Old 05-04-2017, 03:32 AM   #51
ghalperin
ghalperin's Avatar
Re: 67 Plain Jane C10 396 build
The V8 crossmember positions the engine closer to the front, placing the front of the engine in similar position as the front of the I6 engine. The six cylinder engine is longer, therefore the crossmember is set towards the rear about 4 inches for the 6 cylinder. The crossmembers mount where the frame starts to rise for the front suspension and that is why the V8 crossmember is different than the I6 crossmember.
Glenn
1967 Chevy C10 - Only factory option was heater delete
1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca
1952 Mercury M3 Pickup - Barnfind from Canada
1929 Ford Model A Roadster - Soon to be AV8 for The Race Of Gentlemen
ghalperin is offline   Reply With Quote
Old 05-04-2017, 03:09 PM   #52
ghalperin
ghalperin's Avatar
I broke out the torch this morning and dimpled the frame for the steering box. I used my special tools; an old lower control arm shaft and an old ball from a lower ball joint.
I also notched the core support mount.
Next on the list of frame mods is to notch the frame for the big block. I took these patterns off a 68 C10 short coil spring frame.
The X's are the bolt holes for the engine mounts, etc...
Glenn
Old 05-04-2017, 03:11 PM   #53
ghalperin
ghalperin's Avatar
Here are my patterns drawn on the frame.
I'm ready to cut.
Glenn
Old 05-05-2017, 01:28 AM   #54
54Caddy
GM Addicted
54Caddy's Avatar
Yeah I know about the engine stands theM selves being different. I think what confused me is the picture, that's the trans crossmember correct.
..Macís Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 05-05-2017, 10:19 AM   #55
ghalperin
ghalperin's Avatar
I just purchased the mounts from The Truck and Car Shop and they are listed as the rear motor mounts for 6 cyl. and V8. That crossmember actually supports the bell housing and is V8 specific.
Glenn
Old 05-11-2017, 04:45 PM   #56
ghalperin
ghalperin's Avatar
I finally got my frame painted.
Last week I decided that I was going to spray the Chassis Saver Antique Satin Black paint instead of my original plan to brush it on. I knew it would come out much better if I sprayed it, but the reducer is banned in California. I had the paint, but had to order the reducer from out of state.
Check out all the frame holes in the shadow.
Glenn
Old 05-12-2017, 09:19 AM   #57
Jason7121
Jason7121's Avatar
Looks really good you will have a roller in no time!
Jason7121 is offline   Reply With Quote
Old 05-12-2017, 09:34 AM   #58
ABQ-C10
Junior Member
ABQ-C10's Avatar
Beautiful build you have going there! Keep up the great work! Subscribing......
1967 C-10 Stepside - The "Patina Machina" build here!
Patina Customs
ABQ-C10 is offline   Reply With Quote
Old 05-12-2017, 11:07 AM   #59
ghalperin
ghalperin's Avatar
Thanks, I really like your build as well and I'm subscribed. Our trucks are so similar, although our builds are going in different directions.
Glenn
Old 05-12-2017, 11:10 AM   #60
ghalperin
ghalperin's Avatar
Thanks, I'm going to give it another day to cure, then start putting it back together.
Glenn
Old 05-19-2017, 06:50 PM   #61
ghalperin
ghalperin's Avatar
Getting there...
Glenn
Old 05-19-2017, 09:39 PM   #62
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
This is a great build. Hard work and details trumps exotic parts in my opinion.
Kevin -
My Instagram
Tx Firefighter is offline   Reply With Quote
Old 05-20-2017, 01:35 AM   #63
ghalperin
ghalperin's Avatar
Thanks. So far the most exotic parts are the yellow zinc nuts and bolts.
I was on the fence for replacing my brake lines, but I just cleaned them up instead. Some scrubbing with a stainless pot scrubber and a satin clear coat.
Glenn
Old 05-20-2017, 06:49 AM   #64
Tx Firefighter
Were you the guy that sent his hardware to a plating shop ?
Kevin -
My Instagram
Old 05-20-2017, 11:53 AM   #65
ghalperin
ghalperin's Avatar
Yea, I'm trying to get as much done as possible, while I wait for my clear zinc plated hardware to come back. I also had them plate all the bolts and U-bolts that hold the front suspension together, so that has been a slight hold up.
But, I decided to get the 9/16 U-bolts for the lower shafts and I have a good supply of new 7/16 grade 8 flange bolts and locking flange nuts in stock, so I'll use those to bolt the front suspension crossmember in. Those bolts are black and look normal when installed.
After the cross member is tight, I can do the final installation for the front suspension and get the engine and trans in. Then, I should be able to mock up the rear suspension and start mocking up the exhaust.
I plan to get a lot done this weekend.
Glenn
Old 05-21-2017, 05:36 PM   #66
Jason7121
Jason7121's Avatar
Looking great so far. If you need exhaust pipe I have alot of 2.5" stainless pipe left over from my exhaust work.
Old 05-21-2017, 05:56 PM   #67
ghalperin
ghalperin's Avatar
Thanks for the offer, I'll let you know.
Glenn
Old 05-21-2017, 06:03 PM   #68
Jason7121
Jason7121's Avatar
Sounds good
Old 05-22-2017, 02:32 AM   #69
ghalperin
ghalperin's Avatar
Almost a roller. I got the front end all buttoned up.
Glenn
Old 05-22-2017, 09:25 AM   #70
Jason7121
Jason7121's Avatar
Looking good that's a big step to accomplish.
Old 05-23-2017, 06:35 AM   #71
webberjames95
sub'd
webberjames95 is offline   Reply With Quote
Old 05-29-2017, 11:05 PM   #72
ghalperin
ghalperin's Avatar
I had a busy week and installed a few parts.
Glenn
Old 05-30-2017, 12:00 AM   #73
88Stanger
nice work
88Stanger is offline   Reply With Quote
Old 05-30-2017, 01:06 AM   #74
ghalperin
ghalperin's Avatar
I laid out the Pypes exhaust system, but it'll require too many mods to make it work. It probably would work on a leaf spring truck with an auto trans crossmember. I'm seaking out muffler shops to get it done.
I got my engine assembled and primed the oil. It took over half an hour before oil was weaping out of every rocker arm. The machine shop warned me that it may take 45 min. and to not give up.
All my parts came back from being zinc plated, so I reassembled my rear brakes and did the final assembly for the rear suspension.
As soon as the rear suspension was installed, I mocked up the transmission and measured for my driveshaft. It was about an inch too long. I had the driveline shop replace the u-joints, shorten and balance.
I resealed the 3 speed and mounted it to the engine. Then I installed them in the frame. It went pretty easy.
I mocked up the Camaro rear sway bar. I tried to get it to go on the rear end, but in the end I like it better on the trailing arms. It doesn't interfere with anything where I have it sitting. So far I haven't drilled any holes. What do you guys think of the location?
I also cleaned the firewall and set the cab on the frame. It's starting to look like a truck
Glenn
Old 05-30-2017, 12:36 PM   #75
NewType72
NewType72's Avatar
Big time progress! Just installed that POL trailing arm crossmember myself what a PITA that was with the cab on haha don't even get me started in what it took to squeeze the frame rails together as well.. nitemare. Great work, loved the power steering boxframe mod. Subbed for sure
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
