Old 10-16-2017, 06:29 PM   #1
Jonny Hotnuts
Rust on lower leading edge of hood. How to approach?
I have some rust through on this section of the hood.
The hood is in very good condition otherwise and the rust is only on this 'under lip'.
What is the best approach for repairing this section less replacing the whole thing?
Tks!
~JH
Jonny Hotnuts is offline   Reply With Quote
Old 10-16-2017, 08:00 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Rust on lower leading edge of hood. How to approach?
Replace the hood. You are close to good sheet metal in your neck of the woods. You will be time and money ahead.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 10-17-2017, 03:26 PM   #3
cypressbog
Go Pack Go!
That's a common place for them to rust. I agree, find a replacement for a hundred or two.
cypressbog is offline   Reply With Quote
Old 10-17-2017, 05:18 PM   #4
rsavage
rsavage's Avatar
+3 Find a new hood.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 10-19-2017, 10:36 AM   #5
Graham57a
Graham57a's Avatar
Tks!
~JH
If you are trying to preserve the original paint and do not want to replace the hood then there are ways to either neutralize the rust or replace the metal. You can remove the under hood brace with a spot weld cutter and that will allow you to get to the backside of the rusted out lip. Not sure what kinda equipment you have access to but a simple sheet metal break should make it easy to duplicate the bends in that front edge and cut out what is bad and replace it. If you don't want to cut and weld it I would at minimum spray some ospho on the back side and clean it up with a wire brush and use some sort of rust converter to slow it down.
I have the same issue on my 68 gmc but I have a piece of trim on the front edge that will help hide the new metal. Oh and if you don't care about the patina then yes getting a new hood is waaayyy easier. Hope this helps
ANDREW
1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072
1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827
1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315
1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788
1972 Chevy SWB Highlander OLIVE Build thread coming
Graham57a is offline   Reply With Quote
Old 10-19-2017, 11:09 AM   #6
Harrison.
Short of finding a new hood, if you have access to a metal brake, welder and some 20ga sheet metal it would not be hard to reproduce that. However, if you value your time I'd do what others have suggested and replace the hood.
http://harrisonspeed.com
Instagram: harrisonspeed
Harrison. is offline   Reply With Quote
Old 10-19-2017, 08:16 PM   #7
Barnfind46
Barnfind46's Avatar
I agree. Replace the hood. I am an experienced collision and restoration tech and would repair it for my self but if you pay someone it will be more than a replacement hood just to get to the primer stage.
Barnfind46 is offline   Reply With Quote
