Old 06-18-2018, 12:35 PM   #1
OUbesto
OUbesto's Avatar
How long until an oil leak appears????
I just installed new FelPro #1635 silicone valve cover gaskets. I called the FelPro Customer service rep and asked about installation suggestions etc. He said do not use any type of adhesive, sealant etc....just put 'em in bareback! So that's what I did! After reading many of the forum posts, I only tightened the bolts using a nut driver with not much more than a wrist turn snug. Once done, I started engine and let run for about fifteen minutes and could not see any leaks....VOILA!
But my question is how long do I have to wait to truly know if these pretty expensive silicone gaskets are not going to leak? Do you know right away? Is it something that might take a few hours of running time etc??? Any comments?
1970 C-10 CST, LWB, 402/400, A/C
OUbesto is offline   Reply With Quote
Old 06-18-2018, 12:59 PM   #2
Coley
Coley's Avatar
Re: How long until an oil leak appears????
Small block chevy?......probably 15 minutes, lol.
Great little engines but known as oil leakers
All Good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 06-18-2018, 01:43 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Regardless of how good the gaskets are, I would help them do their job with a set of spreader bars. https://www.amazon.com/s/?ie=UTF8&ke...l_5nrfifmdd3_e
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 06-18-2018, 02:30 PM   #4
weq92f
weq92f's Avatar
Probably the last set of rocker cover gaskets you buy for that motor!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 06-18-2018, 03:53 PM   #5
72LB
72LB's Avatar
I agree if your using steel covers.
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
Old 06-18-2018, 04:01 PM   #6
cleszkie
cleszkie's Avatar
Are these the steel reinforced blue silicon gaskets. If so, I have had very good results with these. But I also ditched the stamped steel rocker covers in favor of some cast aluminum units.
You will need to run longer than 15 minutes at idle. Go out on the freeway and then come back and shine a light up at the back outside corner of each rocker cover. if you see any wetness on the head, you have not completely stopped the leak.
cleszkie is offline   Reply With Quote
Old 06-18-2018, 04:41 PM   #7
'70_402
'70_402's Avatar
it has to do more with the type and quality of your valve covers than anything... you can use an old cheap cork gasket with some nice thick alum covers with a good flange and you'll be fine for years!!
'70_402 is offline   Reply With Quote
Old 06-18-2018, 04:43 PM   #8
OUbesto
OUbesto's Avatar
I did install The FelPro blue, steel reinforced gaskets. They did install quite easily largely because of their rigid structure. I could easily use my fingers to hold in place then position valve cover over the head. I then lined up the holes and used a punch to center up the cover, the gasket over the bolt hole. Very easy! The worst part of the job was cleaning off the old RTV and glued on cork from the valve cover.
Old 06-18-2018, 04:53 PM   #9
OUbesto
OUbesto's Avatar
Thanks for the suggestion on the spreaders. I bought them today from Amazon although I had to find the 8 cyl BB set.
Old 06-18-2018, 07:00 PM   #10
BRL
BRL's Avatar
...yep, I put quality FelPro under my Bug valve covers without lock washers...and lost one cover on a steep hill in the middle of the night, in the middle of nowhere!
Drilled holes in the Bug valve cover bolts and safety wired them.
I think I have cork gaskets under my aluminum covers on the Chevy...well they don't leak anymore than anything else does under that hood! HA!
BRL is offline   Reply With Quote
Old 06-19-2018, 02:55 PM   #11
toolboxchev
Those are not the good ones, I have half of a different set that are thick and made with a convex so when you tighten them down they spread the pressure instead of bend.
I picked them up in a junk yard. Need 4 more.
toolboxchev is offline   Reply With Quote
Old 06-19-2018, 03:23 PM   #12
Grumpy old man
Grumpy old man's Avatar
50 year old engines , Try 50 year old methods . Cork and Permatex #1 works every time . no more leaks
Old 06-19-2018, 03:26 PM   #13
OUbesto
OUbesto's Avatar
Too late....already installed!
Old 06-23-2018, 02:39 AM   #14
BCOWANWHEELS
Depends on how much blow by your engine has...............
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
