#5476 |
Re: What did you do to your truck today? Chapter II
Delete as duplicate.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
#5477 | |
![]() Join Date: Jul 2016
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
#5478 | |
#5479 | |
#5480 | |
I installed my Marchal Amplilux headlights today.
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod Last edited by ghalperin; 06-20-2017 at 01:46 AM. |
#5481 |
Like I said about a Woman (she was no lady) I used to date : VERY nice headlamps ! .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#5482 |
Re: French (Marchall) Headlamps
Thanks, I can't wait for it to get dark to see how they work. The original headlights were like old Rayovac flashlights.
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
#5483 |
![]() Join Date: Jul 2015
Hey I know someone who resembles those old Rayovacs.
Same tool isnt that sharp! |
#5484 |
They sure look bright in post # 5495 ! .
Yellow headlamps give far less glare and further out visibility but they're quasi illegal in Cali. ~ expect some tickets .
#5485 |
In the photo they were bright, but not so much on the road. I'll keep my fingers crossed for the coppers. I've got the Cibie H4s ready just in case.
#5486 |
Cool beans .
I loved my yellow H4 headlamps but got tired of tickets and so removed them . My then 18 year old Son put them in his Hot Rod and drove like a maniac and never got one ticket . Go figure .
#5487 |
Starting to put together the puzzle
#5488 |
#5489 |
Any Pictures ?
1972 Chevy C10 Custom Deluxe Highlander 1972 Chevy C10 Custom Deluxe Medium Green |
#5490 |
![]() Join Date: Feb 2009
Knocked 45 years of grease off my 72 driver truck, and snugged up some gaskets. Dirty job, but I refuse to work under a grease pit, which was approaching 3/8" an inch in places. Greased everything up to the rear drive shaft, where I suppose either the U-joints or zerk fittings are wrong. It's not possible to put a grease gun on the zerk fittings. Can't say how to pull a drive shaft yet, but I will at some point.
The driver is having intermittent starting issues, so as part of a revamp, I tried to install a newer starter, which came off my restoration project. Both 402 trucks, so no problem right? Nope. While it may have worked, the hole in the flex cover on my 72 is taller. It doesn't appear cut, perhaps a replacement? Seems all flex covers would be the same, for BBC trucks anyway. The starter that was on there doesn't appear to check out for a 72 C20 either. All I know is it's a good Delco Remy 1109065 and fit. For what it's worth, the replacements call for the same starter, 71 C10 402 or 72 C20 402.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 06-21-2017 at 01:03 AM. |
#5491 |
Tony, I think your story exemplifies why I haven't gotten into owning an older vehicle before. My previous trucks from this era were someone else's headache & I was naive.
#5492 | |
For REALLY tight fits, you can use a needle attachment. Press it into the zerk fitting and it'll work. Might need a second set of hands.
#5493 |
Over the weekend, did the full ignition tune-up (points/condenser/cap/rotor/wires/plugs) and even replaced the coil.
Was driving to work yesterday morning, and about a block away from the office, the engine started running a bit rough, like I was getting a misfire. Made it to the office then back home. Frigging #4 spark plug wire came loose from the distributor cap.
#5494 |
Finished up the bumper. Have a 70 C10, wanted to do fog lights. Found a 72 bumper at a swap meet and went to work..... Added a lower valance, made some brackets for the led's and lenses. Then polished and cleared. The LED's have the option to be clear or amber to complete the "Stock" look.
#5495 |
I added a braided power steering hose
#5496 |
I stripped my roof back to the original white paint.
Dan. Drivetrain parts and accessories. 68 medium green shortbed fleetside |
#5497 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#5498 |
I didn't even know anyone was making those. And now that I know they exist, I want one.
#5499 |
I have a NOS Smash-Hit grill guard, so I installed the outer towel bar to see how I'd like it. I snapped the photo and took it off. I think the grill guard would look better with fog and driving lights, although I think the slant nose looks best with nothing added.
#5500 |
