02-13-2018, 03:38 PM | #1 |
which rad did I have - 3 row or 4 row?
I sold my radiator over a year ago and can't remember what it was. I checked my SPID to see if I had a heavy duty cooling option (if that existed then) but didn't see one. BUT, I need to order a new rad soon and have to know if I have mounts for a 2/3 row or a 4 row. Can anyone tell by these measurements of the bottom mounts?
thanks!
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
02-13-2018, 04:06 PM | #2 |
Re: which rad did I have - 3 row or 4 row?
Looks like 2-3 row rad
02-13-2018, 04:17 PM | #3 |
Vendor can tell you
Stan 67 swb BLU MULE posted via flip-fone |
02-13-2018, 04:56 PM | #4 |
02-13-2018, 04:59 PM | #5 |
Yeah, I'll get a confirmation when I order.
What would I have to do to change them over? Are there simply new brackets available? I have a lot of horsies to keep cool. thanks
02-13-2018, 05:17 PM | #6 |
Several options and ways to go, depending on how much $$ want to spend, how close want to stay original in look and style, plastic / aluminum rads thru most parts stores are cheaper but then to me, so is the look.
I converted my '71 4x4 from 3 row original brass/copper to original HD brass/copper 4 row years back and never regretted the expense. Was not really costly at time but could be a bit more now. Since your a paid subscribing member watch the For Sale ads, 4 row rads do show up from time to time in various states of use. A re-core is not cheap but I did that for my '71 Chevelle when had the 4 row brass / copper re-cored. If go to a 4 row watch for upper and lower rad brackets to show up in the parts section. New rubber cushions are available as are re-production 4 row brackets. Choices, choices, choices to be made. Be sure you do a good fan clutch and metal fan. Don't go the flex fan route. Also a good fan shroud is a must for proper cooling. Just some thoughts and my $0.2 Good luck on your decision.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
02-13-2018, 08:09 PM | #7 |
It’s actually an LS swap rad I’m shopping for. Just trying to pick a vendor/manufacturer. Got the fans spec’d out- a pair of 12” spal in a factory looking shroud.
Appreciate the input!
02-13-2018, 09:24 PM | #8 |
I am a Referee of life.
The brackets for the factory 4 row are available from any of the vendors. The bottom ones have to be cut off. IIRC I ground a rivet to get them out, then redrilled the holes for the 4 row bottom brackets and bolted them in. The uppers have to be replaced (in the wider mounting holes. also as do all the rubbers. Someone probably makes a radiator to fit this swap.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
02-13-2018, 10:06 PM | #9 | |
02-13-2018, 10:25 PM | #10 |
I really like the Entropy LSX radiator on my 68 C-10. They can build it to work with the 3 row or 4 row mounts. Just need to let them know how you want it setup. It fit really well and have been pleased so far (just got the engine running).
02-13-2018, 10:44 PM | #11 |
I purchased the same one (4 row mounts) and was happy with the install. Also they have great customer service as well.
1971 LSX "Bonnie" build thread http://67-72chevytrucks.com/vboard/s....php?p=8026381 paypal is curtbarton1971@yahoo.com |
02-14-2018, 07:09 AM | #12 | |
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 Last edited by NC_John; 02-14-2018 at 07:15 AM. |
02-14-2018, 10:38 AM | #13 |
If you order their LSX radiator the only difference is the mounts. It is the same size / duty radiator. They do have options to go to bigger radiators for those that are running 1,000 HP and have options on the fans.
02-14-2018, 10:45 AM | #14 |
Pictures always help . . . and these are the best ones I had available. I painted my radiator with Eastwood radiator flat black spray paint. I took the fan shroud off to paint it in pieces.
02-14-2018, 04:15 PM | #15 |
OK, that makes it easier. I'm thinking of getting their rad without fans (which they confirmed they will do) and installing the 12" spal fan setup from Old Air. I want spal fans and their setup makes is look fairly stock.
02-14-2018, 04:16 PM | #16 |
That looks great. Nice truck. I used the same paint on my previous radiator after having it rebuilt.
