#401 |
Re: What did you do to your truck today part IV
(just the other day) I installed a much needed heater to keep the windshield from fogging up at night on these brisk LA winter nights
![]() ![]() ![]() ![]() Not pictured, but I ran some flexible hose from two of the ports up to the windshield defroster vents. Little heater works like a champ
- 1964 Chevy C10 "Honeydew" http://instagram.com/zachiatrist http://zachiatrist.com |
#402 |
"(just the other day) I installed a much needed heater to keep the windshield from fogging up at night on these brisk LA winter nights "
It is sure getting cold here I can almost see my breath in the air some mornings. ![]() |
#403 |
![]() Join Date: Jan 2017
you guys are killing me!!!
#404 |
Picked up a new to me hood for Our 63
#405 | |
![]() Join Date: Jun 2015
1961 GMC half ton, short step, Canadian model. Just starting work on it. |
#406 |
Thank you! My shift-boot-hat is always a hit. Yeah I'm working on gathering up all my past photos from when I got the truck up to now and making a sort of build/progress thread.
#407 |
Started the inside wiring fun now.
#408 |
![]() ![]() Join Date: Jul 2002
Some of that modern new-fangled techie wiring.
Nice looking job so far on it.
#409 |
Ahh I remember the good old days of wiring up the Dakota Digital box. Looking good man
#410 |
Dressed up my engine bay a bit with some aluminum stamped radiator support shrouds, carbon dipped plenum cover, and some raw aluminum coil covers
![]() ![]() The LS3 is tucked back there pretty tight so I had to make some cuts on each one to get it to fit against the firewall. ![]() ![]()
#411 |
Man, I'm loving your truck Zac. Are the rad support covers commercially available, or did you make them?
#412 |
I am next in line i need a set made. lol
#413 | |
I wish I had the tools to make them. But if you go modshopinc.net/store and search over on the left hand side under Radiator Support Filler Panels you'll find them there.. a few different pattern styles. They took a little massaging to get them to fit in perfectly, and I had to re-drill a couple of the pre-drilled holes to line up with the holes on my truck.. but nothing major. I also rivetted down the two front corners to keep them both snugged down and inline with eachother.
#414 |
Thanks for the info. I am going to get a set.
#415 |
I put some rust converter in my rear cab corner pockets. I am worried because it said to put on a second coat with in 20 minuets and after it turns black but it never turned black. I don’t know if it’s because the first coat was too heavy or because there was some navel jelly left on the surface. I hope not the latter. I tried to clean it off the best I could considering the location. I will see how it looks next weekend. I also found some rust on the interior where the door frame connects to the floor. Another set back
#416 |
Junior Member
![]() Join Date: Apr 2017
Changed the oil, love the old oil canister, and NAPA filter!
#417 |
swapped the p.o.s. POL lower control arms for some Ridetech StrongArms. Some of the best money I ever spent on the old girl. Went from feeling every single little bump and crack in the road to just gliding over it like driving on a soft pad of butter haha.
#418 |
Started making a speaker box in my kick board vents.
#419 |
Sorry for the sideways pic
#420 |
pulled the cab!
#421 |
Got the insides of my doors painted. Just need to do a final coat on the interior back walls.
#422 |
![]() Join Date: Aug 2004
I went to the paint shop a visited....got these pix
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#423 |
I put it up for sale.
#424 |
It's Better With Nitro
Brian Stoner of Stoner Pinstriping came back today to finish striping the tailgate. A few shots of his work today and the hood he did a few months back:
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
#425 |
![]() Join Date: Jan 2012
I finally got the front clip re-assembled completely. Now to take a break for awhile and then to tackle the cab.
