Old 11-13-2017, 02:06 PM   #1
andreas_kc
49 5-Window Cab - Inner Panel Rust - Fix or Replace?
Not the best picture, but what I have atm. The inner panel to the center rear window is really badly rusted almost all around the center window. Once it was blasted it definitely came out pretty bad. Does the center section remove from the inner sides that fit the corner windows?
Best example pic of the inner 5 window panel (not mine)....it looks like the center section would separate and I could replace just that?
Is it easier to replace this or weld in patch pieces? Its rusted out right around the crease/bend around the center window.
'51 Chevy 3100 Short-bed
2000 Custom Ducati Monster 900ie
andreas_kc is offline   Reply With Quote
Old 11-13-2017, 02:11 PM   #2
andreas_kc
Re: 49 5-Window Cab - Inner Panel Rust - Fix or Replace?
Also, have a build thread here.... http://67-72chevytrucks.com/vboard/s...d.php?t=735623
Old 11-13-2017, 06:33 PM   #3
mongocanfly
get some better pics of the area your talking about...I'm not seeing what your describing. ..I think I see it but the pic is dark...
Old 11-13-2017, 09:15 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
What I see in picture one is very badly rotted. I'm willing to bet that the outer panel is near that bad if you poked it with an awl. You will need to remove the inside center section at the seams media blast the outer panel that mates with it and then evaluate how to proceed.
I see at minimum a outer and inner panel replacement if you don't want that rust popping through is 2 years or less, when you open it up your find more than one nest of cloths and paper no doubt.
Old 11-13-2017, 10:35 PM   #5
andreas_kc
It's dark out there... flash and black paint make it hard on the pictures... maybe this is a bit better....
So, look at the top edge of the center window.... its completely rusted out from most of the top section....
The bottom of the center window isn't too bad... but the flat part that is about where the belt of the cab is in pretty poor condition. If that flat belt part can be hidden behind seats or something I'd be ok with it. It looks way to bad to cover up well with filler... but maybe inside a cab it's not going to get as weathered as the outside paint and cramming a bunch of filler is ok-ish? If its going to be visible, I want something thats gonna last.
Old 11-13-2017, 10:43 PM   #6
andreas_kc
Here is a pic of the outside cab after being blasted... still some w&g remover that hasn't flashed off yet.. but should give decent condition of the outside on this area. Who knows what it looks like on the inside between the inner and outer skin.. Obviously the inner is toast.
Old 11-13-2017, 10:48 PM   #7
andreas_kc
So it sounds like you CAN remove just the center section then? Are there spot welds in the seam? Or is it crimped/slid/bent together?
Old 11-13-2017, 11:00 PM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
the seams are spot welded on the inside and the three pieces are put in as a unit. From what I see on the outside you have a problem with the back lower panel and the upper window outer panel.
Old 11-13-2017, 11:07 PM   #9
andreas_kc
Yea, there are some def little holes along the belt on the outside... the outside I thought I'd be able to weld in a little and grind em smooth without much fuss.
The inside thou, after being blasted just looked so rough... sounds too difficult to sep the seam of the center section if it's spot welded on the back.... I can't even find someone that sells just the sheet metal for the center... all of them include the side windows...
Old 11-14-2017, 12:13 AM   #10
MARTINSR
MARTINSR's Avatar
You can't swap out the center because it's welded with a "pinch weld" to the side pieces. Swapping the whole thing is really pretty easy. It's spot welded around the windows and down the B pillar under the windlace holder. There are a few beads on the vertical support that goes down to the floor from below the rear window. It really is pretty damn easy to do.
Here is a photo of the whole thing I took out for mine and I went out in the rain in my pajamas to get you this photo of the back side so you can see how the center section is pinch welded to the side pieces.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is online now   Reply With Quote
Old 11-14-2017, 12:29 AM   #11
MARTINSR
MARTINSR's Avatar
I went back out in the rain to get this shot. I was going to say that if you wanted that piece on the back of the cab I could send it to you. But realistically if you get the inside of one of these cabs you can get that back piece at the same time.
Brian
1948 Chevy pickup
Old 11-14-2017, 12:47 AM   #12
andreas_kc
Brian
Hah, dude, thanks for the rain pics.... in your pj's
Yea, just gonna suck it up and take the whole inner piece out.... was looking for a better way and looks like that isn't happening...
On the bright side, those two dents on the outside top/rear are gonna be a lot easier to hammer out now!
Old 11-14-2017, 11:13 AM   #13
MARTINSR
MARTINSR's Avatar
But get the patches on the bottom done and the structure repaired before you cut it up any more.
Brian
1948 Chevy pickup
Old 11-14-2017, 12:14 PM   #14
andreas_kc
Brian
Thanks, good point. I'm a bit skeptical that the doors are going to fit right now wo tweaking the pillars. Gonna do that first? Will then weld in replacements for what I've cut out first
Old 11-14-2017, 02:18 PM   #15
MARTINSR
MARTINSR's Avatar
You want to do a "dance" with them all. Put the doors on, change the patches on the bottom, that is way more structural shape changing than the inner panel is. You can remove that (it's out of my cab right now) without making a big deal, the patches and structure of the lower cab is a different story, you want that right first.
Brian
1948 Chevy pickup
Old 01-12-2018, 02:59 PM   #16
mark1505
Brian
How do you remove the top section of the cab I'm have a 5 window cab that the bottom is all rusted out . A good 3 window cab I want to swap out the tops
Are there spot welds? not sure what to cut Thanks Mark
mark1505 is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
