Old 07-22-2015, 01:13 PM   #1
F.A.A.benny
Factory A/C: POA Valve or Cycling switch?
Curious as to how many guys out there went with a poa delete kit, did they like it and why did they choose it over the poa valve. Im guessing cost can be a deciding factor as those delete kits are around $100 and it a little more to get the original poa valve rebuilt.
F.A.A.benny is offline   Reply With Quote
Old 07-22-2015, 03:41 PM   #2
Davidf
Re: Factory A/C: POA Valve or Cycling switch?
Not knowing any better at the time, I rebuilt the a/c system in my '71 (did not operate when I purchased the truck) utilizing a POA delete kit. I elected to stay with R12. Well, it took me about 2 miles down the road to figure out I made a mistake. The darn thing causes the compressor to cycle excessively....constantly on/off is more like it. When the compressors cycles off, there is a total and noticeable lack of cooling in the cabin. Also, the constant loading and unloading of the engine is simply annoying.
So, I built a test rig and calibrated my original POA to 29.5 psi and ripped that POA delete tube out and but the POA in where it belonged. Much better, but not perfect. I occasionally get less than cold air out of the vents.
Davidf is offline   Reply With Quote
Old 07-22-2015, 03:42 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Factory A/C: POA Valve or Cycling switch?
I changed mine out years ago to make it look cleaner under the hood. I like it a lot better than the old POA valve.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 07-22-2015, 04:49 PM   #4
engineer_gregh
engineer_gregh's Avatar
I went with the delete kit and regret it. I should have stayed with the POA valve. Davidf is right about the cycling and it being annoying.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 07-23-2015, 07:29 PM   #5
1972RedNeck
1972RedNeck's Avatar
This is the right way to do it.
I would recommend not deleting the POA valve if you run the factory A6 compressor as the clutches are known to eventually fail in a clutch cycling system.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 08-10-2017, 09:11 PM   #6
72freak
Rottenwood Garage Member
72freak's Avatar
What did you do with the metal line that came out of the box and screwed into the POA valve?
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 08-10-2017, 09:28 PM   #7
lsversaw
lsversaw's Avatar
What does POA stand for?
lsversaw is offline   Reply With Quote
Old 08-10-2017, 10:15 PM   #8
72freak
72freak's Avatar
In most circles it means a really stupid idea that luckily was changed quickly.....in others it means Pilot Operated Absolute Valve
Old 08-10-2017, 10:18 PM   #9
F.A.A.benny
He replaced the original evaporator with one probably from a square body truck
Old 08-10-2017, 10:20 PM   #10
F.A.A.benny
The poa valve was actually not changed for quite a while. It came around 1966 and used into the mid 70s. Gm completely changed over in 1974 and Ford used them for a few yrs.
Old 08-10-2017, 10:42 PM   #11
leddzepp
Moderator
leddzepp's Avatar
I've never had any poa issues personally. An old auto AC tech told me they are pretty reliable, and 9 times out of 10 the expansion valve fails before it does. Not sure how true that is, but so far this has been my experience.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 08-11-2017, 12:04 AM   #12
davischevy
davischevy's Avatar
I run the POA valve on all my old junk, and they work fine.
If you can get R12 do it, but I recalibrated my POA and it works fine with R134.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 08-11-2017, 12:14 AM   #13
tdangle
tdangle's Avatar
I still have the POA valve in mine. Went to recalibrate it and it was already at 27 so I just left it alone. Running R134 for now
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 08-11-2017, 03:27 AM   #14
Bob B.
Pilot Operated Absolute pressure valve. It's job is to maintain a certain pressure in the evaporator by regulating the suction of the compressor. It works in conjunction with the expansion valve, which controls liquid refrigerant flow into the evaporator. A cycling system does the same thing by turning the compressor on and off by use of a low pressure switch on the line coming out of the evaporator.
Conversion to a cycling system will work, but I don't think it's an ideal solution. This is particularly true if you are still using the original A6 style compressor, they were not designed to cycle (though GM did use them in some of the early cycling systems).
I stayed with the POA on my own truck (had it recalibrated for R134A) and a buddy did same on a '72 El Camino. Both systems work great.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 08-11-2017, 02:26 PM   #15
DT1
DT1's Avatar
Is there a write up somewhere for the R134A re-calibration procedure?
DT1 is offline   Reply With Quote
Old 08-11-2017, 02:32 PM   #16
davischevy
davischevy's Avatar
Just do a search. Lots of info out there on the web.
other Larry
Old 08-11-2017, 05:34 PM   #17
F.A.A.benny
Many online say to turn the set screw 1/4 Of a turn counterclockwise. It I find it not to be very pricise. I use guages and compressed air. What I believe it most important though it is to know whether or not the valve is functioning correctly or even at all. Can't do that with just turning the screw. Unless you knew the valve was functioning fine before recalibrating it, turning the screw won't work and you wont know until after you have charged the system
Old 08-12-2017, 02:21 AM   #18
Bob B.
I used these guys:
https://originalair.com/restoration-gm-poa-valves
Sent my old valve in as a core, got one of their remanufactured and recalibrated for R-134A valves in exchange.
Yes, you can probably get by with a guesstimate valve adjustment, but you really should figure out exactly what pressure it is opening at, as others have pointed out in this thread. That's the best advise I can give you, good luck!
Old 08-12-2017, 05:13 PM   #19
F.A.A.benny
I used these guys:
I used to work for them. That's where I learned how to rebuild poa valves.
Old 08-12-2017, 08:26 PM   #20
davischevy
davischevy's Avatar
So F.A.A.benny do you rebuild and rebuild the valves now?
other Larry
Old 08-12-2017, 09:56 PM   #21
strider621
strider621's Avatar
I used the POA delete kit from Ecklers and upgraded to R134A. Kept the old POA valve but new one is working fine.
Keith
strider621 is offline   Reply With Quote
Old 08-12-2017, 11:29 PM   #22
F.A.A.benny
Yep I still rebuild poa valves
Old 08-13-2017, 09:29 AM   #23
jjzepplin
jjzepplin's Avatar
WOW! That sure is a nice valve there sir. Price?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-13-2017, 09:38 AM   #24
F.A.A.benny
Thanks. It's $175 outright. I include free shipping to the lower48. To rebuild your poa valve is $125 with same shipping included
Old 08-13-2017, 10:05 AM   #25
jjzepplin
jjzepplin's Avatar
Good deal. I am going to be using R134. Should I remove the R12 MUFFLER? I am assuming this is the large canister style deal in the aluminum line.
