10-07-2017, 09:28 PM | #5851 |
Re: What did you do to your truck today? Chapter II
10-08-2017, 02:22 AM | #5852 |
Dad found his impressive cable crimping tool for me and I finished painted 7 pieces for my truck.
Two lower 3 row radiator brackets Two headlight buckets Two j-nuts *yes I paint those. One hood latch support bracket I have to paint outside and with this rain coming, none too soon! |
10-08-2017, 02:53 AM | #5853 |
At the body shop.
Because the red ones add horsepower.
" That didnt make it any newer " " Dont antique the equipment " |
10-08-2017, 12:07 PM | #5854 |
New crate engine... ATK HP32C
http://www.high-performance-engines....hp-p/hp32c.htm Replaced the carb w/ FITech I had on previous engine
JMC1965 1967 C20 LWB
10-09-2017, 12:53 PM | #5855 |
Cleaned most the junk out of the cab and bed, then loaded it on the trailer for the trip home on Wednesday.
Jake |
10-09-2017, 04:21 PM | #5856 |
Old member
I bought a push bumper for the RAT!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
10-09-2017, 11:41 PM | #5857 |
Now that is a bumper, a real bumper of yesteryear, cool.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
10-10-2017, 06:13 AM | #5858 | |
Old member
I think it will look great on the Rat!
10-12-2017, 04:26 PM | #5859 |
I just came in. I put the newly repainted headlight buckets back on, cleaned the last of the electrical connections, including studs on starter and engine block ground, connected the last two ground wires to the core support, and removed the two front wheels. Yes, my rotors need sanding!
10-12-2017, 04:39 PM | #5860 |
epoxy-ed my ride
Steven '67 SWB, 250ci, 3OTT.......this is my first build...... I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71" |
10-12-2017, 10:39 PM | #5861 |
I also cleaned up the headlight retaining ring screws with a wire brush and bought some machine screws, washers, and lock nuts (stainless) to mount the front side marker lights. I don't really like J-nuts and I hate pointy screws....you can cut your hand reaching into the fender for something.
10-13-2017, 02:48 PM | #5862 |
Pulled intake to replace the gaskets and found this! Does this look factory? should look purty and leak free tomorrow.
10-13-2017, 03:20 PM | #5863 |
Installed new trailing arm bushings...and new bolts & locking nuts
1970 C10 Short Stepper with 71/72 front clip. |
10-13-2017, 03:32 PM | #5864 |
I started gathering parts for this winters upgrades. They are staring to roll in...
10-14-2017, 01:57 AM | #5865 |
Put the flush-fitting front side marker lenses on with 8-32 stainless steel machine screws, washers, and nylon lock nuts. Not "OEM" but I don't like j-nuts or pointy screws. Seems to be working fine.
10-14-2017, 02:35 AM | #5866 |
Junior Member
Well after 2 months of nothing because My home AC and furnace almost burnt my house down and it cost me 8k to fix. I started buying stuff again Bought a rear fuel tank, New Fuel pump, regulator, Fuel lines New brake lines, New headers for the 382 stroker I bought a few months ago that will go in once the transmission I am buying next month. Hope to buy the New Alternator and power steering pump and Polished chrome pulley's in a week or 2.
10-14-2017, 03:19 PM | #5867 |
Finished the intake gasket replacement and did a little painting.
10-14-2017, 10:29 PM | #5868 |
At the body shop.
Hub seals, packed bearings and new pads. Son gets the joy of re torquing the lug nuts.
Bad side of today saw how bad the frame is cracked up by the steering box.
10-14-2017, 10:35 PM | #5869 |
Repaired the engine bay wire harness and dimmer wiring on the '67 custom and drove it.
Installed the front sheetmetal on the '68 Cummins swap for the last time!
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
10-15-2017, 12:02 AM | #5870 |
Knocked the dirt dauber nests out of the alternator, and sprayed down the wasps that are trying to take over our project.
"Don't get it right. Get it running." -David Freiburger 2014 GMC Terrain I4 (wife's new ride) 2005 Dodge Magnum 3.5 (wife's old ride) 2003 GMC Sierra 5.3 Extended Cab 1972 Chevy Cheyenne 350 |
10-15-2017, 02:14 AM | #5871 | |
I reinstalled my headlights and retaining rings. I ended up using two of the original screws but 4 new 3/4 inch machine screws. It was just too hard to get the OEM short ones started. Turns out two of new ones are too long to fit properly so I'll have to get some 1/2 inch ones and try those. It doesn't help that my retaining rings aren't fully round....they've been bent some time before I came to own this truck. Ugh...... |
10-15-2017, 09:30 AM | #5872 |
Covered my door panels with copies from old drag racing magazines.
Brad handshoe |
10-15-2017, 12:26 PM | #5873 |
Nice touch!
10-15-2017, 12:55 PM | #5874 |
Magazines are interesting touch...but don't see any race trucks.
Mudman.
10-15-2017, 03:17 PM | #5875 | |
At the body shop.
Old blue had spider eggs in the caliper pucks. Yuck
