01-06-2017, 11:54 PM | #126 |
Equal opportunity joke ofender
Re: NJ Suburban
Looking good Paul. Did you find the inner 1/4 pc. you were looking for? I just picked up 2 parts burbs and I will check them out to see if either has a decent pc. if you are still in need. Pending snow this evening may hang me up a little but i will check 1st chance I get if you do need it.
Richard
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
01-07-2017, 10:59 AM | #127 |
Re: NJ Suburban
Nice progress.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-07-2017, 01:48 PM | #128 | |
Re: NJ Suburban
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
01-07-2017, 10:11 PM | #129 |
Re: NJ Suburban
looking good
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
01-08-2017, 04:14 PM | #130 |
Re: NJ Suburban
Thanks guys!
Glad it is inside now so it can get some work done! Paul
02-06-2017, 09:49 PM | #131 |
Re: NJ Suburban
More bodywork. With the mild winter here in NJ the usual 5 snowblower repairs a week I saw last year are non existent this year. The plus is lots of Suburban time in the garage.
The inner part 3rd door rocker that is part of the floor was a pain to fabricate. Glad I saved the entire roof of my original Suburban for sheet metal repair material. This weekend I'll paint everything inside with either POR15 or epoxy primer and then weld on the outer rocker and the quarter panel patch! Paul
02-09-2017, 07:09 PM | #132 |
Re: NJ Suburban
All the treated rust and homemade patch panel primed with KBS. I need to collect the door from storage and re hang it before welding in the new rocker and lower quarter piece. I'm sure my storage garage isn't plowed out yet! We got about 8" here in NJ last night. I'm loving my garage heater!
Paul
02-11-2017, 01:45 PM | #133 |
Re: NJ Suburban
Nice work!
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
02-11-2017, 07:18 PM | #134 |
Re: NJ Suburban
staying warm making progress looks great Paul
02-12-2017, 07:37 PM | #135 |
Re: NJ Suburban
And more progress! Welded in the quarter patch. Once it is epoxy primed and seam sealed I'll weld in the rocker.
Paul
02-12-2017, 07:45 PM | #136 |
Re: NJ Suburban
Moving right along, looking good. I can't seem to find time to work on any of mine, too busy cutting up parts trucks.
Was this pretty much the bulk of the metal replacement or do you need to do driver side as well? Richard
02-12-2017, 07:50 PM | #137 |
Re: NJ Suburban
Richard both front rockers still need to be done as well as the driver side lower quarter. There is still a long way to go! I got the rocker inner and outer panels but they will need a lot of fabricating since they are pickup parts. The door had to come out of storage so that I could match up the body lines. Spent all morning fussing with the alignment!
Paul
02-12-2017, 08:11 PM | #138 |
Re: NJ Suburban
I was going to say, the door alignment looked better than factory. Good job.
I should ask, does that patch have the bead edge or no? I bought a slightly larger patch and it has the beaded edge but the rest of the wheel arch patch does not. I am trying to figure out how I am going to make it look right.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe Last edited by Bigdav160; 02-12-2017 at 08:16 PM. |
02-12-2017, 11:25 PM | #139 |
Re: NJ Suburban
Dave the beaded edge matches the factory edge pretty well. I saw your post with your patch and the issues you are having. I think the wheel arch patch that LMC sent has the beaded edge but I'll have to check. Years from now I hope I have the patience to align the door again!
Paul
02-19-2017, 02:51 PM | #140 |
Re: NJ Suburban
Got the panels welded in epoxy primed and seam sealed. Tomorrow I'll shoot the sanding primer. I've got some warpage in the rear quarter but I'm really happy with the panel fit.
Paul
02-19-2017, 11:09 PM | #141 |
Re: NJ Suburban
LOOKING GOOD Paul
post good notes cause Ill be needing all the reference I can find. lol
70 c10 2wd crashed Suburban 67 c10 2wd sb truck 67 c10 4wd lb truck |
01-19-2018, 11:19 PM | #142 |
Re: NJ Suburban
Wow it's been a while!
Got some work done on the front right side this past week. It will get a coat of epoxy primer before the rocker goes on. Paul
01-19-2018, 11:22 PM | #143 |
Re: NJ Suburban
looks good Paul i been making some progress myself ...you around this weekend come get my saw
01-30-2018, 10:45 AM | #144 |
Re: NJ Suburban
Nice job on the repairs.
02-04-2018, 06:08 PM | #145 |
Re: NJ Suburban
Thanks! Made a little more progress. The right side is done. Time to turn it around and work on the left side now!
Paul
02-04-2018, 06:50 PM | #146 |
Re: NJ Suburban
02-04-2018, 07:12 PM | #147 |
Re: NJ Suburban
great work Paul!! thanks for the recent chat, helped me out a bunch!
I chickened out though and found a very little rust Fremont burb a couple of hours from here.. seller and I worked out a real fair deal and I think we both did good.. I'll get a thread going sometime to share with everyone as I move out of 'ol rusty blue.. please keep up the good work in the fight against rust and keep us all posted!
I started out with nothing - and I still have most of it |
02-04-2018, 11:15 PM | #148 | |
Re: NJ Suburban
Paul
02-17-2018, 02:22 PM | #149 |
Re: NJ Suburban
Getting ready to prep and prime the cowl and windshield area. The plan for the rust on the window frame is to treat and paint it with POR 15 and hit it with the Omni epoxy primer while the POR is still tacky. It's already been wire brushed with my 4" and die grinders.
Paul
02-17-2018, 11:55 PM | #150 |
Re: NJ Suburban
Nive work!
I am dreading pulling my windshield. I know there is some rust. I just hope it doesnt require too much surgery.
