02-12-2018, 12:04 PM | #1 |
Steering Wheel Compatibility
I'm one of those weirdos who likes the large size of the original steering wheel on my '72 C20. Unfortunately, the sun turned it into chalky gravel and I'm looking for a replacement. I don't like the price of the reproduction ones and the only other options I can find that big are for semi trucks. I was looking at the link below, but they only list an adapter for '74+ Chevy trucks. What is the difference? The spline has 36 teeth (unless my thumbnail skipped) and it's roughly 7/8"
Picture of my column: https://drive.google.com/file/d/17P8...ew?usp=sharing Hopeful Replacement: https://www.raneystruckparts.com/18-...teering-wheel/ |
02-12-2018, 12:27 PM | #2 |
Re: Steering Wheel Compatibility
Im unsure of the exact years but it could be all the way to present that GM steering wheels interchange, spline size and count, 1955 or so to present.
The best fit is smaller diameter hubs from chevy cars without the key on the column. The difference in column diameter is about 1/4" or so therefore its not real noticeable. |
02-12-2018, 01:07 PM | #3 |
Old member
Well if you want some idea's here are a few. I know that work and they are about the same sizes.
1-2 wheels are 63/64 Impala. 3rd is a Corvair wheel are Camaro depending on the center cap you choose. 4th is a 67 truck wheel. Last picture is a 67 SS Chevelle wheel in my 71 C10. They all work on either the Impala shaft are the truck shaft.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-12-2018, 01:20 PM | #4 |
I just took a 80s 1500 pu wheel off. Same as the 67.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
02-13-2018, 02:43 PM | #5 |
I have a 61 Chevy Impala wheel in my 71 truck. Restored and painted to match the truck. Never could get the horn to work but at my age I ain't doin no honkin.
4oldcars Driving: 1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado The ones I let go: 1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed |
