Junior Member
![]() Join Date: Apr 2015
6 Qt oil pan
I've done a couple searches and can't find an answer to my question. Will a 6 qt oil pan on a small block fit in a 67 c-20? And is there really that much benefit to have a 6 qt pan?
I bought a mildly built 350, it has a 6qt oil pan on it. what I should have asked will it clear the cross member, or should I use the oil pan off the 327 that was originally in it? Last edited by inline67c20; 07-04-2017 at 05:03 PM. Reason: clarefication |
Six in a row makes it go...
![]() Join Date: Mar 2009
Re: 6 Qt oil pan
Not sure what the benefit might be other than cooling. Small blocks have a pretty good oil system. I don't think much of Fram filters these days, but the PH373 will screw on and adds about a quart. I think the Wix equivalent is 51794.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
Re: 6 Qt oil pan
Will it fit, really depends on which brand you use. I'd see no benefit to just increasing the oil capacity of a street driven vehicle. It'll just run up your oil change tab by about 3-5 bucks for the extra quart. If heavy hauling or towing is in the trucks future, an oil cooler would be a more practical investment.
Re: 6 Qt oil pan
If you are referring to a stock 5 qt pan + 1 qt filter vs. a 4 qt pan + 1 qt filter then yes it will fit.
Re: 6 Qt oil pan
Sorry if I confused the thread with the oil filter bit.
OP is asking about a 6 quart pan only. I'd put the 5 quart pan on the mild 350 and call it a day.
Junior Member
Re: 6 Qt oil pan
Thanks for the info, I will take the oil pan off the 327 and use it.
Re: 6 Qt oil pan
A milodon 30401 pan will fit
Fuzzy |
