10-2017, 05:19 PM   #486
stangtjk
Whats up with that color change from green to tan, lighting make that big of a difference?
Old 04-11-2017, 10:22 PM   #487
Slick67
Sofa King Crazy!!
Slick67's Avatar
Fabbed a bracket to hold my airride stuff and had it powdercoated. Didn't do it in one day but got it installed!!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 04-12-2017, 11:13 AM   #488
BLT-NT-BOT
Finished painting the dash and tomorrow I will spray the frame.
BLT-NT-BOT is offline   Reply With Quote
Old 04-12-2017, 11:52 AM   #489
raggedjim
raggedjim's Avatar
Probably the old sony camera I use! I think it flashed on the last pic but not the first (later in the day) It is green, not tan.
Roger
'70 GMC Jimmy 2wd
Old 04-12-2017, 11:52 AM   #490
raggedjim
raggedjim's Avatar
Nice work on this, Rg
Roger
'70 GMC Jimmy 2wd
Old 04-12-2017, 12:09 PM   #491
BLT-NT-BOT
Thank you, this is my first attempt at doing all the work myself.
Old 04-12-2017, 12:40 PM   #492
raggedjim
raggedjim's Avatar
Well, it certainly looks like you know what you are doing. I'm trying to do everything myself also, and it shows!
Do you have a build thread for this Blazer?
Good luck, Rg
Roger
'70 GMC Jimmy 2wd
Old 04-12-2017, 12:51 PM   #493
BLT-NT-BOT
Good luck, Rg
I have not started one yet, I guess I should get one going.
Old 04-15-2017, 01:02 AM   #494
GM man
GM man's Avatar
Removed my transfer case to get it rebuilt for my 6.0 LS / 4L60 swap.
1972 GMC Jimmy 6.0/4L65
1972 Chevrolet long bed 1/2 ton
GM man is offline   Reply With Quote
Old 04-15-2017, 04:15 PM   #495
BLT-NT-BOT
Got a little more painting done.
Old 04-15-2017, 05:03 PM   #496
stangtjk
Blasted and primed the frame... Trying to choose what to top coat it with. I might try some thinned down bed liner sprayed on with an hvlp gun with 2.0 tip for the top coat.
Old 04-20-2017, 09:53 PM   #497
broda1
broda1's Avatar
I got tired of the Blazer Hedman's scraping the ground, ended up with exhaust leak so I got some Chevelle Hedman headers. They're thicker and pretty nice looking. Didn't use the gaskets that came with though. Also swapped out both cross members with cut-out cross members from CPP. Plenty of clearance now.
TM
broda1 is offline   Reply With Quote
Old 04-20-2017, 11:06 PM   #498
Brian Atkinson
Brian Atkinson's Avatar
Not super exciting but I added a light to my center console
1970 CST C10
1971 CST 2WD Blazer
1971 Cheyenne Super C10 - Sold
1972 Super Custom K20 - Sold
1972 Cheyenne Custom Camper C20 - Sold
Looking to trade my 2WD blazer for a nice 4WD!
Brian Atkinson is offline   Reply With Quote
Old 04-21-2017, 07:57 AM   #499
A1971Blazer
A1971Blazer's Avatar
There was an old 70s era roll bar in the parts Blazer I bought....in the process of modifying it for a better fit.....
need to finish welding it....sandblast..... and go to powder coat.
I bought a nice new set of 3 point retractable seat belts from MCB Matt one of our vendors...
gonna mount the top link to the roll bar......
rear supports were too short to fit on top of the wheel hubs
added 9" to them
view from the back..the pic makes it look taller than the windshield....
it's actually shorter
final fitting before welding the supports in
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is online now   Reply With Quote
Old 04-21-2017, 09:30 AM   #500
raggedjim
raggedjim's Avatar
TM
Broda, you need to show more pics of this blazer, it's really nice. Did you buy the 67-68 trim from Mar-K? How did you install it? I have it but I'm far from paint so it will be 1 to 13 years before I get it on...
Roger
'70 GMC Jimmy 2wd
Copyright ©2000 - 2018, vBulletin Solutions Inc.
