01-23-2018, 11:10 PM | #101 |
Carpe manana
Re: Let's play name that part, bolt, harness, screw....
Hmmm. Honestly no idea....brake related for 67-68?
01-24-2018, 12:06 AM | #102 |
Yet, another brain stumper for me. I'm leaning towards an e-brake cable part, but I honestly have no clue.
1971 LSX "Bonnie" build thread http://67-72chevytrucks.com/vboard/s....php?p=8026381 paypal is curtbarton1971@yahoo.com |
01-24-2018, 01:56 AM | #103 |
DeadheadNM & Curtb1971, sorry but neither of you are even close. It's part of a fairly uncommon option.
01-24-2018, 02:57 AM | #104 |
01-24-2018, 12:41 PM | #105 |
I don't recall ever seeing one.
01-24-2018, 12:51 PM | #106 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Throttle arm?
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
01-24-2018, 01:08 PM | #107 |
Moderator
Carb mount for manual throttle
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
01-24-2018, 04:36 PM | #108 |
Ding, ding, ding!! WINNER WINNER leddzepp got it. The bracket that attaches to throttle arm for 67-70 manual throttle.
01-24-2018, 08:42 PM | #109 |
Good job Zep, Iron too. Looked like potential throttle, but I've never seen one.
According to my mostly unmolested 71 C-10, 2WD, these were used to mount two items: Over the top trivial probably. At a second glance, I had these bolts on three parts. There's another version of the same bolt stamped with a circle.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 01-28-2018 at 03:30 PM. |
01-25-2018, 09:36 PM | #110 |
Any idea what these ac brackets fit? Early small block? Aftermarket? Pulley is larger than usual as well. I’m pretty sure it came off a 67-72
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
01-28-2018, 03:30 PM | #111 | |
No takers on that L8 bolt I see. Well, how about this washer?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
02-07-2018, 08:19 PM | #112 |
No takers on the L8 bolt and flat sides washers I see. So I'll give it away for edge-u-cationals. These come off a 71 C-10.
The L8 bolts mount the steering box. They also mount the upper control arm support to the wall of the frame, which screw into the fixed square nuts on the support..............I also found one for the upper control arm to frame. In that case GM was using up bolts, I ended up with three types. The flat sides washers are used to mount the engine crossmember to the bottom of the frame. Two are used for each bolt (=12). On a side, I was surprised to see the application didn't have lock washers or lock nuts. Just plain regular nuts. I checked the assembly manual to confirm, but came up empty. Probably missing it. Perhaps some takers on this stud. Can't speak for prior to 1971, but I can say the 72 BBC doesn't use one (hint)
02-07-2018, 08:29 PM | #113 |
Moderator
That stud is used for the heat shield mounting on the driver exhaust manifold, also used for mounting a small block AC bracket to the other exhaust manifold.
02-07-2018, 08:43 PM | #114 | |
Edit, I might be wrong about 3/8 both sides........Pending.....Edit again, confirmed, 3/8" both sides. Another clue, the stud in post 113 was not on the exhaust manifold.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 02-07-2018 at 11:19 PM. |
02-08-2018, 01:39 PM | #115 |
Okie Dokie, I'll give another one away. The stud goes to the front hole in the intake manifold on the LH side for the top alternator bracket on a 71 BBC. I assume prior years as well, but the 72 uses a different set-up.
03-12-2018, 12:43 AM | #116 | |
1971 LSX "Bonnie" build thread http://67-72chevytrucks.com/vboard/s....php?p=8026381 paypal is curtbarton1971@yahoo.com Last edited by Curtb1971; 03-12-2018 at 12:54 AM. |
03-12-2018, 12:58 AM | #117 |
Here's a fun one. Name that part!
03-12-2018, 01:25 AM | #118 |
Moderator
7/16 - 20 fine thread bolt used for 67 seat belts. Also used for shoulder belts all years 67-72
Next
03-12-2018, 01:49 AM | #119 |
Dang leddzepp! Knocked that one out of the park
03-12-2018, 11:06 PM | #120 |
Carpe manana
Nice work Scott. Good to know these are correct for shoulder belts also.
03-12-2018, 11:21 PM | #121 |
Carpe manana
Anyone recognize these? There are two different size screws shown.
03-13-2018, 12:16 AM | #122 |
Larger ones with shoulder are door lock to door screws.
03-13-2018, 12:18 AM | #123 |
How about these two pieces?
03-13-2018, 12:29 AM | #124 |
Are the small ones are for wiper transmission to inner cowl?
03-13-2018, 01:06 AM | #125 | |
