Old 12-08-2017, 11:12 PM   #1
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Let's play name that part, bolt, harness, screw....
I figure this could be a good learning opportunity. Let's post up parts and pieces and name the application. Here's one: where does this rubber piece attach?
Old 12-08-2017, 11:29 PM   #2
71cheyennesuperlongb
71cheyennesuperlongb's Avatar
Re: Let's play name that part, bolt, harness, screw....
Airconditioning housing for condensation drain?
'71 Cheyenne Super LWB - Second Owner in 39 Years!
'70 CST/10 SWB - Soon to be Daughter's truck when finished
71cheyennesuperlongb is offline   Reply With Quote
Old 12-08-2017, 11:30 PM   #3
Old Money
a/c evaporator drain and spring clamp
old money
Old Money is offline   Reply With Quote
Old 12-08-2017, 11:32 PM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Yes! Often missing. Here's the attachment location.
Old 12-08-2017, 11:33 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Ok. Anyone familiar with these sheetmetal screws?
Old 12-08-2017, 11:36 PM   #6
Old Money
grounding strap screws
Old 12-08-2017, 11:45 PM   #7
DeadheadNM
Carpe manana
DeadheadNM's Avatar
These are the body-side ground screws that I'm familiar with - not all used a star washer but that's just my experience. Here are examples including that for the ground for the AC harness at the condenser box and those at the rad support, which differ from that below: http://67-72chevytrucks.com/vboard/s...1&postcount=54
The longer sheet sheet metal screws above were used for two applications that I'm aware of.....
Old 12-08-2017, 11:56 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
These are the screws used for the fan ground at the AC box and examples of those used for grounds at rad support. Replated in clear zinc.
Old 12-08-2017, 11:58 PM   #9
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here's the screw used for the battery clamp on my blue 72 blazer - similar to rad support ground screws but longer.
Old 12-09-2017, 11:32 AM   #10
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Screws in post #5 are correct for mounting the console to floor pan and also used for some attachment points for AC and heater box - in cab side maybe?
Old 12-09-2017, 11:43 AM   #11
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Ok. What about these screws....anyone?
Old 12-09-2017, 12:28 PM   #12
SoCoC10
SoCoC10's Avatar
Here's a hint...Some Blazer and Jimmy guys will have these others will not.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 12-09-2017, 02:11 PM   #13
FL71C10
Rear hatch screws?
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 12-09-2017, 05:40 PM   #14
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Originally Posted by FL71C10 View Post
Rear hatch screws?
Close! These are the top bolts for use on k5s w a single wall top. Not best example pic but shown below.
Old 12-09-2017, 05:50 PM   #15
DeadheadNM
Carpe manana
DeadheadNM's Avatar
How about the application for these nuts?
Old 12-09-2017, 06:02 PM   #16
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Acorn nuts for West Coast Jr. mirrors.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 12-09-2017, 06:04 PM   #17
projectking
projectking's Avatar
Gary
Ditto
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 12-09-2017, 06:27 PM   #18
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Yes! Camper mirrors and below eyeline. Did you know the threads are metric?
Old 12-09-2017, 06:32 PM   #19
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here's an obscure part (set of 4) I received in a parts lot. I honestly don't know exactly where these go. Spacer for what the rear lamp lens?? Between screw and lens?
Old 12-09-2017, 06:34 PM   #20
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Parts tag...
Old 12-09-2017, 06:48 PM   #21
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Neat idea Deadhead. Here's something you don't see everyday.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 12-09-2017, 10:28 PM   #22
atog
If that's what I think it is I wish I had a 5 gallon bucket full of them. 72 c10 part 2 per vehicle
atog is offline   Reply With Quote
Old 12-10-2017, 12:22 AM   #23
SoCoC10
SoCoC10's Avatar
I'm thinking that is the gas tank vent tube for a 71-72 truck. Goes up the passenger side of the cab between the back of the seat, just behind the door jamb, where all the jack tools are missing.
Old 12-10-2017, 12:59 AM   #24
71CHEVYSHORTBED402
Yep, right above the missing parts......"Vent pipe assembly".
Tony
Old 12-10-2017, 09:42 AM   #25
DeadheadNM
Carpe manana
DeadheadNM's Avatar
What do you think they are???
