02-16-2018, 01:46 PM | #1 |
425hp409
My truck sits too high
When I restored my truck, i replaced the rear springs because they had sagged and the center coils were sitting on each other. It now sits too high, like an original truck with the original type overload springs that I installed. Does anyone make lowering springs, or can I install air bags in the original spring perches? Or should I get the torch out and "lower" the springs?
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
02-16-2018, 01:57 PM | #2 |
Re: My truck sits too high
Here is Summits listing on some of what you can get. About a 3" spring would get you sitting level.
Jimmy https://www.summitracing.com/search/...rder=Ascending
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
02-16-2018, 02:56 PM | #3 |
02-16-2018, 06:45 PM | #4 |
What springs did you put in it?
Jimmy
02-16-2018, 08:19 PM | #5 |
425hp409
Stock GM that were like the original overload ones. They had wide coils at the top and bottom and narrow coils in the middle.
02-16-2018, 09:00 PM | #6 |
Don't use a torch, use a cut off wheel. You could cut one coil off and see where it puts you. Free to try out.
02-16-2018, 09:55 PM | #7 |
Negative. I wouldn't cut the rear springs. You lose the pigtail when you do that and then have no way to retain the spring. Now the fronts on the other hand, you can always hack a coil off of those!
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
02-16-2018, 11:44 PM | #8 |
I would leave at that it looks a truck is suppose too. they sell them little fiats everyday they sit low
4x4k30 if trouble was money i would have plenty |
02-17-2018, 02:34 AM | #9 |
and they make a virtual bolt in rear air bag kit for trailing arm rear ends .
i like a bit of rake tho .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
02-17-2018, 05:57 PM | #10 |
I was more interested in who made the springs and maybe a part number. Some of the aftermarket springs they list as heavy duty are for use in a suburban. They have a higher spring rate and will sit really tall in a truck. This may be the issue you have. You may want to try just a set of standard truck springs and see how that works.
Jimmy
02-18-2018, 12:28 AM | #11 |
that's a really nice truck you got there....and I always like those old dealership bumpers....
it does look like it needs to come down a couple inches.....
