10-11-2017, 11:03 PM | #1 |
Wheelbase:How Short is too Short?
I have a 63 LWB I'm doing a flatbed dually with. I've been thinking of notching the back but maybe shortening it up too since I'm not running a bed and I won't need to match it up to anything. I've got it mocked up at about 113" and I like it. I've read 110" to 120" is used for hot rods and stuff so it seems reasonable. Any thoughts? Stupid idea? Any problems you think I might run into with handling?
10-12-2017, 05:34 AM | #2 |
Re: Wheelbase:How Short is too Short?
Do you want to tow with it or more just a truck used ?
10-12-2017, 10:47 AM | #3 |
meowMEOWmeowMEOW
For a dual wheel truck (assuming you want to tow or load it) shorter = less stable.
A short truck with a lot of weight on it will have a harder time controlling a load under braking.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
10-12-2017, 11:22 AM | #4 |
Thanks guys! I don't plan using like a truck. I'm building a little novelty hot rod for my business. I'm going to drive it like a car.
10-12-2017, 12:20 PM | #5 |
also the shorter the wb the ruffer the ride..
10-12-2017, 12:32 PM | #6 |
does anyone have a link or place of a wheel base chart for short bed?? I believe short bed should be 115in but I thought I remember seeing a chart some where with precise measurements. thanks
10-12-2017, 01:39 PM | #7 |
I believe a SWB is 117", a long is 127", and a one ton is 133". So 113" is just a little shorter.
I'm building a little downtown hot rod. I'm laying frame too so it's not a practical truck it's to get attention. So I thought while I was notching it I could shorten it at the same time. I'll be building a rear end anyway. |
10-12-2017, 04:03 PM | #8 |
I have a 73 P10 stepvan and the wheelsbase is 102”. So I’m thinking that Chevy designed a “half ton” with 102” and used for hauling stuff. Can it really be all that unsafe and unstable...maybe not
Customization is what you want it to look like -- not what other people think it should look like |
10-12-2017, 04:27 PM | #9 |
I would make it short bed length. You never know if you come across a good bed someday you may change your mind. with a flatbed you probably would never notice a few inches either way.
10-12-2017, 05:46 PM | #10 |
meowMEOWmeowMEOW
AFAIK the only vehicle (full frame truck) that is shorter than the 2dr S10 Blazers, is the Postal Jeep. I was able to tow single axle motorcycle trailers etc, so its not "unsafe" at small loads. I think it being a dually one ton is what throws people. If you aren't using it as a one ton, then so as short as you want. Heck, guys drag race Topolino's and Anglias, and they are TINY>
10-12-2017, 11:20 PM | #11 | |
10-14-2017, 01:56 AM | #12 |
meowMEOWmeowMEOW
Thanks for watching!
10-20-2017, 01:19 PM | #13 |
frame specs
lwb and swb
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
10-20-2017, 01:44 PM | #14 |
The 1969-1972 blazers are 104" and people tow with them all the time.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
