Old 06-23-2018, 09:35 AM   #5501
Gregski
Gregski's Avatar
Re: Restoring Rusty
so $217 dollars later (yes more than what we paid for the transmission in the first place) see lesson #1 above, ha ha we had ourselves what we believe is a proper or more better transmission mounted shifter linkage - this one I was told came out of a Chevelle
Gregski is offline   Reply With Quote
Old 06-23-2018, 09:57 AM   #5502
Gregski
Gregski's Avatar
Re: Restoring Rusty
and this is what the shifter bits looked like when they arrived, can't wait to bolt them on and give them a go shiftin gears
hopefully they don't position the shifter too far back where we have bench seat clearance issues
kinda cool that the eBayer threw in that white shifter ball, I happen to have a shifter stick that I hope will work so this should give me everything I need
Old 06-23-2018, 10:01 AM   #5503
Gregski
Gregski's Avatar
Re: Restoring Rusty
Saginaw Specifics
When looking at a Saginaw transmission, the front input shaft will likely have one or multiple grooves cut around its diameter. These grooves are there to indicate the ratios of the gears inside the transmission.
0 grooves: First 2.84, Second 2.01, Third 1.34, Fourth, 1.00
1 groove: First 2.54, Second 1.84, Third 1.44, Fourth, 1.00
1 groove: First 2.54, Second 1.84, Third 1.32, Fourth, 1.00
2 grooves: First 3.11, Second 2.20, Third 1.47, Fourth, 1.00
3 grooves: First 3.50, Second 2.46, Third 1.65, Fourth, 1.00 (I believe ours has three grooves so it's this one)
Old 06-23-2018, 09:01 PM   #5504
rusty76
rusty76's Avatar
Re: Restoring Rusty
This ought to be fun. I’m watching. I know you are ready to cruise a new four speed.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 06-24-2018, 06:39 PM   #5505
Gregski
Gregski's Avatar
Re: Restoring Rusty
so decided to clean the Saginaw four speed transmission a bit, using Mineral Spirits from Home Depot, a wire brush, and some paper towels
Old 06-24-2018, 06:41 PM   #5506
Gregski
Gregski's Avatar
Re: Restoring Rusty
remember our goal being: Progress Not Perfection
Old 06-24-2018, 06:43 PM   #5507
Gregski
Gregski's Avatar
Re: Restoring Rusty
and here it is with the Hurst four speed shifter linkage mounted and my old chrome HURST shifter installed, not sure if this stick will work/clear but we shall see, it does look pretty cool though
of course couldn't mount the white ball do to thread differences not only size but also pitch, coarse vs fine, it's not easy fellas, really wanted to see that ball atop the stick
Old 06-24-2018, 06:53 PM   #5508
Gregski
Gregski's Avatar
Re: Restoring Rusty
When looking for a brand new Hurst shifter components I further learned there were two Saginaw transmission types the 441 and the 456.
Hurst makes linkage for the 441 but not for the 456. So naturally I believe I have the 456, lol. Though with that Chevelle style bracket I think it makes it a moot point as to which one I have the 441 vs the 456 as it mounts the shifter using the bracket and ignored the holes in the tailshaft.
hope you is following all this it can get unnecesarily complicated
and I still don't get how this is supposed to be a torque tube transmission as it accepts a regular Turbo 350 yoke and has a rear seal for an open shaft, but the graphic saying it could be off of a 1981-82 Camaro or Firebird makes me feel a bit warm and fuzzy inside
Old 06-25-2018, 10:39 AM   #5509
hatzie
hatzie's Avatar
Re: Restoring Rusty
The F-body torque tube mounts to the three holes on the bottom of the tailhousing.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-26-2018, 01:15 AM   #5510
Gregski
Gregski's Avatar
Re: Restoring Rusty
thanks bud anyway you can help me find a pic of one, I can't seem to find it on the Google, ha ha
Old 06-26-2018, 01:36 AM   #5511
brakenit
Re: Restoring Rusty
He meant torque arm, 3rd and 4th gen f-bodies had a torque arm suspension. C5 and newer Corvettes have a torque tube.
A bushing bolts to the tail housing of the transmission and then a link connects the rear axle to that bushing to control axle rotation. It's basically a type of 3 link suspension.
Looks like the Vega had a torque arm suspension as well.
I found this picture here.
http://dave.h-body.org/H-body%20Conversion%20Tips.htm
brakenit is offline   Reply With Quote
Old 06-26-2018, 01:59 AM   #5512
Gregski
Gregski's Avatar
Re: Restoring Rusty
Thank you, aha, I appreciate that, but there's a big difference between a torque tube and a torque arm. I can buy into the torque arm setup, the torque tube as you pointed out I only knew of one modern car that had it that being the Corvette, the older Chevys may have had it but those may have been pre War cars or 50s.
Old 06-26-2018, 02:23 AM   #5513
brakenit
Re: Restoring Rusty
I agree, I don't understand why your graphic says torque tube since that should refer to some type of enclosed driveshaft which no Camaro ever had.
Old 07-05-2018, 03:28 PM   #5514
Gregski
Gregski's Avatar
Re: Restoring Rusty
it's that time of year again Comrads, haha
Old 07-05-2018, 05:26 PM   #5515
MikeB
MikeB's Avatar
Re: Restoring Rusty
Saginaw Specifics
0 grooves: First 2.84, Second 2.01, Third 1.34, Fourth, 1.00 (I believe ours has zero grooves so it's this one)
And the one with the tallest first gear (2.54) can handle the most torque. That's the ratio our trucks used for 350s with 3-speed manual trans.
The 3.50 first gear was used behind small six cyl engines, like the 250. Your 2.84 is probably right on the ragged edge for a 350, but I know you're a conservative driver.
Mike
82 C10 Custom Deluxe SWB -- original paint, 355/TH350, Vortec heads, GM RamJet 350 roller cam
69 C10 LWB -- Bought in 1989, now my son's http://67-72chevytrucks.com/vboard/s...d.php?t=775449
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 19 years! This is the very first car/truck Internet forum I joined.
MikeB is offline   Reply With Quote
Old 07-05-2018, 08:33 PM   #5516
rusty76
rusty76's Avatar
Re: Restoring Rusty
Is that a current pic of Rusty? Man what happened to the hood? I still like seeing you taking Rusty camping.
My build thread
Crossmembers CC
Old 07-05-2018, 10:46 PM   #5517
Gregski
Gregski's Avatar
Re: Restoring Rusty
yes current pic, used wrong acid, muriatic instead of phosphoric to clean it, broke my heart when the rust came back, got second hood, will paint it instead, the rusted one is also tacoed
peace and chicken grease,
g
Old 07-11-2018, 03:20 AM   #5518
Gregski
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by MikeB View Post
...but I know you're a conservative driver.
ha ha, yup, I almost chocked on my beer when I read that, sure thing I'm a super hypermiler, lol
Old 07-11-2018, 03:25 AM   #5519
Gregski
Gregski's Avatar
Re: Restoring Rusty
Rusty treated me to some scary transmission noises on the way to work this morning to where I had to limp it home after work. So I decided to open up Midnight Auto and go Def Con 4 on the ol' OD trans!
I lifted the truck up to the highest click on the Harbor Freight 6 ton jacks and went to town
at nearly 10 PM it was still almost 80* F
Old 07-11-2018, 03:29 AM   #5520
Gregski
Gregski's Avatar
Re: Restoring Rusty
How does a one man with a bad elbow git the trans out by himself without a proper transmission jack you ask?
Introducing the Semi Fully Adjustable TransJack 3000... suitable for the semi amateur casual transmission swapper
brought to you by Pollack Potrafi (TM)
Old 07-11-2018, 03:31 AM   #5521
Gregski
Gregski's Avatar
Re: Restoring Rusty
and two short hours later she was out
Profanity Disbursement = Minimal
Old 07-11-2018, 03:35 AM   #5522
Gregski
Gregski's Avatar
Re: Restoring Rusty
mandatory stare and compare of the GM New Process NV833 and the Saginaw 4 Speed
hard to tell from the pics but they is nearly identical at roughly 21 5/16 inches long from bell housing to tailshaft end
Old 07-11-2018, 03:37 AM   #5523
Gregski
Gregski's Avatar
Re: Restoring Rusty
doing my best here to hold the squigly measuring tape with one hand and snap the pic with the other
Old 07-11-2018, 09:34 PM   #5524
MikeB
MikeB's Avatar
Thumbs up Re: Restoring Rusty
Can't tell you how awesome these 12-ton stands are. I've never had to extend them past half way up. Just trying to spend your money.
https://www.northerntool.com/shop/to...hoCUsUQAvD_BwE
Mike
Old 07-11-2018, 10:35 PM   #5525
Gregski
Gregski's Avatar
Re: Restoring Rusty
me want
Copyright ©2000 - 2019, vBulletin Solutions Inc.
