12-15-2017, 10:37 AM | #1 |
Re: Let's Build A 1 Ton Crew Cab 4x4
Cool about the find. Not so cool about the crack. It's an NA motor then?
1972 K10 1986 K30 crew cab dually 2002 Z06 2007 Escalade |
12-15-2017, 11:00 AM | #2 |
Yeah I have always known my 96 6.5 had the hair line crack but gonna run it until it dies I guess.
The seller said it was NA setup that was going to be put into a suburban. I am not entirely sure what that means. I don't know that much about them. I just know it has the better design so would be better suited to build up to replace the one I am currently running.
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF 2020 1500 Silverado 3.0 Babymax 2002 2500 Silverado- 6.6/ Allison 2010 CTS V- The "NastyBuzzard" 1979 Trans Am - Eventually getting 6.0/T56 swap with boost |
12-22-2017, 10:24 PM | #3 |
82GMCK.. guess what issues I am running into...
Also! Screw (pun intended) that stock 6.5 FFM. I have a duramax one on the way! Any help or more insight on the plastic intake box meeting the cast air intake box of the banks setup? I remember you said it was a pain.
01-22-2018, 10:18 AM | #4 |
Stripping it down for paint! I moved everything but the cab and frame to my painters place last night. Super excited about the color change. We are stripping it completely down for the recolor.
I am also removing the dash to replace with one that hasn't been cut up and beat on, so that should be interesting.
