Old 12-30-2016, 04:02 PM   #26
my56chevytruck
my56chevytruck's Avatar
Re: wheels & tires for 55, 56, 57, 58, 59 truck
Nice ride Blain. Very nice!!!
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 12-30-2016, 07:53 PM   #27
bosco
bosco's Avatar
Originally Posted by 57chevyman View Post
slot mags / BFG tires
Frank, may I ask what size are your BFGs? Thx
bosco is offline   Reply With Quote
Old 12-31-2016, 10:37 PM   #28
roger55
roger55's Avatar
16"X7" Wheel Vintques Smoothies and tires are Bridgestone Dueler Alenza Plus in 235/70R-16.
Painted with Summit Wimbledon White in single-stage:
roger55 is offline   Reply With Quote
Old 01-01-2017, 12:10 AM   #29
1958Warrior
1958Warrior's Avatar
easy peazy , search box upper right these and many more there: (Your welcome)
http://www.67-72chevytrucks.com/vboa...me+your+wheels
1958Warrior is offline   Reply With Quote
Old 01-01-2017, 06:23 PM   #30
57chevyman
57chevyman's Avatar
235 70 r15
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
Old 01-01-2017, 06:50 PM   #31
bosco
bosco's Avatar
235 70 r15
Thanks. Looking at the same size. Appreciated.
Old 06-01-2017, 02:12 AM   #32
nail pounder
nail pounder's Avatar
I have a 58 fleetside (32), saw some wheels I like on Craigslist but wondering if they clear the rear wheel well & front calipers. Tape measure says yes. Wheel size are 15 x 7 front & 15 x 8.5 rear, 4 ⅛" backspacing (wheel mount surface to inside edge of rim) . I need to pull a front tire off and make sure it will clear my calipers, my stock steelies are pretty close. Looks like it will just miss my e-brake cables. Anyone running this set up?
nail pounder is offline   Reply With Quote
Old 06-01-2017, 02:16 AM   #33
nail pounder
Aluminum slotted mags or kidney beans, not sure what everyone calls 'em.
Old 06-01-2017, 02:26 AM   #34
nail pounder
Here's an example. Also, I'm planning to do 2" drop shackles and remove a couple leafs out back, and Sid's drop axel up front if that helps
Old 06-01-2017, 07:12 AM   #35
1project2many
Originally Posted by tsmith8 View Post
Crager Dulux 15" rims with the chrome Bullet centre cap and Bullet Chrome lug nuts. Coker Classic 235/75R15 tires all around.
How are the tires? It seems like the internet didn't think they were good quality a few years back.
1project2many is offline   Reply With Quote
Old 06-01-2017, 12:09 PM   #36
_Ogre
_Ogre's Avatar
I have a 58 fleetside (32),..... Anyone running this set up?
might not be able to remove the rears if you have lowered your truck at all
i run 8x15 w/ 4 backspace i jack up the frame with axle hanging and have to wiggle the tire out from between the fender and hub
a lot depends on rearend width, i run a gen3 camaro 62'' wide
shop air compressor timer
Old 06-01-2017, 12:17 PM   #37
nail pounder
Good point, might be pretty tight. I have stock rear end, not sure of width but I can look it up. Do you know stock width off the top of your head?
Old 06-07-2017, 05:01 PM   #38
BobTheTrucker
BobTheTrucker's Avatar
Old School!
1955 Chevy truck ( SOLD )
1955 3/4 ton parts truck.
1957 Chevy truck
1995 S10 Chevy truck
1999 ext cab Chevy truck, w/1998 body style. (for parts)
1964 Honda 90
2003 Ultra Classic Harley
BobTheTrucker is offline   Reply With Quote
Old 06-07-2017, 05:56 PM   #39
akdg87
akdg87's Avatar
just sold the 20" and went a bit retro. Wheel vintique series 37 with 1953 centercaps. 15x6 on front with 215/70R15 and 15x8 on rear with 275/60r15
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 06-07-2017, 07:56 PM   #40
capnduane
capnduane's Avatar
Posted pics on here before, but always grab a chance to show off my truck. Wheels are American Outlaw II, 15x7 front and 15x10 rear. Tires are 185x65 on front and 275x75 on rear. My idea was go give a '60s/'70s hotrod look with bigs and littles. Also to make steering easier and get a higher gear ratio, as the truck has stock 3:90 rear end. And a nice rake results also.
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder"
capnduane is offline   Reply With Quote
Old 06-14-2017, 04:50 PM   #41
butchp
Coys 18 fronts 20 rears
butchp is offline   Reply With Quote
Old 06-14-2017, 08:29 PM   #42
FAKKY
subscribed ...... have to get some soon too
FAKKY is offline   Reply With Quote
Old 06-14-2017, 10:10 PM   #43
mr48chev
mr48chev's Avatar
My 2 cents and I know my opinion on wheels isn't worth much on this board according to some says that what you have now looks just as good as anything the others showed.
Choosing the "right" wheels and tires for a rig is probably the most damned if I do damned if I don't think a guy can do on his truck. The wheels shouldn't dominate the truck to make it look like a wheel add nor should they look out of place like some that belong on a Jacked 4x4 on a nearly stock truck because that is what the tire store had in stock that fit the day the truck owner went down to by new wheels. I'd say for me a part of that comes from the local tire stores more often than not have exceedingly poor taste when it comes to selling a customer new wheels for his rig or the local customers have exceedingly poor taste in wheels for the most part. The gaudier and uglier the wheel the more they like it around here.
My ongoing truck projects:
Old 06-20-2017, 10:00 PM   #44
1955 CAMEO
Looking for advise: Recently purchased wheel vintiques 15 inch smoothies for my 55, with chrome center caps and trim rings. After painting and mounting tires i put them back on the truck. The center caps fit fine on the rear wheels but not on the front due to the hub/axle protruding out to far.supplier offered a deeper, bullet style cap - they look like something off of a roman chariot from ben hur.
looking for deeper center caps ?
Wheel spacers may work?
Looking for advise
1955 CAMEO is offline   Reply With Quote
Old 06-20-2017, 10:20 PM   #45
Dan in Pasadena
Dan in Pasadena's Avatar
Spacers may allow the hubcaps to clear the dust covers on the spindles but will they cause the tires to rub the wheel wells? How much space do you need. The dust caps alone MIGHT be adding 1/4"
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 06-20-2017, 10:35 PM   #46
1955 CAMEO
Ordered 1/4" spacers, if that's not enough I will try removing dust covers.
Old 06-20-2017, 11:10 PM   #47
62lwbc10
Wheelsmith smoothie wheels powder coated oyster white 235 75 15
62lwbc10 is offline   Reply With Quote
Old 06-21-2017, 01:03 AM   #48
Dan in Pasadena
Outstanding 62lwbc10. Love yours.
Old 06-21-2017, 08:53 AM   #49
my56chevytruck
I too like your wheel set up 62lwbc10. I've been trying to detemine what I want to use.
1955cameo, try the wheel spacers and or dust covers, but as Dan said, you may rub your fender lip. Of course you could bend that under to clear. It's easy to do if that's your choice.
1940 Ford Dlx Coupe
1969 Mach1
Old 06-21-2017, 11:11 AM   #50
62lwbc10
Thanks guys I highly recommend Wheelsmith. They manufacture the wheels in house and the quality is very high. I sent th m my stock caps and they modified them (via tig welding) so I could use them with their wheels, which was important to me. The powder coating outfit they use is really awesome too, the quality of the powdercoat is very high.
