01-22-2018, 08:05 PM | #26 |
Re: New To Me 2001 Silverado
Power where?
2001 Silverado 1500 1986 K20 1997 Dodge Ram 2500 1999 Dodge Ram 2500 2001 Dodge Ram 2500 |
01-25-2018, 12:19 AM | #27 |
I am sure he is asking if the INJ A and INJ B fuses have power when the key is on. ::EDIT:: the under hood inj a and inj b fuses.
which made me think of something if they do have power with the key on, check the bottom of the under hood fuse panel and see if all the large plugs are tight and the 7mm bolt in each is snug.
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
01-25-2018, 08:07 AM | #28 |
Both of those fuses have power, I havent got to mess with this week as much as I would like.
01-25-2018, 11:09 AM | #29 |
Check for power at pin D directly at an ignition coil(at the 4 pin connector, not the 8 pin)(use a test light between the pin and the negative battery terminal)
Do you have power? If you do, check for ground at pin A(use a test light between between the pin and the positive battery terminal) There is a ground that bolts to the engine block on the drivers side, about an inch above the oil pan. It is the ground for all 8 ignition coils. I've worked on 3 trucks that had the ground corroded inside that wire. |
01-25-2018, 11:11 AM | #30 |
I will try that today or tomorrow after work and let you know what I get.
01-27-2018, 02:59 PM | #31 |
On the 4 pin connector at the coil from left to right does it go pin ABCD? Or is there another order for it?
01-27-2018, 03:35 PM | #32 |
I'm not sure, but the power wire should be pink.
01-27-2018, 03:41 PM | #33 |
The pink wire has power
01-28-2018, 09:09 AM | #34 |
That's good. Does the pin on the other side of the connector have ground?
01-28-2018, 09:12 AM | #35 |
Everything is good but #2 the ignition control circuit. Im trying to trace that as back as I can.
01-28-2018, 01:55 PM | #36 |
Okay guys I've spent all day tracing wires in my engine harness. Every wire I checked between the coil packs and ECM had continuity so my thought was check wiring to the Crankshaft Position Sensor. It is 3 wire, 12 volt supply, triggering signal, and ground to ECM. I checked those wires and the only wire I could not get continuity out of is the 12 volt supply from the ECM. Can this be my whole problem? Will I be fine making a jumper wire from CKP sensor plug to the postive battery terminal to see if it starts without harming anything?
01-28-2018, 04:03 PM | #37 |
Well guys this was my problem, ran a jumper and plugged everything back in and the truck fired right up. So I will be de pinning that one and from CKP plug and ECM and running a new wire. Thank you for the help guys!
01-28-2018, 04:33 PM | #38 |
Glad you found problem. I am not a fan of electrical problems.
01-28-2018, 04:35 PM | #39 |
I hate them as well, this is my first really big electrical job. Im pretty pleased that I actually figured it out.
01-28-2018, 11:29 PM | #40 |
Good job! i will have to add this one to the memory banks for the future, I am sure this will come up again for someone, if not for myself.
01-28-2018, 11:30 PM | #41 |
Yes I thought so as well thats why I wanted to let everyone know the solution incase people on the internet were looking for this. Now on to more things with this truck!
01-29-2018, 10:50 PM | #42 |
Well now that I have my running issue solved I'm going to be looking into a cam, headers, exhaust, and possibly a stall converter. Im looking for any recommendations and advice from anyone whos done it to their trucks.
02-14-2018, 06:06 PM | #43 |
Well just a little update. I have been driving the truck and really enjoy it. But some of my parts are showing up and probably this weekend Ill be swapping these parts and getting a tune. Just incase anyone is wondering the headers are from Speed Engineering, seem to be very good quailty for the price. Also have my BTR truck cam kit and that will be going in as well. Also I am debating getting 243 heads and having them milled to get a smaller combustion chamber. But not sure yet at this point.
02-14-2018, 06:08 PM | #44 |
The last few for you guys.
