Old 11-29-2014, 12:27 AM   #26
2tontruck
Re: Will 1987-1991 blazer fuel tank work?
Does anybody have the part number of the sending unit? I plan on putting one of these in a Suburban that I am doing a LS swap on. I would guess that the sending unit is the standard 0-90ohm?
2tontruck is offline   Reply With Quote
Old 12-29-2014, 03:12 PM   #27
N.T.Q
how can one find out which sending unit you need ? I know there is 2 inch difference from 25 to 31 gallon tank, do you measure from the pan or from bottom of the inside
N.T.Q is offline   Reply With Quote
Old 01-19-2015, 11:13 PM   #28
XJDG72X
Originally Posted by jamesjones View Post
I'm using an '87 tank and sending unit in my '72. I put a Walbro 400 in it though.
I haven't had a chance to mount the tank yet but I looks like it should fit.
I am building a 72 K20 4x4 with lq4 4l80e and was wondering if this set up would work?
Thanks!
XJDG72X is offline   Reply With Quote
Old 02-07-2015, 10:20 AM   #29
chevy-fun
chevy-fun's Avatar
good info
chevy-fun is offline   Reply With Quote
Old 10-13-2015, 10:28 AM   #30
mcmlxix
Collector of Projects
mcmlxix's Avatar
Bringing this back up for information on the connections to the in tank pump. I don't want to run AN fittings. Looking for either a barbed fitting for EFI rubber hose or possible the newer style nylon fuel line.
Rich
1972 K5 Blazer CST Click HERE
Old 10-15-2015, 09:32 PM   #31
jessemthompson
I installed this tank in my 72 with AN Fittings. I bought the sending unit from rock auto. They had sending units that used barbed fittings as well.
jessemthompson is offline   Reply With Quote
Old 10-15-2015, 09:37 PM   #32
jessemthompson
Originally Posted by dkauffman05 View Post
I would like to see some picture of how much these tanks hang below the truck.
Old 10-16-2015, 12:02 AM   #33
GMC-YA68
GMC-YA68's Avatar
Dorman 800-078 feed
dorman 800-079 return
Those look like they would work.
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 04-10-2017, 10:15 PM   #34
findog78
Originally Posted by 1SICMAX View Post
Thanks for the answer. I found a replacement fuel sending unit with threaded fittings.
What sending unit did you find to get the threaded fittings?
findog78 is offline   Reply With Quote
Old 06-23-2017, 02:19 PM   #35
stangtjk
Yes it can be turned. The slanted edge on the bottom will just be facing the front instead of the back. I plan on doing it that way. I should be installing mine later this week. I'll try and post some pics of the fitment.
For anyone else looking into this the 92-96 31 gallon tank appears to be identical except the filler neck is on the opposite side but doesn't have the 90 bend on it.
stangtjk is offline   Reply With Quote
Old 07-03-2017, 11:47 PM   #36
lowrodderchev
lowrodderchev's Avatar
for those who have used the 87 tank what fuel gauge did you use? i ran the 87 tank with the 87 sender and my 75 fuel gauge goes past fuel everything is brand new, any suggestions?
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 07-08-2017, 01:36 AM   #37
Blazerowner
Blazerowner's Avatar
It's likely the ohm on the sender. Here's some good reading.
http://www.chevyclassicsclub.com/the...ry-1965-newer/
Kirk
72 Blazer CST 4wd highlander
66 Nova
Blazerowner is offline   Reply With Quote
Old 03-02-2018, 12:51 PM   #38
K5 MAX
K5 MAX's Avatar
Yeah I'm thinking about this tank as well. https://www.1aauto.com/fuel-tank/i/1...yABEgLLPPD_BwE
Filler neck hole is on the correct side for the first gen k5. I need a tank in mine and would like to go ahead and get a bigger one that would work for a further LS swap but could also work for now with my stock 72 motor and fuel pump. Anyone know if I can buy the stock 96 fuel pump/sending unit then pull the fuel pump out and replace it with a piece of fuel line. Rely on the 72 fuel pump then, to suck from the new tank just like it does with the older set up. That way I could go back to the in the tank pump when I do a LS swap later?
1972 K5 Blazer
350/350/PS/PB
From GA but live in Panama City, FL
K5 MAX is offline   Reply With Quote
Old 03-04-2018, 01:41 PM   #39
findog78
What size is the filler neck on this tank?
Old 03-04-2018, 03:00 PM   #40
K5 MAX
K5 MAX's Avatar
Not sure, the plan would be to have a filler neck welded on to fit the first gen if needed if the stock tahoe one wouldn’t work. Maybe pull a filler tube from one from a junkyard to save some $. I’ll buy a new tank though
1972 K5 Blazer
350/350/PS/PB
Old 03-08-2018, 11:50 PM   #41
K5 MAX
K5 MAX's Avatar
After doing some measuring the 92-96 tank won’t fit. It’s too wide to fit between the frame rails. I measure the width between mine at 27 1/4”, the stock tank and the 87-91 tanks are a little wider than this but only with the flanges. Guess it’s back to the 87-91 for me and having the filler next swapped to the other side on the tank or turning it around.
1972 K5 Blazer
350/350/PS/PB
Old 03-09-2018, 12:43 AM   #42
krue
Designated A-hole!
krue's Avatar
Does this help?
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 03-09-2018, 08:33 AM   #43
1 3/4" looks to me. You measure the diameter below the ridge though, least I do with a caliper
Old 11-16-2018, 09:38 PM   #44
Coursey
Coursey's Avatar
ttt
Coursey is offline   Reply With Quote
