Old 06-16-2017, 11:04 AM   #1
mickeykreg
mickeykreg's Avatar
rust repair on the '77...here goes nothin
Wow, what a commitment! Cutting into the body on this truck is intimidating to say the least. I've done some messing around with my mig, but never anything this challenging. What a schooling!
When I've been researching this I've not found very much info about what lies under the roof skin, like where braces are and how things are spot welded together. I went to the junkyard and cut the roof out of an 84 blazer to use part of it for patch panels and to cut it up to see how it's put together.
So far my to do list includes the windshield frame above the glass, floors, bedsides, and tailpan. I sold the top and tailgate cause I don't have room to store that stuff and cause I want to use a soft top and truck tailgate instead. Hope I don't regret that later.
In Baja this past winter whenever I'd get on a rough road little bits of rust would rattle out of the headliner and fall in my lap. I was expecting it to suck pretty bad when I took things apart, but it wasn't as bad as I thought. Here's some pics from first stage.
Rust above windshield frame.
2017-06-14_08-11-52 by Mick, on Flickr
Decided I needed a dome and map light so while the roof was apart I placed the wiring and made a bracket for a light out of a '98 Tahoe. Backseat light actually cause it's a bit smaller.
While the top skin was cut out I used some of this stuff.
http://www.eastwood.com/eastwood-int...z-aerosol.html
to spray around inside between the layers and down the A pillars. Also used to hit the inside of the pinch weld after things were put back together. Not sure it'll make a big difference, but makes me feel better.
A bit later I'll post some pics of the cut up junkyard roof so you can get a better idea of what's going on under the top skin.
'80 SRW C35 - 355/700R4/4:11/2.5-3/DD
'77 Cheyenne K5 - Roller cam 355/NV4500/205/4:88's/35's/DD
http://67-72chevytrucks.com/vboard/s...d.php?t=740291
mickeykreg is offline   Reply With Quote
Old 06-16-2017, 02:41 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: rust repair on the '77...here goes nothin
Nice work.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 06-18-2017, 09:54 PM   #3
mickeykreg
mickeykreg's Avatar
sort of done with the roof for now, just need to do the filler and primer
junkyard donor roof
A pillar cut away looking down from the roof
looking up the A pillar from below
B pillar cut away
If you want more pics of how the roof is put together let me know, still have it in the driveway for now.
Old 06-18-2017, 10:01 PM   #4
mickeykreg
mickeykreg's Avatar
Next up are the bed rails.
the junkyard donor bed rail with spot welds drilled out and separated.
the patch
the partial fix, just need some epoxy primer and filler and finish
Old 06-19-2017, 09:51 AM   #5
blazer2007
what kinda clecos are those
blazer2007 is offline   Reply With Quote
Old 06-19-2017, 10:21 AM   #6
mickeykreg
mickeykreg's Avatar
They're just a set of stitch weld magnets from Eastwood. On sale for like $5 or something. I've been using them alot, not using the butt weld clamps much though.
Old 06-27-2017, 02:30 AM   #7
68Timber
68Timber's Avatar
Wish you weren't two days drive away, I could use the back half of the donor cab. My 79 has rot where the top butts against the half cab. KUTGW...
John
74 Honda Z50 build
Old 06-27-2017, 05:36 PM   #8
frenchy51
frenchy51's Avatar
Good job! I just got done doing a couple of patches for my "74's door strikers but nothing like what you're doing. Very satisfying to cure cancer though!!
1972 Highlander PAC B 400BB-SOLD
1974 K5 Blazer-6.0 swap
1974 C20 Long Bed 454
1977 GMC HeavyHalf
several adopted orphans
frenchy51 is offline   Reply With Quote
Old 06-27-2017, 10:51 PM   #9
amberkalvin
amberkalvin's Avatar
Man I wish I had tour patience. Looking good!
1984 SWB C10 (http://67-72chevytrucks.com/vboard/s...d.php?t=687521)
1976 K5 super rusty fitech truck(http://67-72chevytrucks.com/vboard/s...d.php?t=740582)
The one I'm keeping forever (Fingers crossed!)
1989 Suburban 2500 L83 6L80
(https://67-72chevytrucks.com/vboard/...d.php?t=818822)
amberkalvin is offline   Reply With Quote
Old 06-28-2017, 10:17 PM   #10
mickeykreg
mickeykreg's Avatar
I think I'm done with it so if you can figure out some transportation you can have it for nothing.
Old 06-29-2017, 02:18 AM   #11
68Timber
68Timber's Avatar
I appreciate that. Greyhound might ship it, but it'd cost more than a parts truck to send it that far. I'm sure there's one close to me, but I haven't put that repair on my calendar yet so I haven't shopped for that piece yet. It's just ironic to see it here. BTW, I've noticed your white truck in the background of a few pics, cool to see you still have it.
John
74 Honda Z50 build
Old 06-29-2017, 07:26 PM   #12
phillipm
Looks like you've taken your time and done a very good job with your repairs. Nice work.
Old 11-06-2017, 03:06 PM   #13
mickeykreg
mickeykreg's Avatar
Thought I'd throw out an update, as I've had a bit of a eventful summer. Kind of back on track now.
My white truck has had a rod bearing making noise for a while now. Just as I was getting ready to head out on a road trip in July it started to really make a racket.
So I had to swipe the motor out of the blazer.
...and jabb it in the white guy
Then rolled out on a 2500 mile road trip into Idaho, Montana, and Washington for some fishing with my kid.
North Fork Clearwater, Idaho
Coming down into Superior, Montana
Montana/Idaho stateline we got woke up by a bear huffing around at 3am.
While on the road in Spokane I stopped into a junkyard that had a seat sale going on so I picked up these '99 Tahoe seats for $22 for the pair.
Then took a big hit getting them re-skinned in buckskin leather. Seats have always been high on my priority list so these should work out.
Since the motor was out of the blazer it was time to bite more bullet. 400hp Roller cam vortec 355 from West Coast Engines online. Not sure what I'm going to do with this other than break something. Maybe turn the white guy into a muscle truck later, but that'll require a 502BBC.
I was thinking since the motor was out and the floor was all cut up that now would be a good time for a NV4500.
Bummer I can't drive it for a while yet. Hope to have it ready for another Baja trip by this time next year. I think I'm done with mechanical for now. Back to body work next.
Old 11-06-2017, 03:26 PM   #14
phillipm
Seats turned out great! Anyone who's paid to redo seats realizes that the TMI stuff is actually a good deal! Nice work as always.
Old 11-06-2017, 05:28 PM   #15
mickeykreg
mickeykreg's Avatar
I used Katskin who cuts material on bulk then works with local shops to do the install. They had a good selection of colors and styles of leather. I paid $600 each, which I didn't think was too bad.
Sorry, what is TMI?
Old 11-06-2017, 06:11 PM   #16
mickeykreg
mickeykreg's Avatar
Getting into the passenger B pillar, oh jeez:
The neighbor down the street brought over some peppers. Surprised he'll still talk to me considering all the noise I've been making.
Old 11-10-2017, 11:30 AM   #17
mickeykreg
mickeykreg's Avatar
Picking up where I left off with bed rails in post 4.
Old 11-10-2017, 11:38 AM   #18
mickeykreg
mickeykreg's Avatar
Finishing repair above windshield in post 3.
Old 11-10-2017, 12:17 PM   #19
phillipm
Man you're doing a great job! Keep it up.
TMI is an interior shop. http://www.tmiproducts.com/
Old 11-10-2017, 12:27 PM   #20
mickeykreg
mickeykreg's Avatar
I guess one good thing about this taking forever is I've got some time to decide on interior. Thanks for the link.
Next on the list is to build a roll bar, which I hope will give the cab some added structure before I cut up the floor.
JD Squared model 3 bender
Old 11-10-2017, 12:44 PM   #21
raggedjim
raggedjim's Avatar
Nice work, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 11-10-2017, 12:51 PM   #22
phillipm
Man that must be one beefy table! I've got my JD2 bolted to the concrete and it takes some muscle to get it done! Maybe yours is air/hydraulic?
Old 11-10-2017, 12:58 PM   #23
mickeykreg
mickeykreg's Avatar
Yeah, I'm not sure if it's going to work. I used it to bent a couple cheaters the other day and it held up ok. Bench is made out of 2x6's and treated 4x4's screwed to the wall. I like that when I run out of room in a bend I can pivot the vise and keep going. Not much room in my garage.
Old 11-15-2017, 10:54 AM   #24
mickeykreg
mickeykreg's Avatar
Roll bar done. I figure this is a good backup to the work I did in the B-pillars.
Also wanted to give a thumbs up to this guy on YouTube for the good tutorial on tube notching without a tube notcher.
Old 11-16-2017, 02:38 AM   #25
68Timber
68Timber's Avatar
Sweet sweet sweet.
John
74 Honda Z50 build
