06-16-2018, 06:38 AM | #1 |
Help
I am going to put something like line-x on the floor inside my cab . What do i use ?????????????????????????????????
06-16-2018, 12:38 PM | #2 |
Re: Help
I used lizard skin on mine....be a lot cheaper than linex....but linex is top quality stuff
06-16-2018, 02:04 PM | #3 |
Re: Help
Greg, where do you get it ?????
06-16-2018, 02:08 PM | #4 |
Re: Help
got some from summit some from speedway....works well with the gun...but guns not cheap...you can get a kit that has gun and lizardskin....cleans up with water...mines got sanding dust all over it in these pics ..it cleans easy though...
06-16-2018, 02:12 PM | #5 |
Re: Help
did the underside of my bed also....
06-16-2018, 04:41 PM | #6 | |
Re: Help
A good epoxy primer and a top coat of 2K single stage urethane is better and cheaper. The reason I ask is that lots of folks think bedliner is the cure all... which it is not.
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
06-16-2018, 11:30 PM | #7 |
Re: Help
Foot Stomper, Can you recommend a brand of good epoxy primer and a top coat of 2K single stage urethane. I am at this point and was just planning and costing out ideas.
sorry to highjack this thread but may be it will help |
06-17-2018, 10:58 AM | #8 |
Re: Help
Does linex or any other brands offer a tinted or color match option.
I'm afraid that in 10-20 years I'll be trying to chip off the coating but would love to use on my blazer floor. Posted via Mobile Device |
06-17-2018, 11:15 AM | #9 |
Re: Help
linex can color match any color....they have as many paint cards as a body shop
06-17-2018, 03:24 PM | #10 |
Re: Help
Any 2K epoxy is as good as the next one in most cases. Same goes for 2K urethane single stage paint. Go see Guy, he'll have some good stuff for sure!
06-18-2018, 05:39 AM | #11 |
Re: Help
I agree with Foot Stomper. Why bed liner on the inside? It does nothing for heat or noise blocking. Unless you are using it solely as a floor covering instead of carpet. Lizard skin claims to control heat/noise, though I have never tried it.
With that said, I used bedliner on the underside of the cab floor. The primary purpose was to visually hide rust repair weld seams. The underside of my fenders will also get a layer of bed liner over epoxy to add an extra layer of rock protection. |
06-18-2018, 05:41 AM | #12 |
Re: Help
Also, the most common recommended DIY bed liner products are:
SEM Pro-Tex U-Pol Raptor Liner |
