Old 02-03-2016, 11:50 AM   #126
ls1nova71
ls1nova71's Avatar
Re: Pre-LS swap questions
I would think a set of fourth gen F body manifolds would fit. Do you have a pic of your steering set up? May have to get creative with it to make it clear.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10 (avatar truck)
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-03-2016, 01:37 PM   #127
50 Chevy LS3
Greg, I've been going through the same problem with mine, lately.
I ordered the Sanderson headers listed for this application.
You can see everything, with pictures here,http://talk.classicparts.com/threads...headers.22242/
The thread rambles somewhat, with Lakeroadster and I discussing general things, but, it shows pictures of how I solved the problem.
It looks to me, my engine sits a little more rearward than yours.
I'm going with the F-body oil pan.
My engine is the 6.0 LQ9, so I opted for the 1,5/8" header tubes.
Steve.
Steve.
1950 Chevy, 3100, built in Norwood Ohio, USA.
My build thread, http://talk.classicparts.com/showthread.php?t=19110
50 Chevy LS3 is offline   Reply With Quote
Old 02-04-2016, 11:20 PM   #128
Root2812
Root2812's Avatar
Originally Posted by LockDoc View Post
I used these on my '67 and they fit great. I'm not sure how they would work on the 50 though.
http://www.ebay.com/itm/Hooker-Heade...xTxRxO&vxp=mtr
I think you can also get them in a coated version.
LockDoc
I will have to take some more measurements to see if those would work. Right now my biggest clearance issue is width.
manifolds wouldn't work. Are the fbody ones tighter than the corvette ones I have?
I don't have a steering set up yet. I just have so little space for the manifold and steering to share that I knew my
Steve.
Thanks Steve. I'll have to give your thread a read.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 04-30-2016, 10:39 PM   #129
Root2812
Root2812's Avatar
I got another question for you experts. I may be over thinking this but better to ask than not.
So when I painted my engine I didn't mask off the place where the waterpump gasket or exhaust gasket goes. When I see pictures online it looks like a lot of people do. Do I need to strip the paint off? Its smooth so I would think it would seal but I won't want a leak later. I did mask off the intake ports on the heads.
Another thing is that while my engine has been sitting in the frame with no crank pulley I got flash rusting on the crank snout. I was planning on just cleaning that with emory cloth. Think that's the right way?
My 1950 Chevy build
Old 10-20-2017, 09:34 AM   #130
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I searched, and this thread seems like the best place to ask my question.
I feel comfortable doing most everything on a Gen 1 sbc,
Are LS Engines difficult to work on?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 Service truck build:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 10-20-2017, 09:37 AM   #131
Robznob11
Robznob11's Avatar
Wink Re: Pre-LS swap questions
Only 100 times easier than working on a gen 1, no lashing valves, no pulling heads to swap a cam......I have seen questionable people tear into to them and come out with great results!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 10-20-2017, 11:38 AM   #132
LostMy65
LostMy65's Avatar
Cool!
Back in 85/86 when I was only 20, I rebuilt my 283 with a JCWhitney Rebuild Kit.
I didn't even take it to a machine shop. I visually inspected everything, honed the cylinders myself, ground the valves, checked the clearances, and put it back together.
It ran great until I sold it. The old man I bought it back from said it blew up on him in around 2004/05. So, I guess I'll be fine with an LS.
Old 03-09-2018, 03:56 PM   #133
Root2812
Root2812's Avatar
Hi guys. Yes I am still working on this very slow project. I need a bit of help. I attached 3 pictures. 2 of them show ports on the throttle body. What are they for and where do I connect them too? Can I just cap them? The other photo shows a brass fitting coming off of the intake. Can I just cap that off?
I'm getting closer and closer to firing the engine for the first time but I have lots of loose ends to tie up first.
My 1950 Chevy build
Old 03-09-2018, 11:45 PM   #134
Wildkarde
The port on the upper drivers side of the throttle body is your PCV clean air source, should go to the front of the passenger side head.
The two on the bottom of the throttle body are coolant passages for pre-warming air, normally the hose from the steam vents goes in one and out the other but most swappers just leave them disconnected.
The one on the intake manifold is the vacuum source for the PCV system, if that is an actual ls1 it should be on the valley plate. Trucks have a PCV valvle looking thing on the back of the drivers head.
Wildkarde is offline   Reply With Quote
Old 03-13-2018, 10:23 PM   #135
Root2812
Root2812's Avatar
Thanks. You confirmed what I thought for the ones on the throttle body.
I'm confused about the one on the intake though. I have the PCV in the valley cover and the preformed host goes to the port on the intake thats in the same spot but on the passenger side. I thought that one on the drivers side that I showed was for something like evaporative emissions or something but I have no clue. If my PCV goes to the other side of the intake this post can't be PCV too.
My 1950 Chevy build
Old 03-14-2018, 12:22 AM   #136
Wildkarde
I think you're right, I deal mostly with truck intakes which get their PCV vacuum from the top center of the intake and have the EVAP purge solenoid mounted right behind the throttle body on top of the intake. If your pre-formed hose goes to the other port then use that one it really doesn't matter where you get that vacuum signal from. If you don't use the EVAP just cap the other one off.
Old 03-14-2018, 12:40 AM   #137
Root2812
Root2812's Avatar
Great thank you. I was just guessing on what they were for so I really appreciate the confirmation.
My 1950 Chevy build
Copyright ©2000 - 2018, vBulletin Solutions Inc.
