Old 03-03-2018, 10:56 AM   #1
manimal
manimal's Avatar
Lets talk Catalytic Converter positions
On my 94 Suburban 2500 7.4, 2wd, my cat is AFTER the muffler just before rear axle. It looks fairly new, but my smog test, I just squeaked by by points of failing on 1 part(i will have to look which one).
I thought a cat needed to get HOT to be efficient? If I put in closer to the front, where does it go?
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 03-03-2018, 10:58 AM   #2
b454rat
Re: Lets talk Catalytic Converter positions
It should be ahead of the muffler. I'm surprised it passed, as strict as they are. They are staggered on the pass side, under the foot board/seat.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 03-03-2018, 11:19 AM   #3
manimal
manimal's Avatar
Mine is a single(94). the y-pipe is stock and has not been cut. I have seen a couple others this way, but I dont understand the reasoning behind it. I plan on moving it forward, but need to see pics of stock locations.
-Lance
Old 03-03-2018, 02:08 PM   #4
Tom
driving is in my blood
Tom's Avatar
No oem cat has ever been installed after a muffler, period.
I have the oem service manual, all 4 books and like 3000 pages worth.
Old 03-03-2018, 04:42 PM   #5
95 S_Trucker
95 S_Trucker's Avatar
Every 92-95 3/4 ton suburban that I have worked on had the cat at the rear behind the muffler.
95 S_Trucker is offline   Reply With Quote
Old 03-03-2018, 05:14 PM   #6
manimal
manimal's Avatar
Is there a reason they are behind the muffler? Can they be put in FRONT like all the others? Or is something in the way or what? I looked under mine and dont see any reason it cant be moved, but GM did this for a reason that I dont understand.
-Lance
Old 03-03-2018, 05:41 PM   #7
Mr_Rich
Mr_Rich's Avatar
That really defies logic since a cat has to reach a certain temperature before it will even work. The only unit I'm aware of installed after a muffler is a resonator.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 03-03-2018, 06:11 PM   #8
95 S_Trucker
I'll get some pics of my walker catalog when I'm at work on Monday.
I should have clarified earlier, the only ones I work on are big blocks. Small blocks may be different.
Old 03-03-2018, 09:31 PM   #9
1968k20
1968k20's Avatar
My '89 K3500 Single cab/single rear wheels has the cat behind the exhaust near rear axle
1977 Chevrolet K10 SWB Project 350/4spd/np205
1977 Chevrolet K20 LWB 350/350/203
1991 4Runner 22RE 5 SPD
Yanmar Tractor 3 Cyl Diesel
1968k20 is offline   Reply With Quote
Old 03-04-2018, 08:33 AM   #10
b454rat
I had 2 454 1 tons 88 and 89, both were in same location, under pass side, before muffler. something doesn't make any sense.....
Old 03-04-2018, 08:09 PM   #11
mountie
mountie's Avatar
My original Cat is stuck above the transmission cross bar & has a "32 of an inch of room, above / below. I need to change it & move it past the tranny support.
It actually rests on the support... ( exhaust is kinda old)
'70 GTO Midnight Blue
'88 GMC Sierra SLE 392,000 miles-(2018) sold to Classic car shop in Germany.
'93 Cadillac STS Black
'93 Mercedes SL 500 Teal
'86 Yamaha FZ750 - 15,000 RPM
'86 Yamaha FJ1200 - Criminally Fast
2016 Ferrari 488 GTB, I drive it - don't own it.
'05 GMC Yukon XL , SLT 4wd ( just purchased 2018)
mountie is offline   Reply With Quote
Old 03-04-2018, 11:34 PM   #12
arrg
Couldn't find the Suburban, but the 3500 checks out. Converter behind the muffler.
1988 Chevrolet C1500 RCSB
arrg is offline   Reply With Quote
Old 03-04-2018, 11:50 PM   #13
manimal
manimal's Avatar
I just dont understand why though. Its my understanding the cat needs to get to a certain temp to operate correctly. Why did they only do this for a couple years and then go back to the forward position?
-Lance
Old 03-05-2018, 07:09 AM   #14
95 S_Trucker
I couldn't find anything on my walker catalog, which tells me that walker isnt making the parts to keep a factory exhaust on these 92-95 K200 Suburbans with the 7.4
I did look up this picture on my 92 light truck service manual. This was in the suburban section. 8600 GVW with the 7.4. It clearly shows the converter behind the muffler.
Old 03-05-2018, 08:03 AM   #15
Mr_Rich
Mr_Rich's Avatar
Maybe this will help. I scanned this pic out of my '89 Chev truck shop manual. Maybe this cat is some type of "afterburner".
1989 K1500 Chev. EC
Old 03-05-2018, 09:21 AM   #16
mountie
mountie's Avatar
This is from my service manual. ( C2500 5.7 )
I don't know why they needed to jam the converter between the tranny support
Old 03-05-2018, 09:25 AM   #17
95 S_Trucker
You guys are posting exhaust for trucks. The OP has a suburban.
Old 03-05-2018, 10:32 AM   #18
manimal
manimal's Avatar
Attachment 1759620
Yup, thats the way mine is. But the muffler and cat have been replaced at one time. Have never seen this before. I think I will move it before the muffler. I still cant understand the reasoning behind a 3 yr span of putting it after muffler as I dont see any difference in floor plans, crossmembers, wiring etc.. from other years or from a 7.4 TRUCK.
-Lance
Old 03-05-2018, 12:18 PM   #19
Mr_Rich
Mr_Rich's Avatar
We are very aware of that fact. We're in Kali. That is also a fact. At one time there were 49-state vehicles and there were Calif. only vehicles that were optioned with EGR, AIR, etc. that 49-state vehicles were free of. Maybe that Sub was originally a 49-state vehicle (?).
The big question is why the cat is where it is since the cats normally require heat shielding and heat of 600-800 degrees to work. Even Calif. doesn't require cats on old cars with new engine swaps because the old cars didn't have heat shielding under the pass. area.
1989 K1500 Chev. EC
Old 03-05-2018, 03:39 PM   #20
arrg
I had the same problem with my converter laying on the tranny crossmember. I replaced my transmission mount and now I have plenty of clearance.
Old 03-05-2018, 03:55 PM   #21
mountie
mountie's Avatar
What sort of transmission mount - cross member did you get?
