Old 01-23-2018, 11:10 PM   #101
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Let's play name that part, bolt, harness, screw....
Originally Posted by cheyenne shortstep View Post
Here's one for ya, it has nothing to do with the radio knob I just used it for size reference.
Hmmm. Honestly no idea....brake related for 67-68?
Old 01-24-2018, 12:06 AM   #102
Curtb1971
Curtb1971's Avatar
Yet, another brain stumper for me. I'm leaning towards an e-brake cable part, but I honestly have no clue.
1971 LSX "Bonnie" build thread
http://67-72chevytrucks.com/vboard/s....php?p=8026381
paypal is curtbarton1971@yahoo.com
Curtb1971 is offline   Reply With Quote
Old 01-24-2018, 01:56 AM   #103
cheyenne shortstep
cheyenne shortstep's Avatar
DeadheadNM & Curtb1971, sorry but neither of you are even close. It's part of a fairly uncommon option.
cheyenne shortstep is offline   Reply With Quote
Old 01-24-2018, 02:57 AM   #104
randy500
because It’s an uncommon option I would guess cruise control part.
randy500 is offline   Reply With Quote
Old 01-24-2018, 12:41 PM   #105
davischevy
davischevy's Avatar
I don't recall ever seeing one.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 01-24-2018, 12:51 PM   #106
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Throttle arm?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 01-24-2018, 01:08 PM   #107
leddzepp
Moderator
leddzepp's Avatar
Carb mount for manual throttle
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 01-24-2018, 04:36 PM   #108
cheyenne shortstep
Ding, ding, ding!! WINNER WINNER leddzepp got it. The bracket that attaches to throttle arm for 67-70 manual throttle.
Old 01-24-2018, 08:42 PM   #109
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Good job Zep, Iron too. Looked like potential throttle, but I've never seen one.
According to my mostly unmolested 71 C-10, 2WD, these were used to mount two items:
Over the top trivial probably. At a second glance, I had these bolts on three parts. There's another version of the same bolt stamped with a circle.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-25-2018, 09:36 PM   #110
69-72
69-72's Avatar
Any idea what these ac brackets fit? Early small block? Aftermarket? Pulley is larger than usual as well. I’m pretty sure it came off a 67-72
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 01-28-2018, 03:30 PM   #111
71CHEVYSHORTBED402
No takers on that L8 bolt I see. Well, how about this washer?
Tony
Old 02-07-2018, 08:19 PM   #112
71CHEVYSHORTBED402
No takers on the L8 bolt and flat sides washers I see. So I'll give it away for edge-u-cationals. These come off a 71 C-10.
The L8 bolts mount the steering box. They also mount the upper control arm support to the wall of the frame, which screw into the fixed square nuts on the support..............I also found one for the upper control arm to frame. In that case GM was using up bolts, I ended up with three types.
The flat sides washers are used to mount the engine crossmember to the bottom of the frame. Two are used for each bolt (=12). On a side, I was surprised to see the application didn't have lock washers or lock nuts. Just plain regular nuts. I checked the assembly manual to confirm, but came up empty. Probably missing it.
Perhaps some takers on this stud. Can't speak for prior to 1971, but I can say the 72 BBC doesn't use one (hint)
Tony
Old 02-07-2018, 08:29 PM   #113
leddzepp
Moderator
leddzepp's Avatar
That stud is used for the heat shield mounting on the driver exhaust manifold, also used for mounting a small block AC bracket to the other exhaust manifold.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 02-07-2018, 08:43 PM   #114
71CHEVYSHORTBED402
Possible but I don't believe so. At least not for a BBC. The studs you're referring to are 3/8" on both sides for BBC, and the nuts aren't flared. Not on mine anyway. The exhaust manifold studs on my 402 were placed into the front bolt hole of each manifold. One for A/C, the other for the upper power steering bracket.....................Could be variances, and I can't speak for SBC. Can't speak for a heat shield either. Spark plug?
Edit, I might be wrong about 3/8 both sides........Pending.....Edit again, confirmed, 3/8" both sides. Another clue, the stud in post 113 was not on the exhaust manifold.
Tony
Old 02-08-2018, 01:39 PM   #115
71CHEVYSHORTBED402
Okie Dokie, I'll give another one away. The stud goes to the front hole in the intake manifold on the LH side for the top alternator bracket on a 71 BBC. I assume prior years as well, but the 72 uses a different set-up.
Tony
Old 03-12-2018, 12:43 AM   #116
Curtb1971
Curtb1971's Avatar
Pulled a front bumper of a unmolested 72 the other day and it had L8 bolts that attached the bumper brackets to the frame. Is this where your had the third option?
Old 03-12-2018, 12:58 AM   #117
Curtb1971
Curtb1971's Avatar
Here's a fun one. Name that part!
Old 03-12-2018, 01:25 AM   #118
leddzepp
Moderator
leddzepp's Avatar
7/16 - 20 fine thread bolt used for 67 seat belts. Also used for shoulder belts all years 67-72
Next
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 03-12-2018, 01:49 AM   #119
Curtb1971
Curtb1971's Avatar
Next
Dang leddzepp! Knocked that one out of the park
Old 03-12-2018, 11:06 PM   #120
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Nice work Scott. Good to know these are correct for shoulder belts also.
Old 03-12-2018, 11:21 PM   #121
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Anyone recognize these? There are two different size screws shown.
Old 03-13-2018, 12:16 AM   #122
John H.
John H.'s Avatar
Larger ones with shoulder are door lock to door screws.
John H. is offline   Reply With Quote
Old 03-13-2018, 12:18 AM   #123
John H.
John H.'s Avatar
How about these two pieces?
Old 03-13-2018, 12:29 AM   #124
Curtb1971
Curtb1971's Avatar
Are the small ones are for wiper transmission to inner cowl?
Old 03-13-2018, 01:06 AM   #125
toolboxchev
Attachment 1762998
tool box
toolboxchev is offline   Reply With Quote
