Closed Thread
Old 09-25-2017, 10:54 PM   #226
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: 1965 1/2 C10 Pickup
Originally Posted by joe dirt View Post
if your lifters had bars on them, they are aftermarket retrofit roller lifters
Why in 1965 would the factory put aftermarket roller lifters in his L79?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline
Old 09-25-2017, 11:40 PM   #227
joe dirt
joe dirt's Avatar
they didn't... lol...simply were not avail back then...if in fact this engine has roller lifters and cam, then it will have a cam button behind the timing cover to keep the cam from walking... if indeed it has these...then it has been retrofitted at a later time.....factory rollers dont jave bars on the lifters...and dont use a cam button
1961 c10 longbed - gone
1964 c10 swb
joe dirt is offline
Old 09-25-2017, 11:45 PM   #228
Captainfab
60-66 Nut
If the OP's L79 did actually have roller lifters in it from 1965, the aftermarket is the only source for a roller cam and lifters. And at that they would not be easy to come by in 1965.
Captainfab is offline
Old 09-26-2017, 07:53 PM   #229
rvrfoot
I think he had big connections. lol
rvrfoot is offline
Old 09-26-2017, 08:18 PM   #230
LostMy65
LostMy65's Avatar
There really isn't any shame acknowledging we may have forgotten something. But after we swear up and down, and stomp our feet; It sure takes a lot of humility.
But, still no shame.
'Hey, I could have sworn' .... isn't a rare expression.
LostMy65 is offline
Old 11-07-2017, 01:43 AM   #231
salty531
Just got Engine back from Machine Shop. Engine Block#'s (3858174) (GM225) (F1123YD)
Head# (3782461) (B175)
Friend researched and says that this engine was meant for a CHEVELLE,MONTE CARLO OR EL CAMINO but the YD at the end of the code indicates Pick Up. The Block Casting # says car only but the stamped #.... that was applied well after the Block was cast indicates that it was installed in a Pick Up. He thinks it is indeed a Hybrid Engine. Will continue to research.
https://www.amazon.com/photos/share/...HnbcINHHDavtM4
salty531 is offline
Old 11-07-2017, 05:09 AM   #232
The Rocknrod
Moderator
The Rocknrod's Avatar
-Corrected YD is our trucks.-
http://www.chevy-camaro.com/chevy-ca...s.asp?group=11
The Engine Suffix Code is stamped on a block pad located immediately forward of the right hand or passenger side cylinder head. The entire engine Code contains the assembly plant, month and day along with the engine suffix Code.
Let’s review. Your pictures show a two (2) bolt main block (not HO).
Suffix Code FII23YD
Flint Plant, November 23rd, The YD is a:
Code Year CID HP BBL Application
YD 1966 327 220 4 Powerglide,A.I.R. (this is the one)
YD 1968 327 240 4 Powerglide,A.I.R. (not this one as the casting number ended production in 67)
http://www.chevy-camaro.com/faq/chev...-decoding.shtm
Nothing special here and no indication of roller lifters even in the picture of neither the block nor the heads.
(incorrect info deleted)
http://www.nastyz28.com/gm-chevy-cod...-suffix-10.php
The casting number indicates it was a:
1964-67 3858174 327ci 275hp 2bolt main = Low Power (275 horse- not HO) 2 bolt main block. Nothing special here.
You have a nice 327 block, who put you up to the roller thing? - That by the way didn't exist when this engine was made.
The Rocknrod is offline
Old 11-07-2017, 07:23 PM   #233
Irishbleueyes
http://www.superchevy.com/how-to/eng...esign-secrets/
Paragraph starting with Valvetrain Breakthroughs says roller lifters and cams invented in the 60's...
I only knew of mass produced rollers in 87 but I was 4 in 66 so who knew...
Irishbleueyes is offline
Old 11-07-2017, 09:33 PM   #234
The Rocknrod
Moderator
Yes that was iskanerian that was an aftermarket designer as was mentioned on here earlier - not GM - his engine by the numbers is a GM replacement with NO roller anything. But still a nice 327 engine that anyone would be happy with.
Old 11-08-2017, 12:39 AM   #235
Captainfab
60-66 Nut
It does seem a little odd to me that the heads were cast on February 17 1965 but yet the engine was not built until November 23. But that is not to say that those heads are not original to that engine assembly. The heads having 1.94 intake and 1.50 exhaust valves, the engine would not have been a L79. I'm just not sure if those heads would have been on a 220hp engine. I am used to seeing them on 275-300 hp 327's. I was really hoping to see some sort of poof of the 'original roller lifters'.
Old 11-08-2017, 01:24 AM   #236
Irishbleueyes
I agree, 2 bolt main, 283 valve size and those replacement lifters are retro fit engine pro. Nothing factory about engine pro brand. To many holes in the whole story, somewhere along the many years there was some engine work. Proof would be pics of the original mystery lifters that came out. Sorry, but nothing adds up.. Rollers may actually have existed sometime in the 60s however they didn't come in that engine from the factory. I think we were all really hoping there was some actual magic somewhere in there.
Old 11-08-2017, 11:37 AM   #237
The Rocknrod
Moderator
Thats a good point concerning the heads date and valve size. I read the suffix code on the block stamp pad says that it was made in Nov 66. Am I right there or reading it wrong?
Old 11-08-2017, 12:09 PM   #238
The Rocknrod
Moderator
I was told by a very knowledgeable member that the 174 casting number is 1966 ONLY . Those are interchange years I was quoting not actual block years.
I was also corrected on the YD - The '66 327 Truck prefixes are: YS, YR, YH, YC & YD.
And that the block may be original to the truck but the heads aren't. Which "may" be the reason for the roller cam latter on.
Reading the C-10 Parts Book on page #8 at the bottom the YD is shown in the 1966 year but not on the 1965 year. Could be incorrect or the date of the truck is incorrect?
So these engines didn't have a VIN on the bloc.
I'm hearing this truck is a 1966 then? Not a 1965? Makes a difference on the info being correct.
Question:
a. Can the OP show the original cam numbers from the original roller cam?
b. Did those main studs originally come with the block?
Old 11-08-2017, 01:58 PM   #239
61K10
61K10's Avatar
If it did have a roller cam it was aftermarket. Isky had roller cams avl in the late 50's and they would have been solid lifter type.
1961 chevy K10
my build is------------61K10 build
61K10 is offline
Old 11-08-2017, 03:03 PM   #240
salty531
Yes the Main studs came with the Block.
We looked at the Cam and could not find any numbers? Where should we look?
Truck is 66 although i said 65 as i received it in 65. Sorry for the confusion.
Rollers came from factory as i have owned since new and engine has never been opened. Fremont Drag strip was next door to factory and perhaps this was something they were building to test and it got in this truck. Crazy but i guess i will never know how it happened.
salty531 is offline
Old 11-08-2017, 04:15 PM   #241
salty531
Thank you for all the info.
The Machine shop calls it a 4 bolt due to the screws in the middle of the bolts. This could be wrong info? No Rollers shown as the originals were thrown away. I know i will be torn apart for this but a third party was doing the engine work and had no idea what he had at the time. I would give my right arm to have them.
As i said before i have owned the Truck since new and the engine has never been apart so it had to come from the factory. We talked to someone who worked at the Fremont Plant during the 60's and he believes that this could have happened. He said they were building engines on the side in the factory and this could have explained this situation. Whatever it looks like i will never get to the bottom of this but i thank all for trying to help. The Truck will be kept in the family and passed down. We will enjoy having it.
salty531 is offline
Old 11-08-2017, 04:19 PM   #242
LostMy65
LostMy65's Avatar
You might be confusing what is actually 'Factory'.
It may have been put in by an associate there at your dealership, or at the drag strip you mentioned was next door.
LostMy65 is offline
Old 11-08-2017, 04:46 PM   #243
Robert Haas
Pathological liars are fascinating
Robert Haas is offline
Old 11-08-2017, 06:41 PM   #244
The Rocknrod
Moderator
If a machine shop calls that a four bolt main then I can imagine what else they call it. Or maybe I can't imagine what?
Well as I said before it's a nothing special engine block made for a 66 Chevrolet truck as stated in the C-10 parts book. No roller about it.
Sometimes people want something Soooo bad to have something special that no one else has, I get it.
Old 11-08-2017, 09:34 PM   #245
jayoldschool
Moderator
Good. Acceptance.
Arghh, you're killing me. One step forward, one back.
The
rollers
didn't
come
from
the
factory
jayoldschool is offline
Old 11-08-2017, 09:42 PM   #246
Robert Haas
First off is the new rebuilt engine going to have roller lifters in it?
If so does it have a cam button?
If yes did the machinist install it?
If no,.... well we all know how that is going to play out now don't we?
The same machinists that called this a 4 bolt main engine because it had aux lugs on the studs,... is he the same guy that identified the lifters as rollers???
So many questions we will never ever, ever get an answer to.
Just because you are old, don't give you the right to change the truth to your own reality.
I am nearly 60 years old myself so I am just a kid to you, but I have 50 years of building Chevrolet Hot Rods and I get to call BS when I hear it.
Old 11-08-2017, 09:45 PM   #247
TJ's Chevy
TJ's Chevy's Avatar
The Machine shop calls it a 4 bolt due to the screws in the middle of the bolts. This could be wrong info? .
Unfortunately, yes that info is wrong. That is a 2 bolt main with locking nuts on the screws. A 4 bolt main would look like what I have pictured. A total of 4 Bolts per main....hence 4 bolt main.
TJ's Chevy is offline
Old 11-08-2017, 09:47 PM   #248
Robert Haas
This is a cam button,
Old 11-09-2017, 12:35 AM   #249
Captainfab
60-66 Nut
All 327's were 2 bolt mains. No that is not '283 valve size'. The 283's had 1.74 intakes and 1.50 exhaust valves.
Any roller cam from 1965 would have been an aftermarket cam. More than likely an Isky cam. Isky proudly stamps their name and grind number on the end of the cam closest to the distributor gear. A roller cam from 1965 would have also been a solid lifter type which would require periodic valve lash adjustment
Sorry but main studs do not equal a 4 bolt main cap. Yes they make a stronger assembly than using the typical bolts, but not the same as a 4 bolt. So these studs have a locking set screw in the middle? In looking at the pictures is appears to simply be the hex socket used to install the studs into the block. Most aftermarket main studs have the hex socket.
Old 11-09-2017, 07:50 AM   #250
shortstep60
They did not put roller cams back in 1965 from the factory in chevy cars or trucks.
shortstep60 is offline
Closed Thread
