How do I kill this automatic function?
I have an 87 TBI 350 silverado. Which seems to pick and choose at random, when its going to engage that weird, higher RPM engine warming function. Its when the engine will idle higher, in some kind of seemingly unnecessary attempt to warm up... better? Faster?
I'm told that it has something to do with the cold, but it doesn't always do it when its really cold outside. It does it when there is... like an average temperature change. Here in TX I do not need the function. And its malfunctioning. It won't do it in the summer, unless we get one of those rare cooler nights. Then it may do it. But as a general rule in the summer the truck won't do it. Its in the spring and the fall when its the worst. In the winter it doesn't really do it much either, although there are times when it will. Today I was sitting in the drive thru, and it was idling at 1500 rpm. I've seen it go to 1700 when its doing this. And its hard to get it to stop. It just decides all on its own when its going to stop, but this is usually after I've been driving for 10-20 minutes. Its really annoying and I'm sure people around me are wondering why my truck is making so much noise. So how do you kill this ill conceived function? I don't need it, and I don't ever want to see it again. I just want the truck to always start up and idle the same. |
Re: How do I kill this automatic function?
There is a temp sender that the computer sees to know when to enrich and bring the idle up . This sender may be out of calibration in those temp zones you are talking about .
Also you may want to look into the air idle control . It could be dirty or malfunctioning . I don't think you can do away with this function . It has to work together as a whole . If you get the problem fixed it will work as you want it to . |
Could be your a/c circuit controlling the idle.
My 84 did the same thing. I simply unplugged the compressor on the a/c so it wouldn't cycle on/off and the idle never changed anymore. |
#4 | |
#5 | |
![]() Join Date: Apr 2009
Coolant temp sensor is separate from this sensor. Make sure your cooling system is working normally, low coolant temps will effect the sensor making the computer think the engine is still cold.
Desert |
It may even have a code stored to tell you what is out of spec.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
As Desert said , its right in front of the throttle body . This is the one the computer sees . The one in the rear of the head on the pass side is for the gauge .
Which one did you replace . Cadillac has a good point . Check to see if any codes are set . There is a way to check with out a scanner with the flashes of SES light . May give us a direction to go . Last edited by homemade87; 11-05-2017 at 08:56 AM. |
#8 | |
So to be clear, the one that governs the function I'm complaining about, is right in front of the throttle body? No wait, I went back an reread and desert said its a separate. Anyone know the exact location of this sensor, or otherwise how the computer gets the information to turn up the idle? |
As Desert said, its right in front of the throttle body ( this is the one for the computer ). This is the one the computer sees and you are concerned about . The one in the rear of the head ( by the exhaust manifold ) on the pass side is for the gauge only ( only makes the gauge work , not concerned about this one ) .
#10 | |
Download WINALDL free of charge. just buy or make a cable and then you can data log in real time and take the guessing out of it. |
My 93 model was doing the same thing. Changing the sensor didn't help me. what did help was cutting the ends offa the grounds at the thermostat housing & crimping new ends on. Then get all the grounds on the manifold stud that has the neg bat cable on it. Fixed mine.
#12 | |
4x4k30 if trouble was money i would have plenty |
Benny,
Have you found the problem? I can say that without data logging you may never find it. Here are a few things that will cause high idle. without reading the computer you will have to guess. plastic shift indicator at the base of the steering column is broke or cracked and the truck thinks it is in gear when it is not 02 sensor to far from the manifold and not going into closed loop ,needs heated 02 temperature sender for the computer is off and reading cold. possible vacuum leak. TPS set wrong. here are some screen shots of the program. you will find your problem in one minute. If you want to PM me i can walk you through it. My TBI idled high and i wasted a lot of time and money guessing. My issue was the shift indicator and 02 sensor. sticking IAC. calling for AC by default. |
Hey! I didn't know that TBI went to closed loop! Learn new stuff ever day!
#15 |
On mine the 02 sensor was at the y pipe ~2' from the manifold. It would only get hot enough to operate at highway speeds. If you look at the next generation manifold, the 02 is mounted right at the #7 cylinder.
#16 |
Yeah I thought about using that WINADL thing but I don't have a cable.
Is anyone familiar with what its supposed to be doing? As in, when its cold outside, is it supposed to idle higher? I really just don't like the function. I don't ever need this thing to idle higher. And its definitely related to the cold. But I guess you'd have to flash the computer to kill it. I do have a scanner that may be able to read the codes though. I haven't had time to work on the truck lately. But when I do I'll post up the results of the scanner in this thread. Its got several other much more pressing problems as well that I have to fix first though. ![]() |
#17 | |
The idle would have nothing to do with ambient temperate. Only the engine coolant temp. here is the cable http://www.moates.net/cabl1-obd1styl....html?cPath=64 there are others likely cheaper but moates stuff works. odds are good you do not have a heated o2,, Also there is a white plastic tab at the base of the steering column that crudely operates a switch that tells the computer is you are in gear or not. It adds IAC steps under certain parameters. This may be the cause of your problem but it is is not as much an issue when the motor is warm because there are other parameters that limit the idle. There is a myriad of code the work hand in hand. When one is flagged it will cause other problem. I can promise you the cable will be your smallest expense if you try to guess instead. |
#18 |
Well yes but the ambient temp will of course lower the coolant temp if its colder outside. And that is when I notice the issue. Once the truck is warmed up, it won't do it anymore. Say for example if I go somewhere: I go inside for a bit, and come back out, and the engine is still warm enough (on a cold day). It won't do it then.
#19 |
![]() Join Date: Jun 2016
I have the same issue occasionally with my R30. Plus keep getting a EGR code and been chasing that with new parts. Just bought an ALDL cable. I'm done going at this blindly. Ordered it from here - http://www.aldlcable.com/
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
#20 |
My truck also has a problem with the EGR. Wonder if its related in some way to the issue...
#21 |
Once the engine is warmed up and idling normally, unhook the wires hooked up to the IAC valve. Now the idle will be set. Yes, you'll have to apply some gas pedal pressure during cold start ups but that's not hard to do and get used to. Plus, it prevents others from driving it.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
#22 | |
In my experience it idles fine when its cold. Again I'm in TX, and we don't really have cold winters. When it doesn't go into high idle mode on a cold day, it still idles fine. Maybe a bit lower than normal, but its a fuel injected truck and I usually just drive off anyway and its well on its way to warming up. |
#23 | |
#24 | |
Benny, Listen to the wisdom of Dieselsj, You will spend nothing but money and time throwing darts at it. If you want to stop all IAC functions do as edahall suggested or set the IAC to zero this way. 1) With the IAC valve connected, ground the diagnostic (ALDL) terminal (same as you would do to flash trouble codes thru the check engine light). 2) Turn ON the ignition, but do NOT start the engine. Wait at least 30 seconds. The IAC will go to zero. 3) With the ignition still on, disconnect the IAC electrical connector. This will leave the IAC at zero and with no connection it will remain there. 4) Remove grounding of the diagnostic (ALDL) connector and start the engine. 5) Adjust the idle stop screw on the TBI. If your IAC is working right it is nice to have. It adds counts for power steering, ac engaged, cold starts, when in gear. I can't urge you enough to take advantage of the free (donation) software. There is most likely more going on than you will know and a little more MPG will pay for the cable. good luck. |
#25 |
Got my cable yesterday. It came with a CD that had more than a dozen different scanning/logging programs. I loaded up winaldl and went for a quick drive.
- I have CEL flags that weren't registering when I grounded the pins on the connector and read the flashes. The only code that showed up was for EGR. I also have codes for TPS low voltage and ESC. - My knock counts are out of control. I'm seeing counts of several hundred on each cycle. Actually it cycles between just a few counts and several hundred. - Confirmed that my temp sensor is reading correctly. - IAC operation seemed fine - I am slightly lean everywhere. This was expected due to the high-flow cat and 3" exhaust that I added. It seems to be within the parameters that the computer can handle though. Hooked up the timing light and found that my initial timing (with plug disconnected) is sitting at about 10 degrees and is bouncing around. Didn't have time to adjust it. While I wouldn't think 6 degrees of extra timing would really hurt on a sub 8:1 compression engine, the combustion chamber might just suck enough to detonate anyway. Need to investigate further to determine if timing scatter is due to bad/failing ESC or timing chain.
