10-01-2017, 08:42 AM | #751 | |
Posted via Mobile Device |
10-01-2017, 11:08 PM | #752 |
60-66 Nut
Re: Power Steering Adapter Plates
If the water pump is the original for the '89 TA, it is a reverse rotation for a serpentine drive assembly.If you don't want to run a serpentine drive, you will have to change the water pump. At that point you may as well get a short water pump, which is correct for your truck.
10-11-2017, 09:11 PM | #753 | |
10-11-2017, 10:47 PM | #754 | |
10-11-2017, 11:34 PM | #755 | |
60-66 Nut
Are the power steering pump brackets you bought for a long water pump? If so they should work with that power steering pump. Does your water pump have a threaded boss or a smooth bore boss to hang the pump from?
I already replied to your PM. You do not need a steering box adapter plate for a '67 C series truck. Only for a K series truck. You have not said which one you have.
10-12-2017, 10:29 AM | #756 | |
10-12-2017, 10:31 AM | #757 |
10-12-2017, 10:35 AM | #758 |
10-12-2017, 11:44 PM | #759 |
60-66 Nut
Those brackets are typically used with a short water pump. If that pump works, I would just get the correct brackets for the application that you got the water pump for. It will depend on the threads or no threads in the boss I mentioned yesterday. Post a pic of the front of your engine on the drivers side.
10-13-2017, 10:18 AM | #760 | |
10-13-2017, 11:07 PM | #761 |
60-66 Nut
With a long water pump, the power steering pump hangs from a boss on the water pump. Some water pumps such as for a '76 will have a smooth bore in that boss. Others will have a threaded bore in that boss. You will need the correct bracket assembly for what you have on the water pump.
10-15-2017, 04:05 PM | #762 | |
10-15-2017, 11:24 PM | #763 |
60-66 Nut
I don't know what to tell you not knowing just which water pump you have. It might be easier to just get a short water pump as should be on your truck and then get a early pump. You may be able to use that chrome bracket you already bought. You will also need the correct pulley to drive the PS pump. Do you already have the alternator mounted?
10-29-2017, 10:22 AM | #764 |
I need power steering adaptor plate, steering shaft adapter and power steering pump mounting hardware for converting 66 Chevy C10 292 4.8L. I plan on 69 replacement power steering gear and pump for 1/2 ton. Can you send me a pm for ordering?
10-29-2017, 10:55 PM | #765 |
60-66 Nut
I do not make anything for mounting power steering pumps. I will send you a PM.
12-04-2017, 01:15 AM | #766 |
60-66 Nut
I have a couple of new steering couplers for sale. I have one that is 3/4"-36 spline and one that is 13/16"-36 spline. The cost is $45.00 each plus shipping.
12-12-2017, 09:34 PM | #767 |
got mine today as well as brake booster plate ,looks top shelf! thanks
12-13-2017, 08:17 AM | #768 |
[QUOTE=Captainfab;8061642]I don't know what to tell you not knowing just which water pump you have. It might be easier to just get a short water pump as should be on your truck and then get a early pump. You may be able to use that chrome bracket you already bought. You will also need the correct pulley to drive the PS pump. Do you already have the alternator mounted?[/Q
Captain, I have installed everything successfully. I ended up using an old style pump with those chrome brackets, and the long water pump. I reused the old pressure line and just made my own bends to accommodate with my set up and bought and used a new return line. Thanks for all the help! |
12-17-2017, 07:08 PM | #769 |
Ok, so I must have messed up somewhere. The Captainfab brack went on with no problem, great quality and template. My problem is that after cutting off 1 3/4" of the steering shaft like in the instructions show, it appears that it does not leave enough of the shaft to weld the original end/coupler and allow for the two coupling to tighten all of the way down.
I have not welded anything yet, but something appears off. |
12-17-2017, 07:41 PM | #770 |
I will go ahead and buy the extension tube/coupler. Will you send paypal request to jpayne_80@hotmail.com?
12-18-2017, 12:26 AM | #771 | |
60-66 Nut
I will have to calculate the shipping cost first as I do not typically sell the tube and flange separately. Send me a PM or a email with your zip code. If I were to send it in a medium flat rate box, that will cost $13.60.
12-23-2017, 05:22 PM | #772 |
Hi Cap, would like to order ur PS adapter for a 65 I just picked up.
Thanks & a very merry xmas. Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon 2008 Corvette convertible |
12-24-2017, 12:21 AM | #773 |
60-66 Nut
I'll send you a PM with payment info.
01-04-2018, 02:23 PM | #774 |
Captainfab do you ship up to canada?? Postal code is S7v0g5. Lookin for the ps pump bracket and tube. Also has anyone adapted the 73-87 stuff with an inline 6?? Mine does not have ps but trying to track down some factory ps brackets/pump for it. Its a 235 out of a 62 chevy 2
01-05-2018, 12:03 AM | #775 | |
60-66 Nut
Sorry but I do not make any power steering pump brackets, only the steering box adapter plates. For power steering pump brackets to fit your 235, check ebay and look for Davis Racing. They make some very nice power steering pump and alternator brackets for the I6 engines.
