03-12-2018, 11:16 AM | #51 |
Re: Project: '72 Family Hauler
I had a little time to get out in the garage on Sunday. I pulled the rear drums to see how the rear brakes look. No leaks from the wheel cylinders, and the shoes still have some wear, so I think i'll let them ride until I swap over to rear discs. Also took a look at what was going on out back from the previous owner. (Check out that exhaust hanger!!) I have some notches on order from Dead End Garage that should be in within the next couple of weeks. I pulled the old door weather stripping from the 3 doors, and installed some new push on Precision seals. I think I need to go ahead and replace the window seals soon, because the doors are so tight now that I feel like the glass may break when they get slammed shut. I pulled the burb out and made my first lap around the block since replacing everything up front. No funny sounds, and nothing fell off, so I think we're good! I did a quick string alignment to straighten the wheels and steering wheel, then pulled this crappy aftermarket wheel. The 14" diameter felt too small for one of these vehicles. I mounted a 15" repo comfortgrip in it's place. I have to say, I definitely prefer the comfortgrip over the Grant equivalent that was installed on my old truck. The horn connection is giving me a little trouble. I can get the horn to sound by pushing on the contacts, but once the horn button is installed, I can't get any noise. Any recommendations?
03-12-2018, 07:03 PM | #52 |
That's a structural exhaust hanger haha.
03-12-2018, 07:27 PM | #53 |
The Older Generation
Where I come from it would be called "Bullet Proof"...
LockDoc
03-13-2018, 08:50 AM | #54 |
Where did you pick up the steering wheel? Why original is all cracked and beat up
03-13-2018, 09:09 AM | #55 | |
https://www.ebay.com/itm/Comfort-Gri...72.m2749.l2649 So far I'm extremely happy with the fit. I just haven't quite figured out the correct way to hook up the horn as there are no instructions. |
03-14-2018, 08:21 AM | #56 | |
http://www.camaros.net/forums/23-int...n-install.html https://www.camarocentral.com/category_s/41119.htm
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 03-14-2018 at 08:37 AM. |
03-14-2018, 09:42 AM | #57 | |
I have everything installed per the illustration. Is the spring from contact plunger the only thing that holds the steering contact away from the steering wheel? I can get the horn to honk when pushing down the contact, but when the horn button is snapped on, I get nothing. |
03-14-2018, 10:28 AM | #58 | |
http://www.flamingriver.com/index.ph...0003/FR20120HN
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-14-2018, 10:35 AM | #59 | |
03-14-2018, 10:39 AM | #60 | |
03-14-2018, 11:10 AM | #61 |
This is what my kit came with, minus the horn contact canceling cam. I'm using the original truck cam. Other than what's pictured, I have the hub, the steering wheel, and the horn button.
https://www.camarocentral.com/1967_1...t_p/ste-85.htm |
03-18-2018, 01:35 PM | #62 |
So, it turns out that the horn/steering wheel was installed correctly. I just didn’t have the horn button on exactly right. At least it was something simple even if it did make me feel like an idiot. I took the Burb in for an alignment yesterday. I’ve put 10-15 miles on it since then and it drives down the road awesome. The steering is nice and tight. The rear suspension bottoms out on decent bumps so I’ll be installing the notch soon. I also picked up a 1” block to put in at that time. The inside edge of the rear tires are rubbing the tubs a little on bumps. I’ll probably try massaging the tubs a little with a block of wood and hammer and maybe add a 1/4” spacer when I redo the rear end. I’m sure the panhard bar could use a little adjusting as well. It feels good to actually have it on the road!
03-18-2018, 04:47 PM | #63 |
Good deal. Glad you have it on the road. LockDoc
03-18-2018, 05:45 PM | #64 |
Way cool how nice wheels and lower stance can make. Good job.
70 c10 2wd crashed Suburban 67 c10 2wd sb truck 67 c10 4wd lb truck |
03-18-2018, 07:10 PM | #65 |
Strongman Garage
Congrats on getting it on the road!
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
03-19-2018, 08:08 AM | #66 |
Burb is looking good Jason, glad to see you out driving it.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
03-19-2018, 12:13 PM | #67 |
The stance is perfect!
03-19-2018, 10:03 PM | #68 |
Congrat’s looks very good!
03-20-2018, 04:34 PM | #69 |
6>8 Plugless........
It sure looks sweet now! Great work!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
03-29-2018, 05:49 PM | #70 |
Sweet Burb!!
1972 C20 Suburban, Bagged and c10 swapped Suspension (sold) 1969 Jimmy, 2wd swapped. bagged, body dropped |
03-29-2018, 09:03 PM | #71 |
A guy with a truck
Love it! Doing flat caps on the TTs?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
03-30-2018, 08:42 AM | #72 |
Thanks guys! It's coming along. I've decided to go ahead and address the rear suspension while the weather is still crappy. I have a c-notch, panhard bar, and some rear shock relocators that I picked up from Jason over at Dead End Garage. New trailing arm bushings, some new shocks, and a 1" lowering block are in the plans. I've replaced the lenses on the turn signals, tail lights, and reverse lights and replaced a couple broken door handles. I also replaced the front factory lap belts with some 3 point retractable belts from Morris Classic. I hope to tackle the suspension stuff within the next week or so and will have some new updated pictures.
I've contemplated doing flat caps like you had on your Streeter wheels, but I'll probably leave the original caps on for now. I do like the look though and it may be in the books for a future upgrade. |
03-30-2018, 11:47 AM | #73 |
Nice buddy, can’t wait to see the next round of updates!
03-30-2018, 02:59 PM | #74 |
Looking good. Ive got similar plans for my recently purchased burb
07 GMC Sierra 2500 compound turbo' duramax 99 GMC Yukon solid axle swapped 67 Chevy c10 small window swb stepside supercharged ls6 70 Chevy c10 suburban 72 K5 Blazer 4wd |
04-09-2018, 10:19 PM | #75 |
I was really hoping to have a new round of updates to share from this past weekend. Instead, all I have to show for it is a fractured 4th metacarpal in my right hand. While drilling holes in the trailing arms to mount the new Deadend Garage lower shock relocators, my drill bit grabbed and torqued the drill around in my hand. That force was enough to break the bone. Vacation day was wasted after drilling two measly holes...minor setback.
