01-25-2016, 10:33 PM | #301 |
Vintage 4x4s
Re: 1971 K20- project just get driveable!!
I had a few days off over the holidays and had some time to work on this again. Since its winter I have time to be on the forum again I finally made a subframe for the Diamond 9ft plow and got it mounted. It was a lot of fabrication since I just had two small bracket pieces to start with. There is a lot of steel here, probably about 150lbs in total. Total plow weight is about 1000lbs!
Here is the subframe I built and the intermediate Diamond frame I sandblasted and improved. Last pic is just the subframe on the truck, so how it will look in the summer if I pop off the intermediate frame.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
01-25-2016, 10:42 PM | #302 |
Proprietor of Dale's Corner
Looks great, the fab work looks awesome
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
01-25-2016, 10:58 PM | #303 |
Vintage 4x4s
Thanks Dale! Here are some pics of it mounted and at work. I will make a new plow skin for it this summer, it has pretty serious rust on the blade still. These skyjacker 2.5 lift springs barely care this heavy plow is on the truck. Sure moves a lot of snow quickly. I do need to rebuild the front driveshaft, the cardan joint is clacking pretty loudly under load.
01-25-2016, 11:12 PM | #304 |
Yea nice fab work!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
01-26-2016, 12:06 AM | #305 | |
01-26-2016, 12:23 AM | #306 | |
01-26-2016, 12:49 AM | #307 |
6>8 Plugless........
Very nice work on the plow mount! How quick can you knock one out for a western or meyers?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-26-2016, 03:27 AM | #308 |
nice build on the truck, love the K20's
02-01-2016, 11:41 PM | #309 | ||
Vintage 4x4s
Thanks! I like your project too
Thanks, the K20's are my favorites
04-14-2016, 11:42 AM | #310 |
Second Chance Program
Updates?
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
01-16-2018, 12:40 AM | #311 |
Vintage 4x4s
Long overdue for an update. A lot of life has happened in the last year or so. More on that later.
Finally found a little time to work on the truck again. Yanked the engine out as it was only running on 7 cylinders and I never could get the one valve to seat and give good compression. As such, I have only been using it around the property and to plow snow. I did put another ochre bed on some time ago for a better paint match. Finally assembling and putting in a new crate engine that I ordered about 3 years ago. Here are some pics. Takes a little while to degrease the used manifold, spark plug shields, wire clips, paint the water pump, paint manifold, build a oil pump priming tool, round up the misc gaskets and rubber pieces. Anyways good to be back at this spare truck.
01-16-2018, 02:41 AM | #312 |
Good to see you're back on it.
01-17-2018, 01:04 AM | #313 |
Vintage 4x4s
Thanks Dale, glad to be back!
I was really struggling with not painting the engine orange but I figured this may be about my only truck that won't be fully stock looking so I might as well have a little fun with it. Got the new flywheel and clutch installed. This weird young cat now calls my place home. My friend found him starving and pretty wild on some property I own. We saved him and feed him well and now he is super grateful and just loves life. I'm trying to teach him not to be comfortable around vehicles but he just isn't getting it. If he survives to an old age I will be surprised.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 Last edited by Vintage Windmills; 01-17-2018 at 01:17 AM. |
01-17-2018, 01:17 AM | #314 |
Vintage 4x4s
Old engine out
01-17-2018, 10:19 AM | #315 | |
GEARHEAD
The new bed looks good. Much better match for color. Good luck with the break in. The last one I did went very bad. I get to build another engine! At least we're not getting much snow to plow so far.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
01-17-2018, 03:18 PM | #316 |
I think it looks good black. Great looking cat to keep you company too.
01-19-2018, 01:32 AM | #317 | ||
Vintage 4x4s
He is a bit odd, check out this pic.
01-19-2018, 01:53 AM | #318 |
What pic? LOL
01-20-2018, 12:25 AM | #319 |
Carpe manana
Hi Jud - great to see an update. Passed through Minneapolis last week and thought of you. Whats the cats name? Pete
01-20-2018, 11:10 AM | #320 |
Vintage 4x4s
Oops, was fighting the uploads. It is of Charles attempting a different grooming method. Also here is a pic of him in field find condition, before his “build”
Let me know next time Pete! Are you in town here for the Super Bowl?😀
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 Last edited by Vintage Windmills; 01-20-2018 at 12:01 PM. |
01-20-2018, 11:16 AM | #321 |
He looks much healthier and happier now.
01-20-2018, 02:34 PM | #322 |
Good to see your back at it. Was thinking about asking how the projects are coming along and your thread popped up again. How is the Cummins swap coming in the red square body? Still have the Longhorn in the herd? I found another one out in South Dakota and I got a thread on it in the 4x4 section called Big Bird.
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
01-20-2018, 07:59 PM | #323 |
Vintage 4x4s
Hi Nathan, I will check it out, always like to see other builds! Thanks for stopping in here. I haven’t done much on the Cummins truck but it’s moving up the list and the engine is ready. Still have the longhorn. We parked it down by the road and sold apples out of it. Here is a pic of it while being pulled down there. We really like the color of it. I almost forgot how beautiful MN is in October.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 Last edited by Vintage Windmills; 01-20-2018 at 08:10 PM. |
01-21-2018, 01:42 AM | #324 |
Vintage 4x4s
New engine sitting in place.
01-21-2018, 02:53 AM | #325 |
Looking good.
