Old 05-07-2018, 07:57 PM   #126
FAKKY
Re: 57 Panel "FAKMLC" build
Passenger side - notice the stock mounts behind the Dakota IFS crossmember
FAKKY 57 PANEL BUILD
FAKKY is offline   Reply With Quote
Old 05-07-2018, 07:58 PM   #127
FAKKY
Passenger side AC
Old 05-07-2018, 07:58 PM   #128
FAKKY
Passenger side exhaust flange
Old 05-07-2018, 07:59 PM   #129
FAKKY
Drivers side - see the stock mounts behind the IFS crossmember
Old 05-07-2018, 08:00 PM   #130
FAKKY
Trans and engine from below
Old 05-07-2018, 08:01 PM   #131
FAKKY
From TOP passenger side fitment tunnel
Old 05-07-2018, 08:03 PM   #132
FAKKY
Not sure what you guys think --- I dont think I am too far back although I am about as far back as I can go I think due to harness as well as bracketry/fuel line for fuel railes on the driver side near tunnel.
I dont * think * I will need to modify tunnel ...... but hard to tell as everything is tight.
Finally - does it need to come forward due to the motor mounts - or is there an offset plate that is big enough to handle this ?
thx
Old 05-08-2018, 07:11 PM   #133
FAKKY
Transmission Removal
1) Remove Starter to gain access to inspection plastic plate (remove)
2) rotate flywheel with screwdriver to get to the 3x 15mm bolts - I used a 15mm 12 point socket and breaker bar to loosen and remove with socket wrench
3) Remove I think 8 bolts on bellhousing. 2 have accessorie 13mm nuts on top then all 15mm bolting into the block.
4) Walk off dowels and onto jack/dolly.
Old 05-08-2018, 07:13 PM   #134
FAKKY
Walked transmission around to rear of house.
plan is to disassemble for 4wd=>2wd conversion.
If all looks good (think it will be) -- just replace a few items (3/4 clutches) and sunshell and swpa the output and redo all asssembly and seals.
Next update should be teardown maybe this weekend.
Old 05-09-2018, 02:20 PM   #135
BIGglaSS
BIGglaSS's Avatar
I would not move the motor forward. There is not a lot of front clearance for radiator / fan. I moved mine further back. I didn't have to modify the tunnel.
As far as motor mounts, there's always custom built to put it exactly where you need it. I hear a lot of guys use dirty dingo mounts. Since I'm using a different frame/clip I can't help you there.
BIGglaSS is offline   Reply With Quote
Old 05-09-2018, 02:35 PM   #136
FAKKY
Yeah going to try and put as far back as I can ......
but really starting to hit/interfere with the fuel rail.
May need to weld a custom mount off back of the
The part I dont get with the dingo sliders is they say its more for moving the engine forward. But this is in reference to stock SBC ....... so not sure how that plays here.
eg
https://www.dirtydingo.com/shop/prod...oducts_id=1372
Thats the triangle pattern for a SBC mount. havent checked but guessing that varies from the mounts from the LQ4 which I think are sort of square.
Old 05-09-2018, 03:15 PM   #137
BIGglaSS
BIGglaSS's Avatar
I just looked at your picture again. In reference to the right coil mount stud, clearance to the firewall is about the same on mine.
Old 05-10-2018, 03:15 PM   #138
FAKKY
Thx.
Was thinking about could relocation or cutting the stud.
Will have to see but either way don't think I can get that much further back due to fuel rail
Old 05-12-2018, 05:26 PM   #139
FAKKY
Patch job on step welded, metal prep treated, cleaned and fibreglassed
Starting transmission teardown tomorrow - puled the torx plus 50 screws today in case they were tough (heard they are a bear - went fine).
Ill start a seperate tranny thread - but post highlights in here.
Old 05-13-2018, 04:10 PM   #140
FAKKY
Didn't get much done on transmission today - pulled my back lifting concrete blocks for a deck off truck yesterday.
Basically took the servo off the side of transmission using a screwdriver/hammer/pick as per most videos.
Then removed transmission pan bolts and had a sneak peak inside.
CLEAN.
Actually cleaner (lighter) in real life. Minimal friction. No metal.
Ill start a trans 4wd=>2wd thread in a different section this weak as I tear it down. And link tot this thread.
Old 05-13-2018, 04:43 PM   #141
FAKKY
Bad side is - my fibreglass patch didnt set up right.
Dont think I got my mixture ratios correct - its tacky and not hard.
Not sure if can be fixed. Or start over
Old 05-20-2018, 12:33 PM   #142
FAKKY
Trans Teardown Tyread for 2WD swap
http://67-72chevytrucks.com/vboard/s...11#post8264611
Old 05-20-2018, 03:22 PM   #143
dsraven
why not just get a 2wd trans and sell the 4wd trans? seems like a lot of work to convert, unless you are a trans guy and love doing that.
Old 05-20-2018, 03:23 PM   #144
dsraven
are you also thinking of swapping the engine oil pan with a shorter version?
Old 05-20-2018, 03:43 PM   #145
FAKKY
A couple of reasons.
1) Couldnt find a buyer quick enough to move on with project.
2) Engine and trans were a factory unit together - unless I went 4l80e liked that idea.
3) Engine rebuild and trans rebuild are 2 things I havent done. So wanted to try it.
Long story short everything on this truck will be basically built where it can be ..... I may only ever do this #1 time in my life. This is not a show truck its literally - can I do it an make it work. Not a mechanic just interested in this stuff for challenge.
Not sure yet - quick fitment on oil pain showed it "might be ok" and just hang a little low. Since its a truck and not a fbody - think it will be fine. BUt I will be doing a few more test refits once trans is done to mainly look at exhaust manifold clearnace (tight might need a corvett manifold) and motor mount support.
Old 05-21-2018, 08:28 PM   #146
FAKKY
Need to ''retap" the IC Dakota steering pump holes
Bought this ...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Any idea of where to get a tap wrench that fits --- only found one and its $150
Old 06-19-2018, 03:03 PM   #147
FAKKY
Start of 4l60e rebuild/shaft swap
https://www.youtube.com/watch?v=4UOVcZf78Ec
https://www.youtube.com/watch?v=id8hyXVhZbA
*missed the low/reverse clutch install as accidentally deleted video*
https://www.youtube.com/watch?v=-qvMx0SiKiM
Old 07-05-2018, 02:27 PM   #148
FAKKY
Transmission rebuild completed.
Old 07-10-2018, 05:12 PM   #149
FAKKY
Old 07-16-2018, 06:36 PM   #150
FAKKY
Almost done with the main work on harness. Wife depinned most of it whilst I was at work and then we finished off. Ordered a fuse block harness from VP auto for $125. That should be enought finish off wtih some loom and tape.
Hope to try and finish of some sheetmetal weld ..... then get the interior done (wife will do that part of cutting and measuring sound proofing and matting) and I can try and get the brake lines done as well as the engine and trans in place.
Still not sure what Im doing on fans/radiator and fuel as yet. Bought a dakota cluster as well as a collapsible steering column from ididit.
