Closed Thread
Old 02-15-2018, 01:59 PM   #6326
VWNate1
VWNate1's Avatar
Re: What did you do to your truck today? Chapter II
Seven leaves in the springs ? .
Are you planning to work this rig ? or maybe tow with it ? .
Good on you if so ! .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 02-16-2018, 09:25 PM   #6327
mud.man.rj
mud.man.rj's Avatar
Rear disc, 3/4 ton, nice.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 02-17-2018, 08:47 PM   #6328
Trackbar
Trackbar's Avatar
Got the front end all done and back on the ground.
Trackbar is offline
Old 02-18-2018, 06:24 PM   #6329
mud.man.rj
mud.man.rj's Avatar
Big step, nice job.
Mudman.
5.0 4spd std.
7" lift w 35's.
Old 02-18-2018, 10:07 PM   #6330
Mts67C10K20
Mts67C10K20's Avatar
This truck will be working not just looking pretty
She was a field fire truck
I took 2 springs out to get to seven
Today I started on the front
Mts67C10K20 is offline
Old 02-18-2018, 10:16 PM   #6331
VWNate1
VWNate1's Avatar
Thumbs up Working Rigs
This is very good to hear ~
Having a shiny truck is nice but never actually using it seems silly to this old farm boy .
I was at an auction where there was a nice one ton stripper long bed step side for sale ex L.A.F.D., it had low miles and ran great once jumped .
Just as it came up for bid SWMBO called and said 'I'm locked out, come home and let me in now please' so I missed it .
It was yellow and white, original fleet paint .
-Nate
Geezer
VWNate1 is offline
Old 02-18-2018, 10:24 PM   #6332
ripper70
ripper70's Avatar
Installed my tubs and bed pan pieces I polished with my son today
1970 K20
1967 Blown Stepside
2016 Chevy 2500 Duramax
1989 Jeep Cherokee
1995 S-10
2014 Infinity Q-50 AWD
1970 Chevy K20 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=634164
1967 stepside rebuild
http://67-72chevytrucks.com/vboard/s...d.php?t=684913
Shop build http://www.garagejournal.com/forum/s...d.php?t=225559
ripper70 is offline
Old 02-18-2018, 10:50 PM   #6333
HO455
HO455's Avatar
I have reposted this from my "fix it up" thread because I'm pretty happy finding out it is a local truck (fifty miles away) and the dealership is still alive (In a new location.)
"I got lucky last night in the good way. The PO had half dozen or so old truck part catalogs along with a box of receipts he gave me when I got the WMB. I had looked through the box of receipts but hadn't paid any attention to the old catalogs. I was in the process of tossing the catalogs last night when I noticed there was some thing stuck in the middle of one of them.
Score baby! I was so close to tossing them away!"
RIP Bob Parks.
HO455 is offline
Old 02-19-2018, 12:30 AM   #6334
B Myers
B Myers's Avatar
Installed a Edelbrock air gap intake and a Holley Sniper kit. Still getting the setup and learn process perfected. [ATTACH]Name:  7D4958FC-7FA9-4C6C-B9DD-AA5D2C054695.jpg
Size:  64.0 KB[/ATTACH]
B Myers is offline
Old 02-19-2018, 01:43 AM   #6335
3757chevy
3757chevy's Avatar
I did a trans filter change and upgraded the vacuum modulator from the old can type on my '67 step side . Then went to the car wash, gas station and drive with better half. Should have done that a long time ago . Apparently it needed to be done .
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline
Old 02-19-2018, 04:39 PM   #6336
Metaldoc
Metaldoc's Avatar
Engine is out
Metaldoc is offline
Old 02-21-2018, 09:35 PM   #6337
JMD
JMD's Avatar
Took advantage of the warmer weather to pull the front clip in preparation for removing the engine and transmission. Taking the whole clip off as one piece was pretty simple with a friend helping me lift it off the frame. We'll see how it goes putting it back on...Might need a 3rd or 4th person to help line things up.
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296
JMD is offline
Old 02-21-2018, 11:08 PM   #6338
MikeB69C10
MikeB69C10's Avatar
Power steering added and saddle tanks removed.
MikeB69C10 is offline
Old 02-22-2018, 01:22 AM   #6339
3757chevy
3757chevy's Avatar
Looking good JMD ,well organized I like. what are your plans?
MIKE
Old 02-22-2018, 09:33 AM   #6340
JMD
JMD's Avatar
Thank you. I'll be replacing the worn out TH350 transmission with a TH400, rebuilding the transfer case, fixing an engine oil leak, and adding a fan shroud. If time and money permit I'd also like to add a more aggressive cam and possibly heads to that list but we'll see.
JMD is offline
Old 02-22-2018, 12:58 PM   #6341
toolboxchev
Took her out for a drive to Eat some Meat at the local gathering place.
toolboxchev is offline
Old 02-22-2018, 01:30 PM   #6342
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
? A meet & greet and you didn't get any pictures ? .
Sad face here .
-Nate
Geezer
VWNate1 is offline
Old 02-22-2018, 05:24 PM   #6343
57Suburb
57Suburb's Avatar
So I refinished my utility bumper.
1972 C30 Grain Hauler, 350/400
1967 1500 GMC Stepside SWB, In Transformation Process
1967 RS/SS Camaro 350/TKO600
57Suburb is offline
Old 02-22-2018, 11:20 PM   #6344
66clow
66clow's Avatar
Simply changed the speedo cable a couple weeks ago created a mess. Ended losing about 2 quarts of fluid in the driveway mostly in a pan at least. I guess the seal tore installing the new cable and I didn't realize it. Bought a new bullet but pulling the old one out most of the trans fluid drained out. Guess I'll just do a fluid change.
66clow is offline
Old 02-23-2018, 06:10 PM   #6345
mikecaddy500
mikecaddy500's Avatar
Nice truck! Too nice to be a michigan truck.
mikecaddy500 is offline
Old 02-23-2018, 07:39 PM   #6346
197D_C10
197D_C10's Avatar
I had some new shoes put on the truck today.
197D_C10 is offline
Old 02-24-2018, 04:48 PM   #6347
mikecaddy500
Nice truck! doesn't look like a typical michigan truck.
Old 02-24-2018, 06:41 PM   #6348
beaterku
beaterku's Avatar
Made decent progress on the leaf to coil spring conversion today. It back on the ground temporarily. The conversion is complete! I put it on the ground to check driveshaft clearance on the crossmembers. It's clears no problem. I still need to get the truck on the lift to see what is going on with the trans mount. It is sitting off to the drivers side. I broke it all back down to do touchup on the frame paint. I also decided to remove the stock leaf hangers. I ran out of time today, but should be able to work a few nights this week. Also installed the 1310 to 1330 conversion u-joint.
beaterku is offline
Old 02-24-2018, 08:32 PM   #6349
andrewpclayton
andrewpclayton's Avatar
HEI ignition! Pretty straightforward install
1977 SWB (c20 conversion) SBC350
Springfield Oregon
Instagram: @nevernotchevy
andrewpclayton is offline
Old 02-24-2018, 09:52 PM   #6350
Baker72chevy
Put pulleys an brackets on today clean and painted
Baker72chevy is offline
Closed Thread
