Luv the Crewcabs
56 Crewcab on the Bay...................
Came across this while surfing, Look's to be well Done............
http://cgi.ebay.com/ebaymotors/Cars-...3756.m14.l1318 Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
Re: 56 Crewcab on the Bay...................
Is it me or is the frame sagging
http://67-72chevytrucks.com/vboard/s...d.php?t=212604 |
polishing a turd
hey, that looks like the photo chops we did in my crew cab post!
there is something not right there at the back of the cab. the bed looks level, but the cab doesn't. it may just be poor fabrication of the rear cab mounts
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
The truck has a lot of potential if the right guy got his hands on it though.
As it is sitting on a later dualie chassis I would say that the body and bed just aren't aligned as well as they should be. It looks like both should come up about an inch or so where they meet. Last edited by mr48chev; 07-10-2008 at 01:41 AM. |
The bed does seem to be leaning towards the cab.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
Resident of Here
Cool! I like that tailgate.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
I wonder what he did to make rear pillar on back door like that?
I don't know, but I'll bet it was a lot of work. suicide doors on a crewcab dually, pretty impressive.
Boy howdy I thought that one was lost in the back dredges of the archives never to be seen again.
Power, I think he probably used a suicide door kit but he could have used part of the front post moved to the other side to runs stock hinges. Having swapped posts corner to corner on mine and using stock hinges to do suicide doors I'd (and have) spring for the suicide door hinge kit on it rather than use the stock hinges. That was a pretty cool truck that seems to have left the face of the earth after it was on Ebay.
![]() Join Date: Jun 2011
The suicide doors are not that hard to hinge. I used the original hinges on mine and just fabed up pockets in the pillar.
___________________________ 1959 Apache Short Fleetside, 1959 Apache NAPCO Long Stepside, 1957 3100 with 59 fleetside bed 1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370 1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF 1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker Big Bertha Build |
#11 | |||
Really, no one here knows how to shim pickup body components for alignment? That slight misalignment is easy to adjust. . |
Evidently the guy who built that truck didn't and that is the one detracting thing about that truck. the bent in the middle look. Nearly as bad as the droopy poopy drawers bed leaning down in the back look on AD trucks on S-10 frames to make them look lower in the back.
Sweet, the last post before yesterday was 2008. Remember that, boys and girls. That stuff you put out there on the web just might be there a while!
1955 SB Stepside 3100 big window cab on a 99 Ram 2500 Frame w/ 12-V Cummins diesel power and 47RH AOD transmission http://67-72chevytrucks.com/vboard/s...d.php?t=640042 |
Yuppers and someone who didn't read that is going nuts trying to find the truck on Ebay now. I knew it was an old thread because I remembered answering it the first time.
#15 |
lot of right and left rear door posts
luckily the op posted pics in 2008 nice freaking truck
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#16 |
I do think extended cab would be a lot easier if I had access to a 55-59 burban. Errr
