03-11-2018, 01:05 AM | #1 | |
Need help with 66 Fawn interior color
Im nearing the point where I can paint the interior of my 66 and I want to get the original fawn color. Im new to painting and before i step into the PPG store next week and try to get a close match I tried a search on this site and got this from the astronaut but there is some tweaking and somethings I just dont understand. I do want it to not have a gloss and more of that sheen he is talking about so there isnt as much of a glare when the sun hits the dash. Can anyone recommend to someone new to painting how to achieve this at a PPG store, knowing what to order? And how much paint to order as well for the interior?
03-11-2018, 01:23 AM | #2 |
Re: Need help with 66 Fawn interior color
sounds like what he did was choose the nissan sand color...and then had them tint it darker to match the og fawn color....
if you have something that has the original paint just take it with you and they can match or get very close to that og color...ash tray or glovebox lid will work... he used bc/cc paint and just never sprayed the cc on it..so all he had was paint....with no shine...
03-11-2018, 04:15 PM | #3 |
Thanks Greg, I do have the glove box panel so Ill take that with me tomorrow. The Spies Heckler brand is new to me and I dont know if PPG sells it. Also how much would be likely for an interior, plus some extra for storage just in case I need to redo an area in the future? Ill be covering up the floor with sound deadener and carpet so I think the SPI epoxy primer I have on already should be all I need there.
03-12-2018, 11:37 AM | #4 |
I took the steering wheel to my paint shop and picked out the paint chip that matched the closest based on color, that's how we decided to use the Nissan code. The color is very close without tinting it, close enough that 95% of people would never notice a difference in color. Also, different types of paint will look different after spraying- basecoat only will spray "dryer" than single stage, and the metalic particle orientation will make the paint look brighter/lighter. Single stage will look darker due to the paint needing to be sprayed on wetter, and the metalic particles won't be as bright/noticeable so the paint appears slightly darker/browner without tinting it.
For the correct sheen, you have options no matter which brand paint you use. With the Spies Hecker basecoat I used, I was able to mix it as an "underhood" application and not have to spray clear over it. This leaves the metalic particles suspended in the paint at the very surface just like the original paint would have been without a clear over the base (clear would make the paint look "deeper"). Adding hardener to the basecoat adds sheen, so you'll need to do a few test panels with different ratios of hardener mixed in to determine the amount of hardener/sheen. It won't have any UV protection this way, the clear is what protects the basecoat from fading. For a show truck/garage queen this isn't a problem, but the color might fade over time on a daily driver. I feel like this is the closest in apperance to the original paint. If you clear over the base you'll need to add a flattening agent, roughly 15-20% to achieve the original sheen. The exact amount of flattener needed will vary based on brand and how much you're reducing the clear. You'll want to do a few spray out panels. The metalic particles will not be at the surface of the paint, so it won't look exactly like the factory paint did. I haven't tried using a metalic single stage with flattener added in. I'm not great at spraying metalic single stage and making the metalic orientation the same all over, so I didn't want to attempt it inside a oddly shaped truck cab. It's easier to get the metalic orientation correct using basecoat, so that's what I did. If you try single stage, it'll have the correct look with the metalic particles at the surface of the paint. You'll want to use a slow reducer if you use single stage and you still need to add a flattener to reduce the gloss down to the correct sheen. On my '66, I'm planning on spraying base/clear, but with a small amount of basecoat mixed into the clear so the metalic particles are at the surface of the paint like the original paint. That way it has UV protection, the basecoat has the correct metalic orientation, and the clear w/base mix is translucent enough that the base shows through but still has some pigment/metalic particles at the surface. Should be very close in apperance and hold up well over time.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
03-12-2018, 07:31 PM | #5 |
Are you guys going to do the dark fawn on the dash and light fawn on the rest like 66 came or all light fawn?
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
03-13-2018, 09:55 AM | #6 | ||||
Thanks for the info Astronaut!
The interior cab, door interior, glovebox, steering column, and gas tank would be shot in one day though so I hopefully stand a better chance of it all not looking totally off. Fingers crossed. A link to the thread on that attempt. Brian had given me alot of guidance. http://67-72chevytrucks.com/vboard/s...d.php?t=746922 Quote:
Hey Jimmy, my interior originally looked like this which looks to me to be the light fawn all round so thats what I was planning to do. |
04-02-2018, 10:32 AM | #7 |
I went to the PPG store last week and took the glove box panel. The guy who was mixing paint behind the counter saw me with the panel and said "Ive got a formula already for that, thats from a C10 60s right?" I said yes a 66. I asked him about how he recommended painting to get an accurate look and he said "base it and clear..Ive got the clear you will need for that too". I asked about maybe adding a little metallic to the clear to get the right finish and he said not to, "if you get any runs in your paint you will have a mess on your hands trying to correct it". Being a first timer I figure Ill see how it goes without tinkering. Especially after nearly spending $600 on the interior paint and the white Ill need for the roof and other places that a 2 tone gets like the lettering and front end panel.
I took a scrap door I have been testing other paints on and got a test going. Looks pretty close to me, the sheen is different but that maybe a plus to cut the glare down when driving. Here is what it looks like. Some interior shots. |
04-02-2018, 10:34 AM | #8 |
The exterior shots...
04-05-2018, 03:16 AM | #9 |
This is perfect timing, I’m getting close to spraying my interior as well. That colour looks really good, any chance you can post up a pic of the mix formula or paint code?
04-06-2018, 05:02 PM | #10 |
Illl check with the paint store on Monday. Hopefully he is willing to share it. Its looks pretty close to me as well, the glove box does look slightly different but there is the age to consider.
04-06-2018, 07:37 PM | #11 |
Yeah it looks to be damn near a perfect match. If you can get the specs I’d appreciate it
05-09-2019, 11:31 PM | #12 |
Were you able to get the specs on the paint?
Former Decorated Combat Marine...Semper Fi!! Instagram jorourke322 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699 2019 GMC AT4 |
05-15-2019, 09:58 AM | #13 |
Hey John, I forgot to post to this thread but replied PM to Dracko back in April last year. The custom mix wasnt something the PPG paint guru would share but he did give me some hints. Here is what I wrote to Dracko.
I stopped by today and checked with the guy and he said it was just Ford Pueblo Gold. I asked then for the paint code, he then looked it up and checked the mix he had on his sheet and said its not 100% to what he had so he must have tweaked it a bit. He said to most anyone looking at them side by side wouldnt be able to tell that much of a difference. He said Pueblo Gold had a little maroon and black mixed in that he didnt have. But basically its the same. Try a sample of that Pueblo maybe and see what you think. Also, Ill add that in the match he gave me he recommended the matte finish and had the flexed and flat product. It went on great except the roof corners. I had to sand out the grit and redo but finally got it looking and feeling better to the touch. Here is a thread of the issue I had as I painted the interior. http://67-72chevytrucks.com/vboard/s...d.php?t=771555 Last edited by msg; 05-15-2019 at 10:07 AM. |
05-15-2019, 10:58 AM | #14 |
05-15-2019, 01:15 PM | #15 | |
09-15-2019, 08:20 PM | #16 | |
But Found Her 25yrs Later!
From another thread:
09-15-2019, 08:32 PM | #17 |
nothing like good ol blurry pb pics... thanks pb
09-17-2019, 03:23 PM | #18 |
They've absolutely killed all of my older build threads.
09-17-2019, 05:12 PM | #19 |
Stinks, I have referenced your work alot astronaut to have all that great info messed over. My build thread is a mess too, one day Ill redo the thing..still trying to get my truck done
09-29-2020, 07:40 PM | #20 |
Adding to this after noticing a very close match in a spray can to the fawn color on the interior. I was spraying my gauge cluster while restoring it and had a can of stainless steel oem paint from years back. Forgot where I got it but it is super close to that expensive custom mix job I had PPG do for me. If I had it to do over I may have just spray canned it.
09-29-2020, 07:52 PM | #21 | |
https://www.summitracing.com/parts/oer-k89091
10-05-2023, 08:27 PM | #22 | |
