#101 | |
high-Tech Red Neck
Re: Anyone running CB's in their truck these days?
![]() IMHO the best route is a "screwdriver" antenna. It is a tunable antenna that uses contacts on a motor driven coil to change the impedance of the antenna. With that setup you can hit stations that are as far away from the west coast as Japan, Hawaii, Russia, it will really get out! ![]()
"He used to be a pretty nice feller, now he's a welder!" |
#102 |
![]() Join Date: Feb 2001
Its time to simmer down ... wrong attitudes are a no no.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#103 | |
![]() Join Date: Oct 2009
#104 |
So you think I am the only one that needs to simmer down?
Brian Ritter |
#105 |
Old Duffer
![]() Join Date: Mar 2003
And here I am, late to the party again!
![]() I did some serious soul-searching before I drilled the holes for the mount, but figured worse-case scenario I may have to repair them at some time, or, just leave the radio there. Not the end of the world either way. Ran the antenna wire back to the headache board, installed a bracket there for the whip. Only downside was I had to run a ground wire back to the cab just to insure a good ground. In the first photo the white speckles on the headliner are reflections from the radio knobs. In the last image the antenna has been removed (quarter-twist) so it didn't get bent up going in the garage.
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
#106 |
In my comments Yes!
#107 | |
#108 |
![]() Join Date: Aug 2014
Slomotion I think I know the answer but will ask anyway. Why did you mount the cb were you did ? I’m thinking because of the shifter and it (CB) being in the way ?
Im building the same truck as yours and have looked at pictures and have studied your truck to get ideas for mine. Very nice by the way. |
#109 | |
Old Duffer
Thank you 70cst! Thank you Rods! You're right, under the instrument panel was not very convenient, and the mic cord and shift lever would have been wrestling each other all the time ![]()
#110 |
Any recommendations on a decent antenna for a 40 channel radio shack cb. Going on a 1969 GMC C2500.
#111 |
high-Tech Red Neck
I have always loved the Firestix 2's, tune em up with an SWR meter in an open field, and you will get out well with them.
#112 |
![]() Join Date: Jul 2001
Noah, I used a pair of twin "Hustlers" when I was doing the CB bit. Got out well with them. Not sure if still have them in the garage or not. Could look and see if still have them. Think they were 40'' long if I remember. Ran them with a splitter for the two antennas.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
#113 |
I like the dual antenna look on the mirrors like semis had, but always though that you needed to be as wide as “semi truck” distance mounting separation for them to actually be more advantageous than a single antenna(??)
#114 |
high-Tech Red Neck
if you have the west coast style mirrors you can mount them where the mirror ties into the main mount tree, that will work just fine, will be about the same width as on a semi.
#115 | |
![]() I will be mounting Twin Antenna ...
#116 | |
#117 |
#118 |
high-Tech Red Neck
![]() I am playing around with an idea for hiding the screwdriver element inside of the bed and using a long whip like on the Fall Guy truck.
#119 |
![]() Join Date: Feb 2002
Mr Beast, I seem to recall a device [black box] that was cut-in to the coax of one side of a twin mirror mount -- which by tuning a variable capacitor -- could sweep the focus of the bi-polar pattern into a directional array. The nominal radiation of ''rabbit ears'' was a figure eight, but changing the signal could make it cardioid, and also onmidirectional.
For on-highway use, the fore-and-aft signal of the bidirectional set up is probably best, but a variable sweep function is interesting. Is there more to it than just a variable capacitor? I remember proprietary black box devices being available, some decades ago.
#120 | |
high-Tech Red Neck
On my sailboat I have an Isolated backstay with a tuner on it that really works well, I have talked to Japan and Alabama with it from Puget Sound.
#121 |
Any others have a CB in their Truck?
#122 |
![]() Join Date: May 2012
I always liked a whip. I've tried to find the military style 'S' clips to hold an antenna whip down. You would clip upper clip in the bush so if antenna gets caught on a branch it pulls off and breaks away. In city(MOUT) you clip under so antenna cannot accidentally come loose and catch a power line. I always thought that was clever. You would get a serious reprimand in the bush with using an under clip(Potential to break the whip) or over clip mount on highway(potential for catching a power line). If you broke a whip in the bush you had some splainning to do!! Always looked for a civilian equivalent but never found one. Here's a pic below.
I stayed clear of this thread because I knew it would make me want a vintage CB, yet here I am... I want! ![]() j
White K20 |
#123 | |
23 Channel CB's which are period correct for our trucks .. are cheap to purchase unless you go after the high end radios ...
#124 | |
https://www.cobra.com/products/professional/29-ltd j
White K20 |
#125 | |
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 02-23-2018 at 09:31 PM. |
