Will 275 Tires Fit in Rear of Fleetside?
This is a direct question which I have yet to find and answer to in all the tire/rim threads on this site (my eyes are bleeding from reading!).
Will a 275/60/15 tire fit inside the rear wheel well of a 1973 fleetside shortbox? Tires will be mounted to 15x8 rally wheels (4" back spacing). |
Re: Will 275 Tires Fit in Rear of Fleetside?
Yes, they should depending on your offset because I have a set of 295/50 15R on my 15x10 rallies.
I had 275/60s on stock 15x7 rallies on my fleetside with no trouble. there wasn't tons of room but there was nothing to worry about
- When the Reaper makes his deal, trust in your steel - '77 C10 350/350 2/4 drop and a mild street engine |
thats a 28" tall tire
i have a 85 fleetside short bed lowered 2.5" all 4 corners . stock 88-98 ss truck rims now and roller tires i clear 31x10.50x15 mud tires . my truck has a 3 leaf rear spring setup so its not to tall in the rear like some with 4 or 5 leaf . just whats on it when i got it . using them for rollers till ready for drive time then going the 275/60/15 size . i already have 1 bfg radial ta in this mounted on a 15x8 pickup ralley wheel and tested no problems.
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
I failed to mention that the truck is lowered (5/7) but it shouldn't matter as long as the width clears the wells.
I have 275/60r15 tires on 8inch rallys on a 3 inch lowered fleetside. Tons of room in the back. Front may rub if I lower more
1986 Custom Deluxe 10 1978 Caprice 2 door - sold 1937 Chevrolet 2 door sedan - project |
Wow! I haven't been on here for a while now.
Here you go. 275 60 15 on 15x8 with room on both sides to put my fingers, but I don't remember the wheel backspace. I hope this helps. |
I have a 4/6 drop on my fleetside and 275s. Plenty of room
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
Cruzzzn' Vet
Lot of room, have the same setup on the back.
#12 | |
I'm running these on my Fleetside and I couldn't go any wider. 0 spacing.
Front Wheels Ridler Style 695 Grey Wheel with Machined Lip (17x8"/5x127mm) Rear Wheels Ridler Style 695 Grey Wheel with Machined Lip (18x9.5"/5x127mm) 215/55R17 = 26.3x8.5R17 235/50R18 = 27.3x9.3R18 I know yours are higher but these are almost 11" wide at the side walls. Last edited by 85/Silverado; 03-04-2018 at 10:28 PM. |
Nice!
#15 |
looks close but will it fit on a bagged truck with 8 in 0r 10 inch truck rallys ?
#16 |
There's 5 diff trucks pictured in this thread. What looks close?
#17 |
Yes. 275's will fit w/room to spare.
295/40-20's on a 10" wheel......
#18 |
![]() Join Date: Dec 2006
Just as SCOTI and others have said, no problems with a 275. Here's a 285/50 on one my trucks with 1" of room at least.
Follow me on Instagram: @midtennc10 Youtube channel: Midtennc10 |
#19 |
#20 |
I have a 4 / 6 drop (flip kit) and 295 -45 /20 on the rear with 20X10 wheels with 5" BS.The tires are very close to the wheel well lips (less than little finger) and I built an aluminium angle device to prevent the sharp edges from cutting the tires. I have yet to rub as best I can tell. No marks on the tires. Been this way for 10+ years. Rear end is reasonably centred but not perfect.
Works for me. |
#21 |
Cruzzzn' Vet
#22 |
#23 |
Cruzzzn' Vet
#24 |
Diggin The SquareLife
I had 275/60 on a 15x10 rally lowered 6" with no problems
