RPM question
Just wondering; does the amount of cylinders in an engine have any bearing on the rpms it turns? For instance: if the drive train was otherwise the same, would a 6 cylinder engine run at a different rpm than an 8 at the same speed? My initial thought is no because the final drive on a non o.d tranny (for instance) is 1 to1, and that should remain constant regardless of how may cylinders a motor has right? Funny that in 52 years of living I have never pondered this question before.
Re: RPM question
No!
A 4,6 or 8 would all be the same rpm. |
![]() Join Date: Dec 2011
Re: RPM question
Main thing limiting RPM is stroke length.
Piston speed is approximately constant. Tiny engines go 20k rpm and big ship engines go 50 rpm. But the piston speed for both is about the same. There is a chart for that somewhere in the engine text books.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
![]() Join Date: Jun 2016
Re: RPM question
Piston speed can vary. On any engine, piston speed at idle is different than piston speed at redline. You just want to keep it below the speed of sound.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
Re: RPM question
Gears determine rpm not pistons.
Re: RPM question
Yes, for what actually happens with the engine. We were commenting more on the redline or normally designed operating range.
Do doubt you can take an engine designed for an operating rpm range and keep it in first gear longer and really get the rpms way up. But not for long. ;-)
Re: RPM question
The OPs question was whether the number of pistons make a difference in rpms with the same drivetrain, it doesn't.
Re: RPM question
Exactly.
