Old 06-03-2018, 12:47 AM   #1
prodjay10
gas tank rust
So I'm in the process of getting one of my trucks going again. I got it running but it still needs a few things to be road worthy enough to risk driving.
Well I thought Id start by getting the tank cleaned. After picking it up I put it in garage. A couple weeks later I go to install it and the tank is rusted inside even worse than before!
Now I'm not sure what I should do. Get it cleaned again? Get it coated? Is there a way to prevent rust without coating it?
I'd clean it myself but I wouldn't know how to get the cleaning agent out of the tank.
prodjay10 is offline   Reply With Quote
Old 06-03-2018, 01:38 AM   #2
frank69
Re: gas tank rust
I tried cleaning and coating with a kit from por-25, but it'seasier to just get an aftermarket tank.
frank69 is offline   Reply With Quote
Old 06-03-2018, 02:10 AM   #3
prodjay10
Re: gas tank rust
I was thinking that too. Are they coated or would it also rust in a few days?
Old 06-03-2018, 03:51 AM   #4
BCOWANWHEELS
Re: gas tank rust
Use vineger to clean it out. Works good
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 06-03-2018, 05:07 AM   #5
Grumpy old man
Grumpy old man's Avatar
Re: gas tank rust
KBS Coatings tank sealer kit works .
https://www.kbs-coatings.com/Auto-Fu...ealer-Kit.html
Old 06-03-2018, 10:10 AM   #6
engineer_gregh
engineer_gregh's Avatar
Re: gas tank rust
Hi Grumpy, have you used the kit before? I have rust in my tank now and was going to take it to the local radiator shop to have it coated but if this works I would rather do it myself. I replaced my original tank with one from LMC about 6 years ago and it recently started rusting pretty bad. Nothing like quality Chinese steel!
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 06-03-2018, 10:52 AM   #7
greasemonkey
greasemonkey's Avatar
Re: gas tank rust
I've gone through this recently with a motorcycle gas tank that had sat over winter with water in the tank. I tried oxalic acid and wasn't impressed. I ended up using Ospho (phosphoric acid) and water solution and let it soak a few days. I threw some old bolts and nuts in it, shook it violently, rinsed it and it looked brand new inside. Bike guys swear by Red Kote, so I used that for the liner. It is inexpensive and it is ridiculously easy to use. This is going to be my go-to procedure from now on. Cheaper than buying a new tank as long as you are willing to put in a little work.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 06-03-2018, 12:55 PM   #8
prodjay10
Re: gas tank rust
Thanks for the reply's. I'll try to coat it.
Old 06-03-2018, 05:51 PM   #9
Mikes68C10
Mikes68C10's Avatar
Re: gas tank rust
I feel your pain, just got word Friday that my tank is much worse then thought... 15 years sitting in a garage - not good at all! I'm ordering a Rockauto replacement tank, read enough posts on this forum to be confident. Reading this post, is making me think a good tank sealer will prevent future rust problems.
Best of luck, whichever path you take, play it safe and coat the inside!
1968 C10 LWB Fleet-Wood, 2-WD, 327, 4-Bbl, Auto, 12-Bolt, Bone Stock. >POOF!< Sold 9/8/2018. New owner is local to Waynesboro PA and will take excellent care of her. He also owns a 69 Z28 SS Option car.
1998 Camaro SS, LS1, A4, 3.42. Free Tune - Stock 13.08 @ 106.55 >Lightening Strikes Again!< Sold 9/9/2018 she too will be well cared for as 1 of 45 produced in blue, with Auto and no T-roof.
Mikes68C10 is offline   Reply With Quote
Old 06-03-2018, 07:52 PM   #10
prodjay10
Re: gas tank rust
I found that Dorman sells gas tanks. I've had pretty good luck with their parts so I trust their tank should be good enough. I found one sold by Autozone on ebay for $162 shipped. Mine is for a 1972 and has a special vent on the filler neck. If you go to the dorman website, you can find the part number for your truck.
Dorman 576-233
Old 06-03-2018, 08:00 PM   #11
Mikes68C10
Mikes68C10's Avatar
Re: gas tank rust
Dorman 576-233
Thanks! Will give them a look.
Yeah, agree on the Dorman parts, never saw much complaints about them.
Bought one of their LS2 Intakes for my 98 Camaro SS, takes the larger 92mm TB, so good news an less than a/2 price of the :leading brands manifolds.
Old 06-03-2018, 10:26 PM   #12
Dustytrix
Re: gas tank rust
I used some Red Kote on a tractor tank 4 years ago and its still holding up. Great stuff and simple to use.
Dustytrix is offline   Reply With Quote
Old 06-04-2018, 12:46 AM   #13
mike16
Re: gas tank rust
the fact that there are so many variables and success is still uncertain.
Just get a new tank.All the money spent on rebuild kits, fuel filters, fuel pumps and coatings? and those trips to the parts store, and the pit stop break down procedures in the intersection at rush hour...and those call to all your friends to either come pick you up or bring a tow rope...., the under hood fires and the several exhuaste systems you will blow apart on busy roads... And those are the facts that are certain .....
just get a new tank.
mike16 is offline   Reply With Quote
Old 06-04-2018, 08:21 PM   #14
Mikes68C10
Mikes68C10's Avatar
Re: gas tank rust
Ordering this week, likely the one from Rockauto. Reputable name, made in Canada from what I read. Sounds good to me.
Old 06-06-2018, 10:49 AM   #15
engineer_gregh
Re: gas tank rust
Just got my Dorman gas tank today, part #576-233. Made in Taiwan! Ordered off Ebay https://www.ebay.com/itm/11277339468...m=112773394685
Greg Smyrna TN
Old 06-07-2018, 06:09 AM   #16
Boog
laying low
Boog's Avatar
Re: gas tank rust
Maybe use a good tank coating now before that new tank is installed to get the most out of both the tank and coating? Insurance.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 06-13-2018, 09:20 PM   #17
Mikes68C10
Mikes68C10's Avatar
Re: gas tank rust
Finally! my tank was delivered. Went through Advance Autoparts. They had a 30% off special going... Spectra premium tank for my 68 delivered for 170.00
Spectra Premium Fuel Tank
Part No GM49A
Warranty: 3 YR REPLACEMENT IF DEFECTIVE
The extra week of wait almost killed me.... Dropping at the garage tomorrow morning, hoping to have my truck back in my driveway by early next week!
Then I can get to giving her a good cleaning.
Mike
Old 07-01-2018, 05:07 PM   #18
prodjay10
Re: gas tank rust
What'd you guys think of your new tanks?
My Dorman has a filler neck that is a tad too large. The gas cap is loose because of it.
Old 08-09-2018, 11:17 AM   #19
engineer_gregh
Re: gas tank rust
Installed my new tank yesterday. Fit was good and my gas cap is nice and tight. I hope this one lasts longer than the LMC tank I installed seven years ago. Time will tell.
Greg Smyrna TN
Old 10-29-2018, 08:00 PM   #20
AussieinNC
Moderator
AussieinNC's Avatar
Re: gas tank rust
Have to assume everyone knows to NEVER click on any hidden links in any messages on any boards....
These forms of web trash are dangerous in the extreme, especially for the non technical among the population.
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 10-30-2018, 05:54 PM   #21
racerop
racerop's Avatar
Re: gas tank rust
Shouldn’t that post be removed?
racerop is offline   Reply With Quote
Old 10-30-2018, 08:31 PM   #22
AussieinNC
Moderator
AussieinNC's Avatar
Re: gas tank rust
The admins should be able to remove the post...
The hidden links in the post are all still active....
Please dont click on any links....
Just dropped a note to the admins
2012 Chevy Equinox
Old 02-12-2019, 12:36 PM   #23
blue27
blue27's Avatar
Re: gas tank rust
Does anyone make a kit for our truck using a polyethylene tank? Would love to do away with the metal tank all together. Thanks.
blue27 is offline   Reply With Quote
Old 04-25-2019, 07:24 AM   #24
littlehopper
Re: gas tank rust
Part No GM49A
Mike
How did you make out with your tank Mike? Did you have any issues?
littlehopper is offline   Reply With Quote
