#126 |
Re: Fashionable Fever! - 1969 Chevy C10 Build
#127 |
Getting her closed up... slowly... made a list of what needed to be done before I flip the cab back upright. Still have quite a bit to do!
#128 |
Looks great man! Givin me inspiration to start on my 69. Probably gonna have to get the one piece floor for mine also. Just so expensive for me right now haha Keep up the work man! Cant wait to see it finished
1971 GMC Sierra Grande 2500 2wd "Sadiee" Caddy 472/TH400 Project "Sadiee" 1969 Chevy C/10 Build "Maisie" Thread coming soon |
#129 |
Thank you. I would do the one piece floor if you have to replace a majority of the cab. It's money well spent and saves a ton of time. For me and the amount of rust I had, the cost of the one piece floor vs all the patches was only $80-$100 more.
#130 |
Work on this cab has slowed down a bit since I purchased a 67 c10. So I've been trying to get that driveable and running.
I finished (hopefully) with the passenger side as far as replacing/repairing metal. The drip rail is put back on |
#131 |
Here is just a pic of the shiny new metal I welded in and a little bit of the header panel. It's coming along...
#132 |
I pushed this off to the side for awhile so I could work on my "new" 67 I bought in early June. I'm at a standstill on that while I wait for the engine block to get professionally cleaned and checked.
It doesn't look like much, but anything helps right? It's taking me a little bit to make these pieces by hand. This is the drivers side now. I drilled a hole for the wire to run through the pillar to feed my cab roof lights. Just through in a 3/4" chase nipple so the wire won't rub against sharp metal and short out down the road. I also bent up the piece to tie back into the drip rail area. Just have to cut it down to fit and weld it in. Should be able to get that installed by the end of the week! |
#133 |
Wow... I just found your thread and I must say, you've been busy. Nice work this far, keep it up and you'll have a brand new truck when you're finished.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#134 |
Hey Duane, I appreciate that! It's coming very slowly, but I enjoy (most of the time) the heck out of restoring this old thing. Hopefully when it's done it can be as nice as your pickup!
#135 |
Got the missing piece welded in! Still got to clean up the welds and then I can reinstall the drip cap.
#136 |
I got my 67 running and drivable. Drove it over to the alignment shop. Should be done next week sometime. Not too worried since it gives me more room in the garage!
Couldn't wait to get back at this cab work! Finished up the drivers side drip rail and I made the missing piece to go on the inner roof. Hopefully tomorrow I can weld the piece in! |
#137 |
Welded in the last piece on the drivers side inner roof. Almost ready to flip the cab upright!
#138 |
Managed to get the cab flipped upright after sanding all the paint off the interior roof. I need to purchase some insulation for the roof before I weld back on the outer roof skin.
So in the meantime I just started to work on the lower pillars and kick panel on the passenger side. The kick panel is a really doozy for some reason. It took awhile to get it cut to fit and tacked in place. Still got a bit more welding to do on the panels. Here is the lower "B" pillar patch. Of course it needed some modification to get it to line up correctly. I'm curious why there are two holes vertically in a line where the back cab support matches up with the b pillar. I thought these were spot welded in place, but it seems the holes are for bolting the b pillar to the floor. Is this correct? |
#139 |
Passenger side kick panel mostly done. Need to clean up some welds and such. The A pillar is also tacked in. I also hung the door in preparation for the cab corner and rocker.
#140 |
I moved on to the drivers side after looking at the passenger side corner and rocker. Wasn't ready to tackle that. So I got the drivers side kick panel done and B pillar tacked on. I also got the A pillar all ready to be tacked on just ran out of time tonight.
#141 |
Finished with the drivers side B pillar. Also cleaned up the cab corner area in preparation to get that done.
Last night I hung the door and screwed on the cab corner and rocker. Got it all to line up, but I'm left with a 5/16" gap along side the bottom of door. The vertical gap along the cab corner seam and up look pretty good and the area just below the drip rail looks okay. I know these didn't have the cleanest gaps back then so I'm not that worried. I'd just like to get the rocker up a bit more, but if I do that, the bottom of the rocker and cab corner don't line up. I can't move my cab corner up any or the body lines won't line up. So I'm stuck with a little bigger gap below the door unless someone has any ideas? |
#142 |
Looking good on the cab repairs. Glad I'm not the only having to do the same repairs. Now if I found this thread earlier I would of got you to bend me a couple of those above the door pieces aswell. Were they tough to do with one part being square and the other one rounded.
#143 | |
As far as the part above the door - do you mean where the drip rail attaches to or the inner roof where it ties into the door jamb? The inner roof was actually easier than I thought it would be. I took a piece of 20gauge and used my welding tank to bend it and then used my air flanger for the door jamb. The piece where the drip rail attaches was a bit tough since my metal brake doesn't do those back to back bends. I actually had to weld a piece of 1/4" round to the metal and bend it by hand. It's not as tight of a 90* bend as the original, but it works and it's pretty hidden. I saw your pics on another thread. I still got to check out your build thread, but it looks like your going all out on yours! It's gonna be sweet! |
#144 |
The piece in post 135. The one side is non existent and the other side is half there on mine. Looks good though but tough to bend I bet.
I got a door and a fender I'm going to carve up for most of my patches. The curves look pretty close to the same as the roof skin. I'll have to track down one of those air flange tools, looks like it did a good job and would be handy to have with the amount of work I'm doing. |
#145 | |
The flange tool did an okay job. I'm sure they make a better one than what I have. I bought mine at a Napa a few years ago. It was probably $50. Funny thing is is I don't even have an air compressor... it's on my list to get! |
#146 |
I finally got my drivers cab corner tacked in. That thing took awhile to get fitted. I've spent a lot more hours on it than I thought it would take. I figured I better make it look good since it's a piece people like to look at! After I tacked it in I tested my rocker and it dropped right in so that's always a good thing! Hopefully I can keep working on the cab for another month or so before it gets too cold.
#147 | |
![]() Join Date: Sep 2015
#148 | |
#149 |
Any updates recently? Figured you would have had the cab primed by now
#150 | |
I've been watching everybody's builds and getting eager to get out there again soon! |
