Old 07-22-2017, 02:51 PM   #426
MMcMasters
MMcMasters's Avatar
Re: 1970 Med Olive Project
Originally Posted by cericd View Post
If you are using your iPhone or other Apple device as your camera, the following link will explain the issue.
http://rotatemailer.com/sideways-pictures.html
Thank you very much for the link. That explains my problem exactly. I will take pics the right way from now on.
My question is I have 100 plus pictures of my build process in my phone that were taken the "wrong" way. Will that camera + app fix my existing pictures that I took the wrong way? Or is there a way to rotate the existing bad photos once I have downloaded them to my reply screen?
Thanks everyone.
Oh yeah one more photobucket complaint. I tried for an hour to download pictures from my account to my computer and photobucket kept giving me an error that "something occurred and download failed".
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 07-22-2017, 03:35 PM   #427
Rufas
Rufas's Avatar
Thanks everyone.
Don't feel like the Lone Ranger. I tried downloading today from PhotoBucket and got the same message.
For some reason I can still use the link for photo and I have the free account. I suspect PhotoBucket will soon find out about it and take it away.
1970 GMC 2500
700R Trans
RideTech 4 link rear suspension - Air Bagged on all four corners
350 SBC 300hp
Weiand Supercharger
FiTech EFI
Rufas is offline   Reply With Quote
Old 07-22-2017, 04:26 PM   #428
GR8-68
GR8-68's Avatar
Okay yes, holding your phone with the volume button down makes your photos correct, I take all pics that way now, just formed a habit. I use snapseed if I need to edit or post a pic I took the old way with phone upright. You do not even have to do an edit, just load it to snapseed and post it from there. Not sure if it is available on I-phone or not but I believe it is
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 07-22-2017, 07:03 PM   #429
cericd
cericd's Avatar
Hey Mike, I don't know anything about the app mentioned on that page I linked too, I just use that link because it explains the source of the issue so well. I use my PC to correct the rotation issues so I can't tell you how to correct the problem without transferring the pics from your phone first (if that's where they currently are.) Do you use a PC and if so, what version of Windows do you use i.e. 7, 8, 10 etc.?
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 07-22-2017, 07:19 PM   #430
cericd
cericd's Avatar
This seems to be a good solution if you have lots of pics to correct.
https://www.howtogeek.com/254830/why...ectly-rotated/
Direct link to the software: https://savolai.net/software/JPEG-EXIF_autorotate
The way I do it is basically one file at a time since I learned about holding the phone a certain way early on in my iPhone photo taking experience.
If I had a lot to do I would look into the software I listed above.
Chris
Old 08-03-2017, 07:11 PM   #431
MMcMasters
MMcMasters's Avatar
I pulled a vacuum on the cooling system tonight to check for leaks and there were none. I pulled 26hg and it didn't budge after 30 minutes. Hooked up my siphon and used the vacuum to pull the coolant in and give me an air bubble free cooling system.
The truck is 98% wired. The only things left are the rear tail lights, back up lights and license plate light. They will get wired when the bed sides go on. I finished calibrating the vintage air controls, calibrated the Dakota Digital gauges and topped off all the fluids. Tomorrow night I'm going over everything with a fine tooth comb and Saturday morning this turd is getting fired for the first time.
Mike
Old 08-03-2017, 07:14 PM   #432
Jason7121
Jason7121's Avatar
That's great news Mike I'm sure it will fire right up.
Jason7121 is offline   Reply With Quote
Old 08-03-2017, 07:24 PM   #433
MMcMasters
MMcMasters's Avatar
Thanks Jason. I'm confident it will. It seems like forever since I have been on here but I have been working. I have worked so hard to keep the wiring clean and hidden and it has taken me longer then it should have. I added so many systems that these old trucks never had and there isn't much room to begin with. I'm very happy with the end result.
I have been building engines for 30 years and I still get nervous for the first fire up and I don't know why I'm pretty stoked for Saturday. I'm coming up on a year since I started this build, it's time to get it on the road. Wish me luck fellas, I'll have my son take a video of the first light off
Mike
Old 08-03-2017, 07:28 PM   #434
projectking
projectking's Avatar
That's awesome Mike! How'd the bed "shrinkage" turn out?
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 08-03-2017, 07:30 PM   #435
MMcMasters
MMcMasters's Avatar
They turned out nice. I will try to post some pics. Sometimes they post sideways, I apologize in advance if they do.
Mike
Old 08-03-2017, 07:35 PM   #436
MMcMasters
MMcMasters's Avatar
Here are a few pics
Mike
Old 08-03-2017, 07:41 PM   #437
MMcMasters
MMcMasters's Avatar
Here are the gauges lit up.
Mike
Old 08-03-2017, 07:45 PM   #438
MMcMasters
MMcMasters's Avatar
When I open the hood I did not want to see any wiring. I ran all of the front light harness, fan wiring and the trinary switch on the outside of the core support. It disappears with the grill in place. I know it's there and it's still hard to see when everything is in place.
Mike
Old 08-03-2017, 07:51 PM   #439
MMcMasters
MMcMasters's Avatar
Things were a little busier in the back. Main power and grounds, American Autowire junctions for grounds, dual redundant relays for my fuel pump, fuel pump signal wires and fuel gauge wires. I also went a little overboard with chassis, body and engine grounds. (If there is such a thing) this all will disappear when the bed floor is installed.
Mike
Old 08-03-2017, 07:54 PM   #440
MMcMasters
MMcMasters's Avatar
And this is my view tonight as I do a front to back nut/bolt check and give everything a once over. Sorry for all of the pictures at once.
Mike
Old 08-03-2017, 08:20 PM   #441
builtbyKane
builtbyKane's Avatar
Moving right along
builtbyKane is offline   Reply With Quote
Old 08-03-2017, 08:33 PM   #442
projectking
Wow, he did a great job on the bedsides!
67 Chevy C10 LWB
90 Mustang Gt
Old 08-03-2017, 09:19 PM   #443
MMcMasters
MMcMasters's Avatar
Kyle is stud
Mike
Old 08-03-2017, 09:20 PM   #444
MMcMasters
MMcMasters's Avatar
Originally Posted by builtbyKane View Post
Moving right along
It's getting there
Mike
Old 08-03-2017, 10:34 PM   #445
sprint_9
sprint_9's Avatar
Looks great, I always like seeing detail pics of the wiring, wiring is something I have always enjoyed doing and making clean.
That pic on the hoist really looks good too.
sprint_9 is offline   Reply With Quote
Old 08-04-2017, 02:41 AM   #446
Jason7121
Jason7121's Avatar
I know what you mean about finding room for the wiring. I added cruise, ac, power windows, power locks , stereo system, and push button start with alarm system. So many extra wires under the dash to tuck up haha.
Old 08-04-2017, 06:15 AM   #447
72 tigger
72 tigger's Avatar
Coming right along- looking forward to the video!
72 tigger is offline   Reply With Quote
Old 08-04-2017, 08:23 AM   #448
MMcMasters
MMcMasters's Avatar
Thank you !
Exactly! 10 pounds of **** in a 5 pound bucket
Tomorrow is the day
Mike
Old 08-04-2017, 03:01 PM   #449
knomadd
knomadd's Avatar
Never apologize for the quantity of pictures... we all like to see what you're working on. It all looks good too!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 08-04-2017, 06:46 PM   #450
MMcMasters
MMcMasters's Avatar
thanks
Mike
