Old 04-21-2017, 10:53 AM   #501
Okie528
Okie528's Avatar
Re: What did you do to your Blazer/Jimmy today?
Originally Posted by A1971Blazer View Post
There was an old 70s era roll bar in the parts Blazer I bought....in the process of modifying it for a better fit.....
need to finish welding it....sandblast..... and go to powder coat.
I bought a nice new set of 3 point retractable seat belts from MCB Matt one of our vendors...
gonna mount the top link to the roll bar......
rear supports were too short to fit on top of the wheel hubs
Attachment 1644414
added 9" to them
Attachment 1644415
view from the back..the pic makes it look taller than the windshield....
it's actually shorter
Attachment 1644416
final fitting before welding the supports in
Attachment 1644417
Nice work! Roll bar is looking great...big improvement!
Okie528 is offline   Reply With Quote
Old 04-21-2017, 07:13 PM   #502
Chulisohombre
Chulisohombre's Avatar
Attachment 1644414
added 9" to them
Attachment 1644415
Attachment 1644416
Attachment 1644417
I have that same rollbar in my blazer. i planned on attaching a three point belt to the rollbar as well. It makes me feel
Much safer having something over my head when the top is off.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 04-21-2017, 07:42 PM   #503
stangtjk
Shot a coat of raptor liner on the frame. Used two bottles but sprayed it with an hvlp gun instead of the shutz gun. I didn't thin it at all and it sprayed on fine. I like how the texture came out. If you held the gun close it left a smooth surface almost like paint but backing up a few inches gave it a nice even texture. Looks sandpaperish but still feels smooth. Kinda wish I did the underside like that now.
stangtjk is offline   Reply With Quote
Old 04-23-2017, 12:15 AM   #504
mister.freeze
mister.freeze's Avatar
New crate motor. Just a plain Jane 350. I already miss my stroker...
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
Old 04-23-2017, 08:01 AM   #505
Walter White
Walter White's Avatar
Stan, if you were to do a build thread i know i'd take a look at it daily.
i can really appreciate what you're doing
Walter White is offline   Reply With Quote
Old 04-23-2017, 08:36 AM   #506
Lieferson
Lieferson's Avatar
Took her for a drive with the pups
1972 K10 350/700R/205/ Sniper EFI Daily Driver
1971 K5 on 35s Traded
1972 K5 3/4 ton PROJECT Sold
Lieferson is offline   Reply With Quote
Old 04-23-2017, 08:54 AM   #507
A1971Blazer
A1971Blazer's Avatar
I got the roll bar placed and all tacked up and ready to finish weld....
my dogs hung out in the back.
Before I could take it back out..I had to take them for a ride...hahaha
ready to do the finish welding...
1970 Chevrolet K5 Blazer.............
A1971Blazer is offline   Reply With Quote
Old 04-23-2017, 09:00 AM   #508
A1971Blazer
me too....I made some brackets and moved the diver seat back about 2 inches to make some more leg room....figured the location for the top seat belt link will be perfect if placed in the short tube that's between the two main tubes....gonna make those today and get them welded in.
Also plan on drilling some small holes to fish a wire up from the bottom to the top of the bar......I want to put in some small LED interior lights that will come on with the courtesy lights under the dash.....
Old 04-23-2017, 10:36 AM   #509
colgad
colgad's Avatar
Originally Posted by raggedjim View Post
Broda, you need to show more pics of this blazer, it's really nice. Did you buy the 67-68 trim from Mar-K? How did you install it? I have it but I'm far from paint so it will be 1 to 13 years before I get it on...
I got mine from Mar-K, it was just perfect. I measured twice or three times and drilled once. Scary but it worked out great. They make such a great product.
Dave
1967 Red, C10 Short Bed 6.0L NP440 4 speed OD
1967 Primer, C50 327 4 speed, 2 Ton Pickup conversion in progress
1972 White, Chevy Blazer 2WD 67 Dog house 350 700r4 2016 Power Tour LH
1972 Silver, Vega Wagon 4.3L WC 5 speed, Almost Finished
1972 White, Pontiac Ventura 350 350 GTO Clone, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 04-23-2017, 11:02 AM   #510
broda1
broda1's Avatar
raggedjim
Hi, I bought the truck from HUGGER*(USMC to USN! ) about a year and a half ago. Great guy, unfortunately his health wasn't the greatest so my son and I flew to Phili to purchase the truck. Most of the build is posted on this site too!
broda1 is offline   Reply With Quote
Old 04-23-2017, 11:07 AM   #511
broda1
broda1's Avatar
Nice, I don't know where I'm going to end up remounting mine. Right now, it's in the rear mid section housing stereo equipment (I cut 6.5 JL's in the sides with a remote Pioneer TV unit embedded) and I have brand new black spare console in case I want to switch back.
Old 04-23-2017, 11:11 AM   #512
raggedjim
raggedjim's Avatar
Dave
Trim looks great on these blazers. I'll measure 5 times just to be sure! Did you repaint the holes in the area you drilled?
Roger
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 04-23-2017, 11:14 AM   #513
raggedjim
raggedjim's Avatar
Originally Posted by broda1 View Post
raggedjim
I'll check the build. I'm an old navy salt myself!
Nice blazer, treat her well, Rg
Roger
'70 GMC Jimmy 2wd
Old 04-23-2017, 11:27 AM   #514
broda1
broda1's Avatar
What did you do today?
The OG gas pedal broke a few grocery store trips ago and now I'm just stepping on the "stick." I've got a new Lokar pedal and measuring for fit now. Seems like I'm going to end up mucking with it all the way to the carb.
Old 04-24-2017, 06:53 AM   #515
RustyBucket
RustyBucket's Avatar
A week ago I was in the Blazer on my way home from a car show and smelled coolant.. and noticed the temp. gauge was a little above 200*. It never runs hot. I found the radiator had split a solder seam between the core and the tank on the pass. side. I got the repaired radiator back on Fri. from the shop... $95. Radiator looks nice. I cleaned & painted a little on the rad. support yesterday and set the shroud and radiator back in. Looked at the hoses & decided to replace 'em, - they're 5+ years old. Belts are old too, but look fine. Off to the auto parts store after breakfast with a couple of other old truck geezers I hang around with, both have pretty nice '51 Chevy trucks. I'm the "youngster" at 65.
Dad always said, "Son, WISH IN ONE HAND, and ......."
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
'66 Plymouth Belvedere City of Miami cop car clone
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- shop ornament, needs resto.... SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, needs resto...SOLD!!
RustyBucket is offline   Reply With Quote
Old 04-24-2017, 10:00 AM   #516
Lieferson
Lieferson's Avatar
Scored some 15x8 slotted mags of good ole Craigslist! 50$ for all 4!!! just a little simple green goes a long way
Old 04-25-2017, 11:48 AM   #517
RustyBucket
I had a set of those wheels on a brand new '72 Cutlass. First time I replaced tires on the car the mounting machine busted about a quarter of the rim off the inside of one of 'em. Still remember the funny noise it made. 'Course the wheels were out of stock, so I rode around on the mismatched spare for about 3 weeks.... Thanks for the memories Lieferson
Old 04-25-2017, 10:09 PM   #518
stangtjk
I started a build thread.... Titled Crossbreed. The name comes from it being a combination of Jimmy, blazer and a 67-68 C10. Really it's more Jimmy than anything but the vin and title say blazer so thats what it is.
Also cut the drum brake mounting brackets off my 14 bolt. Going to weld on some brackets to accept the rear discs from the gmt800 trucks.
Old 04-27-2017, 01:19 PM   #519
BLT-NT-BOT
Got the frame already for the motor and trans.
BLT-NT-BOT is offline   Reply With Quote
Old 04-27-2017, 02:56 PM   #520
stangtjk
Frame looks good. Almost have mine finished up. Trying to get paint on everything can be a pain, have to go it each spot from 10 different angles. Seems like every time I look at mine I see a crevice somewhere that I didn't get coated.
Old 04-27-2017, 05:03 PM   #521
dirish
dirish's Avatar
A bath, to knock the winter dust off. Leaving shortly to take a herd of 7 yr. Olds to soccer which is the BeSt part of the day.
dirish is offline   Reply With Quote
Old 05-01-2017, 12:52 PM   #522
OldBalls
OldBalls's Avatar
My old high school had a car show fund raiser this weekend so I drove down and showed her off.
OldBalls is offline   Reply With Quote
Old 05-01-2017, 01:16 PM   #523
BLT-NT-BOT
What size are your wheels and tires?
Old 05-01-2017, 01:17 PM   #524
OldBalls
OldBalls's Avatar
18" wheels, 35" tires & 4" lift.
Old 05-01-2017, 01:19 PM   #525
BLT-NT-BOT
Motor is almost already to drop in.
Copyright ©2000 - 2018, vBulletin Solutions Inc.
