Old 05-09-2018, 09:24 PM   #1
steveimpala
Active Member
Quadrajet help
I have an issue with my 1969 Chevrolet C20. It has the 350 V8 with the automatic transmission, the carb is the Rochester Quadrajet. The truck starts up fine, comes to a idle after a few minutes. The problem that is occurring is that after driving for 15 mins or so, you come to a stop and the truck wants to die. The truck has 88,000 miles and I'm guessing that the carb is original. Any thoughts....adjustments or rebuild ?
Thanks!
steveimpala is offline   Reply With Quote
Old 05-09-2018, 09:30 PM   #2
rjs53
Re: Quadrajet help
Is it running out of fuel? I think those had a filter at the inlet, might check it. Quadrajets are good.....when they work
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 05-09-2018, 09:49 PM   #3
dmjlambert
dmjlambert's Avatar
Re: Quadrajet help
Sounds similar to the problem I had
http://67-72chevytrucks.com/vboard/s...d.php?t=760430
dmjlambert is online now   Reply With Quote
Old 05-09-2018, 09:53 PM   #4
steveimpala
Active Member
Re: Quadrajet help
Yes, gas filter was replaced.
Old 05-09-2018, 10:35 PM   #5
geezer#99
geezer#99's Avatar
Re: Quadrajet help
Check for a vacuum leak.
Is this a recent occurrence or has it been ongoing?
Old 05-09-2018, 11:02 PM   #6
steveimpala
Active Member
Re: Quadrajet help
It just started... just had some work done to the truck - new exhaust, hoses, belts and brake lines.
Old 05-10-2018, 08:32 AM   #7
68Gold/white
Re: Quadrajet help
www.cliffshighperformance.com
You need a rebuild. Cliff can sell you a kit and all the parts to calibrate your carb for todays gas, and his parts are ethanol resistant. His stuff isn't cheap, but it IS the best!!!
Get his book ,also!
68Gold/white is offline   Reply With Quote
Old 05-10-2018, 09:01 AM   #8
geezer#99
geezer#99's Avatar
Re: Quadrajet help
Yes you might need a rebuild but find the source first. You might be chasing it after a rebuild too.
When you say it comes to an idle after a few minutes, is that from you kicking the high idle off?
And when it does that is the choke completely off?
Old 05-10-2018, 09:09 AM   #9
steveimpala
Active Member
Re: Quadrajet help
Yes, after a few minutes, I'll tap / kick the accelerator to bring the engine to an idle....I'll have to look later today regarding the choke...
Thanks!
Old 05-10-2018, 09:21 AM   #10
geezer#99
geezer#99's Avatar
Re: Quadrajet help
Thanks!
Easiest visual check is look at the tang on the secondary lockout. If it’s dropped off the pin on the end of the secondary shaft then the choke is completely off.
Here’s a pic on a link.
https://www.google.com/search?tbm=is...d5PpmhDXHRHTM:
Old 05-10-2018, 09:58 AM   #11
Coley
Coley's Avatar
Re: Quadrajet help
It does sound like something in the choke circuit (passenger side of carb) is off somehow.
When they did the work on the truck, did they touch the timing?
I'll take a page from Geezer's book and say check that first to make sure you have (at least) 8°..personally I would recommend 10-12° to start.
Regardless, make sure the choke equipment is working properly....check all carb hoses as well...or simply replace them (they are cheap).
These include the main hose up to the power brake booster, the PCV valve, the short air cleaner connection, the vacuum advance hose, and even the little short one between the choke pull off and the carb.
Also check the transmission vacuum hose which comes down from the upper manifold to the trans.
When the truck is idling...is it smooth? or does it sound a little rough?
...if it not a smooth idle, all cylinders hitting...then you probably have a vacuum leak.
Do you have any pics of your set up?
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 05-10-2018, 10:55 AM   #12
steveimpala
Active Member
Re: Quadrajet help
Nothing was touch regarding the engine... the truck runs smooth on all cylinders...here are some pic:
Old 05-10-2018, 10:57 AM   #13
steveimpala
Active Member
Re: Quadrajet help
1969 c20....
Old 05-10-2018, 11:26 AM   #14
geezer#99
geezer#99's Avatar
Re: Quadrajet help
Nice pics!
I can see your choke plate wide open but the lockout tang is still hooked on the secondary pin.
Could just be some crud on the tang.
I’d spray it and clean the whole choke area with some carb/choke cleaner first. Then if that doesn’t help we can help you with a couple more possible things to check.
Old 05-10-2018, 12:41 PM   #15
steveimpala
Active Member
Re: Quadrajet help
Thanks again.... will give it a try
Old 05-14-2018, 01:14 AM   #16
steveimpala
Active Member
Re: Quadrajet help
Just an update, I did clean up the carburetor and gave the truck a run later that day...... so far so good...
Will keep you all posted
Thanks !
Old 06-05-2018, 02:54 PM   #17
steveimpala
Active Member
Re: Quadrajet help
I thought I was all set with the idling issue, but it's back. Took it out over the weekend, about 10 mins into the drive while at a stop light, it felt like it was going to stall out, so I place it in neutral until the light change. Not sure on what to check next...
Any suggestions....Thx !
Old 06-05-2018, 03:16 PM   #18
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Quadrajet help
Spray carb cleaner around the primary throttle shaft on the driver's side and see if the idle speed changes. You likely have a worn bore where the throttle shaft goes through the base plate. If there is a vacuum leak there, it will be covered up by the richer mixture when it is on the choke.
~Steven
Simi Valley, CA
Old 06-05-2018, 04:03 PM   #19
geezer#99
geezer#99's Avatar
Re: Quadrajet help
Check your timing.
What’s your initial timing set at?
Old 06-05-2018, 04:35 PM   #20
steveimpala
Active Member
Re: Quadrajet help
Heading off to work now, I'll check it tomorrow and post it here.....
Old 06-07-2018, 10:20 PM   #21
steveimpala
Active Member
Re: Quadrajet help
Finally got to checking the timing, it's at 2* BTDC . I forgot to mention that it has a electronic ignition set up from prior owner.
Old 06-07-2018, 11:36 PM   #22
geezer#99
geezer#99's Avatar
Re: Quadrajet help
No wonder it dies!
Bump your initial up to 12.
You’ll see a world of difference.
Old 06-07-2018, 11:42 PM   #23
steveimpala
Active Member
Re: Quadrajet help
Thanks for your input geezer ! I'll post results tomorrow.
Steve
Old 06-08-2018, 07:29 PM   #24
steveimpala
Active Member
Re: Quadrajet help
Set timing at 12.....went for a drive.... no issues !
Thanks again !
Old 06-08-2018, 07:46 PM   #25
geezer#99
geezer#99's Avatar
Re: Quadrajet help
Good deal!
