02-12-2018, 03:36 AM | #1 |
Vin number on frame?
I've read here that part of the VIN number is stamped on the drivers side of the frame near the power steering pump. I've look in that area and can't find it.
Is it stamped on the outside of the frame or the inside of the frame.
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
02-12-2018, 04:30 AM | #2 |
Re: Vin number on frame?
Stamped on top of the frame adjacent to or slightly forward of the power steering pump, #'s are parallel with frame rail. May have to wire brush a little to reveal it. Mine was not noticeable either until wire brushing and sanding lightly.
02-12-2018, 08:24 AM | #3 |
Stamped on top of frame, near ps pump toward cab on my 71, probably hidden by inner fender. Also on frame under cab, about the center top.
02-12-2018, 09:47 AM | #4 |
BlahBlahBlah
I don't know the definitive answer on this, but Ive read on here many times that not all the GMC's have frame stamped partial vins.
… … … … … … … … ... … … … … … … … … … … … Monroe Swap meet May 18-19. Mike has the same spots for the NW guys he's had forever. Lunch time BBQ at the spaces. If you have stuff to sell bring it along. If you have a question PM stllookn (Mike) here via the board. https://67-72chevytrucks.com/vboard/...d.php?t=851291 |
02-12-2018, 02:04 PM | #5 |
My 67 GMC had no numbers on the frame
02-13-2018, 10:49 AM | #6 |
My 67 gmc did not have any either
02-13-2018, 02:42 PM | #7 |
Inner fenders have been removed. Frame has been cleaned and painted. I still can't see any numbers. I can easily see the top of the frame in the area ps pump and to the cab.
02-13-2018, 04:52 PM | #8 |
I have a '71 GMC with no frame numbers. I'm guessing not all GMC's had them? My '70 Chevy is stamped.
02-20-2018, 07:48 PM | #9 |
72 with a frame stamp near the power steering box as described.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
02-20-2018, 07:51 PM | #10 |
Is that on the top, inside, outside oe bottom of the frame?
02-20-2018, 10:46 PM | #11 |
top of the frame.
