03-10-2018, 06:58 PM | #1 |
Console repair Saddle Paint and restore
1972 Blazer Console restore. I repaired a 4 inch crack on the top back where they all split. I used 2 part epoxy with fiberglass matting on the inside. Took everything apart and cleaned and prepped. Then sprayed it with Sem paint. The color is a bit lighter than I want. I may re-
do it if someone can tell me a product that is closer to factory Saddle. overall I am very happy the way it turned out. |
03-10-2018, 09:47 PM | #2 |
Re: Console repair Saddle Paint and restore
Looks nice .
03-11-2018, 05:14 AM | #3 |
Looks awesome!
Full top blazer or bust.... |
03-11-2018, 09:30 AM | #4 |
Carpe manana
Console looks great. What sort of prep work did you do to the console prior to paint? I've got a console to repair and redo in parchment.
Here's a thread on attempts to match the dark saddle interior in a 72: http://67-72chevytrucks.com/vboard/s....php?p=7956593
03-11-2018, 10:51 AM | #5 | |
https://www.semproducts.com/blog/4-e...terior-plastic Last edited by a1vintage69; 03-11-2018 at 10:59 AM. Reason: prep with Sem |
03-11-2018, 11:05 AM | #6 |
Pete, I also painted the trim plate around the ashtray because it was rusted. sand it down then primed it and then sprayed it with silver wheel spray. very durable. looks good to. The chrome trim ring I used oooo steel wool. a1
03-11-2018, 11:16 AM | #7 |
Excellent work; looks great!!
-Bruce 1971 K5 Blazer 4WD |
03-11-2018, 11:16 AM | #8 |
Carpe manana
Good info thanks. I couldn't find a helpful guide on the SEM website last time I checked. Steel wool works great. Lately I've been using bronze wool with a similar effect.
I've got a container of the SEM soap, cans of plastic SEM plastic prep, and an adhesion promoter. Since I've had no luck matching a NOS parchment door panel I'm going to paint an excellent set of black door panels too in addition to bucket seat panels and a NOS set of black arm rests.
03-11-2018, 11:22 AM | #9 | |
03-11-2018, 11:26 AM | #10 |
Carpe manana
Thanks! I've got the same. I've had the cans sitting atop a bench in the garage for months. Every week or so I invert the cans on the superstition that I'm keeping the pigment in suspension
03-11-2018, 11:27 AM | #11 |
Carpe manana
I'll tackle the project soon as the temperature improves and will do some split repair to the rubber mats with rubber cement
03-13-2018, 05:03 PM | #12 | |
03-13-2018, 06:53 PM | #13 |
Thanks awelle, I ordered some. I will give it a try and report back. a1
03-13-2018, 07:31 PM | #14 |
The guy on ebay who sells restored consoles media blasts them. Last I spoke with him he said they are all the same color once the dye is removed. I would imagine its real low pressure blasting.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
03-13-2018, 07:33 PM | #15 |
03-13-2018, 09:03 PM | #16 |
I used acetone to remove the old paint, took it right down to the fiberglass. lots and lots of rags.
03-16-2018, 01:11 AM | #17 |
03-19-2018, 08:47 PM | #18 |
awelle, I sprayed my console, door panels, armrests and blazer visors with pp818 m42 dark saddle and it is very close to originals. I am so happy you gave it to me as an option. thanks, a1
03-19-2018, 08:59 PM | #19 |
Here is the before and after pictures. also shown on new saddle seat covers.
03-19-2018, 11:58 PM | #20 |
Good, glad I can help, looks great! Haven't gotten around yet to spray rear armrests yet, but maybe this weekend. Might touch up some other pieces as well
