Truck bed mat
Since no one make a mat for our trucks I looked around and found that they make a horse stall mat that is 4’x6’x3/4 or 5/8 thick. I went and picked up 2 mats spent about a hour and voila a bed mat that fits perfectly. The box is exactly 6’ wide( long box) and just cutout wheel wells. Mat cost me $80.
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Truck bed mat
Those things are incredibly tough (and heavy!). I have had one in my truck bed for a few years and it's virtually like new. Didn't get two and line the entire bed floor, just one between the fenderwells and touching the front of the bed.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#3 | |
Re: Truck bed mat
choctawchevyclassics ![]() |
Re: Truck bed mat
couple of pictures
20' Daredevil (Ret)
Re: Truck bed mat
That looks great! What did you use to cut them?
Re: Truck bed mat
I used a rechargeable circular saw for straight cuts and a large box cutter for the corners. The mat actually cuts pretty easy with the box cutter.
Re: Truck bed mat
The trick is to lube the box cutter with soap
20' Daredevil (Ret)
Good to know, thanks for both replies.
![]() Join Date: Feb 2002
Re: Truck bed mat
If you have a steel bed you'll want to avoid trapping moisture between the steel floor and the rubber mat. One 1/2'' or 3/8'' hole in each corner will do the trick. If there's a wood floor underneath, you can skip it.
Would one horse mat cover the back deck of a K/5?
Re: Truck bed mat
The bottom of the mats actually have hundreds of 1/4” dimples so air can get under. I will post a picture.
Re: Truck bed mat
Here are a couple of pictures of underside of mats
Re: Truck bed mat
Where did you buy those at ?
Re: Truck bed mat
I bought them at a farm store called North 40 also know as Big R. I am sure any farm,ranch supply store will have them
Re: Truck bed mat
Someone does make them. I posted this before in the 66 form. I will need to find it.
#15 |
Re: Truck bed mat
The maker of the mats is. Red Barn
Red Barn Lite Stall Mats $42.99 +25 Write a review Red Barn Lite Stall Mats Select Quantity LOAD THE TRUCKCecelia North 40 Icon Truck |
#16 |
![]() ![]() Join Date: Mar 2016
Re: Truck bed mat
The local Tractor Supply has them for 39.99 I was looking at them last night. I have had a mat made from conveyor belting from a local manufacture, but it has seen it better days. I have been considering one for my step side.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() Last edited by 3757chevy; 04-09-2018 at 01:42 PM. |
#17 |
20' Daredevil (Ret)
Re: Truck bed mat
That's where I got mine, Tractor Supply Co.
#18 |
Re: Truck bed mat
I have not bought one yet because it measures 5" short and I don't need a 5'7" left over piece if I buy 2.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() |
