Old 05-03-2017, 09:55 PM   #1
chris mc bride
chris mc bride's Avatar
lowering c 10 with coil springs
1969 Panel .How much can I lower it with just cutting coil springs? Not looking for dropping much.Maybe 2 to 3" max and not dead set on that much. Doing it on cheap for now. RACE car not finished and it barely comes in second to breathing.LMAO All money is allotted to it.
Only the stupid know too much to learn something new.
chris mc bride is offline   Reply With Quote
Old 05-04-2017, 06:56 AM   #2
PGSigns
PGSigns's Avatar
Re: lowering c 10 with coil springa
You can cut half a wrap off the front and get it down a couple of inches. Problem is you cant cut the back they way they are wound. The only drop springs for suburban/panel are 4"
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-04-2017, 07:56 AM   #3
hewittca
hewittca's Avatar
As PGSigns said, you can easily cut the front springs. I think the common drop is 2" per coil and you would be really pushing it to cut up to 2 coils, which would give you 4". I have 2 coils cut on mine and they ride fairly well (for an old truck) but you do have to cut out the bump stops for a 4" spring drop, so it's not for everyone. In the rear, your best bet is to just spend the 80 bucks on 2" drop block and longer U-bolts and you are done without messing with the springs.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 05-04-2017, 10:54 AM   #4
SCOTI
SCOTI's Avatar
Cut between 1/2-1 coil in front for a mild drop. For the rear, I would opt for a small drop spring & 1-1.5" lowering blocks. Lowering blocks in truck-arm suspensions allow drop w/o affecting shock travel (which is good). 2" drop spring & lowering block combo should keep things level vs the front drop.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-15-2017, 10:19 AM   #5
blindman78537
I am buying a Beltech 3 inch drop front spindle and would like to know what size rear spring would I need to level the truck out?
blindman78537 is offline   Reply With Quote
Old 05-15-2017, 11:43 AM   #6
SCOTI
SCOTI's Avatar
Typical front to rear rake is a 2" difference. Measure what you have now to know for sure.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-30-2017, 09:12 PM   #7
trailcarnage
trailcarnage's Avatar
Not to hijack but I have a question about cutting coils. I have a set of -2" front and -4" rear coils which I expect to set the rig level. I would like to maintain a 2" rake so my question is can I just cut a wrap off of the front coils? The reason I ask is because I haven't heard of anybody cutting lowered coils so I am wondering what the result would be. -4" up front?
trailcarnage is offline   Reply With Quote
Old 05-30-2017, 10:59 PM   #8
SCOTI
SCOTI's Avatar
The potential problem is the spring becoming so short it can (& will) become unseated when the suspension extends. Not a good thing to have them moving around....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-31-2017, 06:53 AM   #9
trailcarnage
That's a good thought that I hadn't considered. I had assumed that the unsprung length of the lowering coils would be the same and use a different rate to lower.
Old 05-31-2017, 09:20 AM   #10
SCOTI
SCOTI's Avatar
Typically, they're physically shorter.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-01-2017, 08:27 PM   #11
trailcarnage
I am uber disappointed! I purchased a pair of front lowering springs only to find that they were either cut OE coils or the aftermarket manufacturer copied a cut coil. WTH? I could have done this myself...
Old 06-13-2017, 02:03 PM   #12
Tdavis2005
Re: lowering c 10 with coil springs
What were you hoping would be different about the lowered coils?
Tdavis2005 is offline   Reply With Quote
Old 06-13-2017, 03:47 PM   #13
trailcarnage
I was expecting that they would have had a different wire size to change the rate and a closed tail. I could have literally cut a coil from the stock ones and saved the purchase.
Old 06-26-2017, 06:05 PM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
You are correct. And it would ride better as well
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-04-2017, 07:07 PM   #15
Backpayne
Where did you buy them ftom?
Backpayne is offline   Reply With Quote
