03-06-2018, 10:34 AM | #1 |
RetroSound kickpanel speaker
Has anyone used these?
https://www.retromanufacturing.com/c...nt=20835567363 How did they fit? Did you buy their speakers also? If so, how did they sound? Thanks,
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-06-2018, 10:41 AM | #2 |
Re: RetroSound kickpanel speaker
If I had an option ... I would buy the kick panels without the speakers ... then buy a High Efficient speaker.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
03-06-2018, 11:09 AM | #3 |
Do you have part a particular brand and part #'s ?
03-06-2018, 12:03 PM | #4 |
I have them. Bought mine without speakers from Summit for half the linked price.
https://www.summitracing.com/parts/res-kp-c59-6772 |
03-06-2018, 12:18 PM | #5 | |
Hey, have you posted your setup anywhere. Do they rattle at all? Do they need to be caulked or anything. I'm thinking about moving my speakers from under the seat. It's valuable real estate for cramming stuff! Did you paint them? Looks like summit is getting in on the classic truck action more and more! Willie Doit? Damn straight, if he has the time!
White K20 |
03-06-2018, 12:20 PM | #6 |
Classic truck parts has the kick panels, $129.00, plus shipping.. they work fine. Chinese made , also crowds the parking brake.
03-06-2018, 12:25 PM | #7 | |
j
White K20 |
03-06-2018, 12:35 PM | #8 |
I have them installed - good fit, but the sound of the speakers coming with the panels is definitely a little too "retro" (rather tinny and without bass) for my taste. I have replaced them with other speakers (brand is "Gladen") - you surely can take any other brand, just take care they have the right diameter and depth (as I remember, the necessary depth - which I can't remember because it's quite a while ago since installation - was not easy to find). Even when switching to higher quality speakers, when you are into deep bass tones, you absolutely will have to install a subwoofer. There are some really small ones on the market that can be installed underneath the bench/seat.
And I can't recommend to install the panels "out of the box". To prevent the plastic from vibrating, I adhered a rather heavy "sound deadener mat" on the backside of the panels. I would buy them again - but just the panels without speakers |
03-06-2018, 01:11 PM | #9 |
I would get their size ... looks to be about 5 1/2 ...
Then go to an audio store and compare size and then look for High Efficiency speaker ... Takes less power Good Luck
03-06-2018, 01:38 PM | #10 |
I have them, came in the truck when I bought them. I beleive they have the speakers that came with them. I dynamated the back of them and the kick panel itself and used double sided 3m tape to mount them. I have them powered by an alpine amp from the front channels with a single sub bridged on the rear channels and it sounds pretty damn good.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
03-06-2018, 01:43 PM | #11 |
I had to use spacers for my JL audio component speakers to fit and the speaker does get in the way of the E brake pedal but I don't use my E brake anyway so no biggie, I also had to trim both kick panels a bit. Other than that they fit good and the speakers sound great. I ordered the kick panels from Crutchfield as I found them to be the cheapest price from there. I ordered the JL component speakers which also came with crossovers from Amazon, very good price for the sound.
03-06-2018, 02:21 PM | #12 |
I was going to go the route of kick panel speakers, but then stumbled onto BigBlock's cab corner panels. I'm moving the gas tank and like this location a lot better.
Just in case anyone else might want to see/consider this speaker location. Also think its amazing how many members we have that make awesome stuff like this. For all speaker/tweeter needs you gotta go with Crutchfield. Free shipping, crazy good customer service, and quality parts. CAB CORNER SPEAKER PANEL
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
03-06-2018, 02:47 PM | #13 |
I have these also. Modified the parking brake pedal to clear, rotated the dimmer switch 180 degrees. Put JBL speakers in the kick panels. On the passenger side had to trim the kick panel for clearance for the vent flapper (A/C cab). 3M Velcro and the Precision door gaskets hold in place. Also put a 8" powered sub under the passenger bucket seat. Very pleased.
Randy |
03-06-2018, 03:00 PM | #14 |
I purchased these and will install behind the back seats. These are vintage Jensen self enclosed speakers.
03-06-2018, 03:58 PM | #15 | |
~ I didn't use caulk. 3M Dua-Lock (think industrial Velcro-but different ), push-on door gaskets and the screws for the floor vent lever hold it in place just fine. ~ I didn't paint. My carpet is black so the speaker panels blend with the carpet. ~ No pics. They look just like every other speaker kick panel. |
03-08-2018, 01:01 AM | #16 |
I have them, had to trim the firewall edges. Still putting my i interior back together, painted them red. had to move my dimmer switch in.
03-08-2018, 02:48 AM | #17 |
Used these and 6x9 pods attached to roof. Installed 6.5 speakers with tweeters in both and built a custom sub box.
https://youtu.be/7voaqk31vdU |
03-08-2018, 03:17 AM | #18 |
03-08-2018, 03:31 AM | #19 |
I bought a pair of speaker pods and attached them to my kick panels.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Then I filled them with a nice set of Pioneer component speakers. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
03-08-2018, 11:39 AM | #20 |
Thanks for all of the information guys! Can anyone post some pictures of these kick panels installed?
03-08-2018, 12:36 PM | #21 |
no idea what brand they are, came with the K20 Burb I picked up last month.. thankfully, NO speaker hacks
all seems to work well enough for what it is, even with the left side shaved off from parking brake pedal..
I started out with nothing - and I still have most of it |
03-08-2018, 05:03 PM | #22 |
You could shim the parking brake assembly out away from the side of the truck too, with some spacers and longer bolts for more clearance.
03-08-2018, 10:59 PM | #23 |
Does anybody know what the mounting depth is? I haven’t had much luck finding that. Planning on getting a set without speakers and run my own coaxial/component setup.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
03-08-2018, 11:14 PM | #24 |
for some reason 1.25" depth at the most shallow spot come to mind. the kick panels are RetroSound. the speakers are Kicker 6.5 sound/heat deadener also behind them.
Steven '67 SWB, 250ci, 3OTT.......this is my first build...... I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71" |
03-08-2018, 11:24 PM | #25 |
standby.....I've got some pics head your way.....hope they help
